Zephyr and OpenThread join support
While attempting to join a network formed by the OpenThread border router reference implementation and an external commissioner using the Android app, my zephyr end device (based on the lwm2m client sample) ends up failing an assertion:
assertion "awaited_property == AWAITED_PROPERTY_NONE" failed: file "WEST_TOPDIR/zephyr/modules/hal_nordic/nrf_802154/serialization/platform/nrf_802154_spinel_response_notifier.c", line 63, function: nrf_802154_spinel_response_notifier_lock_before_request
I'm not sure I'm doing this properly. CONFIG_OPENTHREAD_CUSTOM_PARAMETERS has to be set in order to be able to link the binary which I think is a little suspicious and not documented as far as I know:
CONFIG_OPENTHREAD_JOINER=y
CONFIG_OPENTHREAD_CUSTOM_PARAMETERS="OPENTHREAD_CONFIG_JOINER_ENABLE=1"
CONFIG_OPENTHREAD_JOINER_AUTOSTART=y
CONFIG_OPENTHREAD_JOINER_PSKD="J01NU5"
CONFIG_MBEDTLS_HEAP_SIZE=10240
  • Hello, Louis!
    Are you using Zephyr standalone or the nRF Connect SDK, based on Zephyr? In the latter we provide a OpenThread configuration guide and samples that should be more straightforward to setup with our devices.
    I will ask the developers about the issue you're seeing here.
    Carl Richard
  • Thanks,
    I'm using the nRF SDK. I tried to add join support to the cli sample. Configuring the application with OPENTHREAD_JOINER_AUTOSTART didin't do anything (no failed assertion but no join either). So I added a "join button" (project here) and ended up with the same failed assertion.
  • Hello again!
    Thanks for the information. I reached out to the developers regarding your issue and got back that the CONFIG_OPENTHREAD_CUSTOM_PARAMETERS="OPENTHREAD_CONFIG_JOINER_ENABLE=1" should not be necessary as the flag is enabled by CONFIG_OPENTHREAD_JOINER. However, the actual issue is related to network core communication. Could you try to enable logging on the network core and provide the output here? You can read more about logging from the network core in the nRF53 series documentation.
    Carl Richard
  • CONFIG_NET_CORE_LOG_LEVEL_DBG=y
    doesn't produce more output :
    E: No response within timeout 500
    exit
    Is that what you had in mind?
  • Hi!
    I thinking about logs from the code running on the network core of the nRF5340. You should have the "hci_rpmsg" sample running on it. Logging should be enabled by default in the sample, but for increased verbosity you can add:
    CONFIG_LOG_DEFAULT_LEVEL=4
    CONFIG_BT_DEBUG_LOG=y
    Please notify me if anything is unclear!
    Carl Richard
