SoftDevice size value in DFU init packet
We are using nRF52840 with SDK 15.2.0, a bootloader and the SoftDevice 6.1.0. We are able to perform a DFU for our application by downloading the .bin and .dat files of the new firmware in Flash memory, to fill the DFU settings structure with the correct values, and after a reboot the bootloader updates our firmware as expected.
Now we would like to perform a DFU as the same way for the bootloader and the SoftDevice 6.1.1. With nRF Util we have created the .zip file for the BL+SD DFU and it works perfectly with BLE using nRF Connect. But for our own download process in Flash memory, when we fill the DFU settings, we need to know the SoftDevice size (variable dfu_settings.sd_size).
With nRF Util we can use the command "nrfutil pkg display my_file.zip" to read the following informations:
|- sd_size: 151016
|- bl_size: 24128
But we are not able to find where are stored these values in the .dat file. For this test, we have written directly in the code this value for SD and it works. So now we just need to read the value from the downloaded data to be able to perform a DFU with any SD size if needed. Can you explain where the SD and BL sizes are stored ?
Thanks for your help!
