Zephyr and OpenThread join support
While attempting to join a network formed by the OpenThread border router reference implementation and an external commissioner using the Android app, my zephyr end device (based on the lwm2m client sample) ends up failing an assertion:
assertion "awaited_property == AWAITED_PROPERTY_NONE" failed: file "WEST_TOPDIR/zephyr/modules/hal_nordic/nrf_802154/serialization/platform/nrf_802154_spinel_response_notifier.c", line 63, function: nrf_802154_spinel_response_notifier_lock_before_request
I'm not sure I'm doing this properly. CONFIG_OPENTHREAD_CUSTOM_PARAMETERS has to be set in order to be able to link the binary which I think is a little suspicious and not documented as far as I know:
CONFIG_OPENTHREAD_JOINER=y
CONFIG_OPENTHREAD_CUSTOM_PARAMETERS="OPENTHREAD_CONFIG_JOINER_ENABLE=1"
CONFIG_OPENTHREAD_JOINER_AUTOSTART=y
CONFIG_OPENTHREAD_JOINER_PSKD="J01NU5"
CONFIG_MBEDTLS_HEAP_SIZE=10240
  • Hello again!
    Apologies for the delayed answer. Your sample functions when I compile it here, and looking at your autoconf.h it seems like some key configurations are missing somehow. Most notable CONFIG_NRF_802154_SOURCE_NRFXLIB. Could you share your build log from building the cli sample?
    And just to make sure, you have not changed <zephyr_base>/nrf/samples/openthread/common/overlay-ot-defaults.conf right?
    Carl Richard
  • Hi Carl,
    I confirm that nothing from the zephyr base was changed. Here's the output of the log:
    Including boilerplate (Zephyr base): /home/theia/zephyr/cmake/app/boilerplate.cmake
    -- Application: /home/project/cli
    -- Zephyr version: 2.5.99 (/home/theia/zephyr)
    -- Found Python3: /usr/bin/python3.6 (found suitable exact version "3.6.9") found components: Interpreter
    -- Found west (found suitable version "0.10.1", minimum required is "0.7.1")
    -- Board: nrf5340dk_nrf5340_cpuapp
    -- Cache files will be written to: /home/theia/.cache/zephyr
    -- Found toolchain: gnuarmemb (/opt/gcc-arm-none-eabi/gcc-arm-none-eabi-10-2020-q4-major)
    -- Found BOARD.dts: /home/theia/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp.dts
    -- Generated zephyr.dts: /home/project/cli/build/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: /home/project/cli/build/zephyr/include/generated/devicetree_unfixed.h
    -- Generated device_extern.h: /home/project/cli/build/zephyr/include/generated/device_extern.h
    warning: SHELL_STACK_SIZE (defined at subsys/shell/Kconfig:28) was assigned the value '2048' but got
    the value ''. Check these unsatisfied dependencies: SHELL (=n). See
    http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_SHELL_STACK_SIZE.html and/or look up
    SHELL_STACK_SIZE in the menuconfig/guiconfig interface. The Application Development Primer, Setting
    Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
    too.
    warning: SHELL_CMD_BUFF_SIZE (defined at subsys/shell/Kconfig:44) was assigned the value '416' but
    got the value ''. Check these unsatisfied dependencies: SHELL (=n). See
    http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_SHELL_CMD_BUFF_SIZE.html and/or look
    up SHELL_CMD_BUFF_SIZE in the menuconfig/guiconfig interface. The Application Development Primer,
    Setting Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be
    helpful too.
    warning: SHELL_ARGC_MAX (defined at subsys/shell/Kconfig:70) was Parsing /home/project/cli/Kconfig
    Loaded configuration '/home/theia/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp_defconfig'
    Merged configuration '/home/project/cli/prj_nrf5340dk_nrf5340_cpuapp.conf'
    Merged configuration '/home/theia/zephyr/../nrf/samples/openthread/common/overlay-ot-defaults.conf'
    Configuration saved to '/home/project/cli/build/zephyr/.config'
    Kconfig header saved to '/home/project/cli/build/zephyr/include/generated/autoconf.h'
    assigned the value '26' but got the
    http://docs.zephyrproject.org/latest/reference/kconfig/CONFIG_SHELL_ARGC_MAX.html and/or look up
    SHELL_ARGC_MAX in the menuconfig/guiconfig interface. The Application Development Primer, Setting
    too.
    -- The C compiler identification is GNU 10.2.1
    -- The CXX compiler identification is GNU 10.2.1
    -- Found assembler: /opt/gcc-arm-none-eabi/gcc-arm-none-eabi-10-2020-q4-major/bin/arm-none-eabi-gcc
    Adding '802154_rpmsg' firmware as child image since CONFIG_NRF_802154_SER_HOST is set to y
    === child image 802154_rpmsg - CPUNET begin ===
    -- Application: /home/theia/zephyr/samples/boards/nrf/ieee802154/802154_rpmsg
    -- Board: nrf5340dk_nrf5340_cpunet
    -- Found BOARD.dts: /home/theia/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpunet.dts
    -- Generated zephyr.dts: /home/project/cli/build/802154_rpmsg/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: /home/project/cli/build/802154_rpmsg/zephyr/include/generated/devicetree_unfixed.h
    -- Generated device_extern.h: /home/project/cli/build/802154_rpmsg/zephyr/include/generated/device_extern.h
    Parsing /home/theia/zephyr/Kconfig
    Loaded configuration '/home/theia/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpunet_defconfig'
    Merged configuration '/home/theia/zephyr/samples/boards/nrf/ieee802154/802154_rpmsg/prj.conf'
    Merged configuration '/home/theia/nrf/subsys/partition_manager/partition_manager_enabled.conf'
    Merged configuration '/home/project/cli/child_image/802154_rpmsg.conf'
    Configuration saved to '/home/project/cli/build/802154_rpmsg/zephyr/.config'
    Kconfig header saved to '/home/project/cli/build/802154_rpmsg/zephyr/include/generated/autoconf.h'
    -- Build type:
    -- Host:    Linux/x86_64
    -- Target:  Generic/arm
    -- Machine: cortexm
    -- Looking for include file stdatomic.h
    -- Looking for include file stdatomic.h - found
    -- Machine: cortexm
    -- C_FLAGS :  -Wall -Wextra
    -- Looking for include file fcntl.h
    -- Looking for include file fcntl.h - found
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /home/project/cli/build/802154_rpmsg
    === child image 802154_rpmsg - CPUNET end ===
    -- Build type:
    -- Machine: cortexm
    -- Machine: cortexm
    -- Check if the system is big endian
    -- Searching 16 bit integer
    -- Looking for sys/types.h
    -- Looking for sys/types.h - found
    -- Looking for stdint.h
    -- Looking for stdint.h - found
    -- Looking for stddef.h
    -- Looking for stddef.h - found
    -- Check size of unsigned short
    -- Check size of unsigned short - done
    -- Searching 16 bit integer - Using unsigned short
    -- Check if the system is big endian - little endian
    -- CMake build type: Debug
    -- Version: gfd27fc3a7
    CMake Warning at /home/theia/zephyr/CMakeLists.txt:1434 (message):
            The CMake build type was set to 'Debug', but the optimization flag was set to '-Os'.
            This may be intentional and the warning can be turned off by setting the CMake variable 'NO_BUILD_TYPE_WARNING'
    -- Configuring done
    -- Generating done
    [3/521] Preparing syscall dependency handling
    [13/521] Performing build step for '802154_rpmsg_subimage'
    [1/241] Preparing syscall dependency handling
    [232/241] Linking C executable zephyr/zephyr_prebuilt.elf
    [239/241] Linking C executable zephyr/zephyr.elf
               FLASH:       84348 B       256 KB     32.18%
                SRAM:       28416 B        64 KB     43.36%
            IDT_LIST:          0 GB         2 KB      0.00%
    [241/241] Generating zephyr/merged_CPUNET.hex
    [16/521] cd /home/project/cli/build/modules/openthread/build && /home/theia/.local/lib/python3.6/site-packages/cmake/data/bin/cmake -DLIST="OPENTHREAD_CONFIG_ASSERT_ENABLE=1;OPENTHREAD_CONFIG_BACKBONE_ROUTER_DUA_NDPROXYING_ENABLE=0;OPENTHREAD_CONFIG_BACKBONE_ROUTER_MULTICAST_ROUTING_ENABLE=0;OPENTHREAD_CONFIG_BORDER_AGENT_ENABLE=1;OPENTHREAD_CONFIG_BORDER_ROUTER_ENABLE=1;OPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS=0;OPENTHREAD_CONFIG_ENABLE_BUILTIN_MBEDTLS_MANAGEMENT=0;OPENTHREAD_CONFIG_CHILD_SUPERVISION_ENABLE=1;OPENTHREAD_CONFIG_COAP_API_ENABLE=1;OPENTHREAD_CONFIG_COAP_SECURE_API_ENABLE=1;OPENTHREAD_CONFIG_COMMISSIONER_ENABLE=1;OPENTHREAD_CONFIG_DHCP6_CLIENT_ENABLE=1;OPENTHREAD_CONFIG_DHCP6_SERVER_ENABLE=1;OPENTHREAD_CONFIG_DIAG_ENABLE=1;OPENTHREAD_CONFIG_DNS_CLIENT_ENABLE=1;OPENTHREAD_CONFIG_ECDSA_ENABLE=1;OPENTHREAD_CONFIG_HEAP_EXTERNAL_ENABLE=1;OPENTHREAD_CONFIG_IP6_FRAGMENTATION_ENABLE=1;OPENTHREAD_CONFIG_JAM_DETECTION_ENABLE=1;OPENTHREAD_CONFIG_JOINER_ENABLE=1;OPENTHREAD_CONFIG_LINK_RAW_ENABLE=1;OPENTHREAD_CONFIG_MAC_FILTER_ENABLE=1;OPENTHREAD_CONFIG_TMF_NETWORK_DIAG_MTD_ENABLE=1;OPENTHREAD_CONFIG_TMF_NETDATA_SERVICE_ENABLE=1;OPENTHREAD_CONFIG_IP6_SLAAC_ENABLE=1;OPENTHREAD_CONFIG_SNTP_CLIENT_ENABLE=1;OPENTHREAD_CONFIG_UDP_FORWARD_ENABLE=1;OPENTHREAD_SPINEL_CONFIG_RCP_RESTORATION_MAX_COUNT=0;PACKAGE_NAME="OPENTHREAD";PACKAGE_VERSION="gfd27fc3a7";OPENTHREAD_CONFIG_THREAD_VERSION=OT_THREAD_VERSION_1_1;OPENTHREAD_CONFIG_NCP_UART_ENABLE=1;KERNEL;__ZEPHYR__=1;_FORTIFY_SOURCE=2;BUILD_VERSION=v2.4.99-ncs1-1818-g54dea0b2b530;__LINUX_ERRNO_EXTENSIONS__;USE_PARTITION_MANAGER=1;__PROGRAM_START;NRF5340_XXAA_APPLICATION;MBEDTLS_CONFIG_FILE="nrf-config.h"" -P /home/theia/modules/lib/openthread/etc/cmake/print.cmake
    PACKAGE_NAME=OPENTHREAD
    PACKAGE_VERSION=gfd27fc3a7
    KERNEL
    __ZEPHYR__=1
    _FORTIFY_SOURCE=2
    __PROGRAM_START
    MBEDTLS_CONFIG_FILE=nrf-config.h
    [512/521] Linking CXX executable zephyr/zephyr_prebuilt.elf
    [519/521] Linking CXX executable zephyr/zephyr.elf
               FLASH:      333684 B      1016 KB     32.07%
                SRAM:       87128 B       512 KB     16.62%
    [521/521] Generating zephyr/merged_domains.hex
  • Hi again!
    Thanks. This seems to may be an issue with the build environment, as the configuration is incomplete. Could you do the following before building again and see if that makes any difference:
    cd <ncs_root>/nrf
    git pull
    west update
    I.e. moving to the newest master and updating the whole SDK. There have been some changes to various thread related components lately, so I want to make sure that they are there. Please report back if you see any errors/warnings during the updating process.
    Carl Richard
  • Just got back from the developers that the issue could be related to an issue fixed by this pull request. Could you try to see if applying it as a patch makes any difference?
    Carl Richard
  • Unfortunately still the same result with the latest version. Note that nrf is at the same level as $ZEPHYR_BASE on my install, not under it which seems consistent with what I see here.
