Hello together,
I try to get the asset_tracker_v2 up and running on the thingy:91.
At the moment I get an Error from AWS_iot aws_iot: mqtt_connect, error: -116
My problem is that the error code -116 is not really mentioned in zephyrs errno.
Also the mqtt_connect function uses only functions from zephyrs mqtt.c/mqtt.h. So I thought I could add some LOG_ERR("...") Statements to the mqtt. c so I could see where everything get's messed up.
But I dont really see those messages in the Output of the LTE Link monitor.
I added the LOG Makros:
CONFIG_LOG_DEFAULT_LEVEL=4 CONFIG_MQTT_LOG_LEVEL_DEFAULT=y
LOG_MODULE_REGISTER(net_mqtt, CONFIG_MQTT_LOG_LEVEL);
