Zephyr and OpenThread join support
While attempting to join a network formed by the OpenThread border router reference implementation and an external commissioner using the Android app, my zephyr end device (based on the lwm2m client sample) ends up failing an assertion:
assertion "awaited_property == AWAITED_PROPERTY_NONE" failed: file "WEST_TOPDIR/zephyr/modules/hal_nordic/nrf_802154/serialization/platform/nrf_802154_spinel_response_notifier.c", line 63, function: nrf_802154_spinel_response_notifier_lock_before_request
I'm not sure I'm doing this properly. CONFIG_OPENTHREAD_CUSTOM_PARAMETERS has to be set in order to be able to link the binary which I think is a little suspicious and not documented as far as I know:
CONFIG_OPENTHREAD_JOINER=y
CONFIG_OPENTHREAD_CUSTOM_PARAMETERS="OPENTHREAD_CONFIG_JOINER_ENABLE=1"
CONFIG_OPENTHREAD_JOINER_AUTOSTART=y
CONFIG_OPENTHREAD_JOINER_PSKD="J01NU5"
CONFIG_MBEDTLS_HEAP_SIZE=10240
  • Hi Carl,
    I rebuild my dev environment and only pulled nrfxlib before performing a "west update". I confirm that the pull request you mentioned made it to ZEPHYR_BASE. I also added :
    CONFIG_NRF_RTC_TIMER_USER_CHAN_COUNT=2
    to cli sample with added join support. Unfortunately, still the same result.
    Louis
  • Hi again!
    Please try to pull in nrf, not nrfxlib and then do the west update
    Carl Richard
  • still the same result after:
    # cd nrf
    # git pull origin master
    # cd ../nrfxlib
    # git pull ncs master
    # cd ..
    # west update
    # cd nrf
    # git rev-parse HEAD
    75db44dec9af4f52861759b05bcb3b309bcf3544
    # cd ../nrfxlib/
    5c6944ecf908d050da93d8755c3441a35ebdfa98
  • Hello again, Louis!
    Apologies for the delay here. I have been awaiting further comments from the developers, but have yet to receive any. In the meantime I would like you to test this a Thread: Cli application compiled on my system. Attached is the hex files for both the Application Core and the Network core. Please flash these to an nRF5340 DK and test whether it works for you or not.
    Network core:GENERATED_CP_NETWORK_merged_domains.hex
    Application core: GENERATED_CP_APPLICATION_merged_domains.hex
    For the on mesh joining procedure I've been following this documentation. It may be a bit different for external commissioners. Please report back your results!
    Carl Richard
  • Thanks Carl,
    Different result but still failed assertion triggering a reboot:
    uart:~$ ot joiner start J01NU5
    Done
    uart:~$ I: State changed! Flags: 0x0800800b Current role: 0
    I: State changed! Flags: 0x0800c00b Current role: 0
    E: No response within timeout 500
    ASSERTION FAIL @ WEST_TOPDIR/zephyr/drivers/ieee802154/ieee802154_nrf5.c:835
    E: r0/a1:  0x00000004  r1/a2:  0x00000343  r2/a3:  0x00000001
    E: r3/a4:  0x00006705 r12/ip:  0x0000a000 r14/lr:  0x000108d9
    E:  xpsr:  0x41000000
    E: s[ 0]:  0x00000000  s[ 1]:  0x00000000  s[ 2]:  0x00000000  s[ 3]:  0x00000000
    E: s[ 4]:  0x00000000  s[ 5]:  0x00000000  s[ 6]:  0x00000000  s[ 7]:  0x00000000
    E: s[ 8]:  0x00000000  s[ 9]:  0x00000000  s[10]:  0x00000000  s[11]:  0x00000000
    E: s[12]:  0x00000000  s[13]:  0x00000000  s[14]:  0x00000000  s[15]:  0x00000000
    E: fpscr:  0x00061cfd
    E: Faulting instruction address (r15/pc): 0x000462ec
    E: >>> ZEPHYR FATAL ERROR 4: Kernel panic on CPU 0
    E: Current thread: 0x200015c0 (ot_radio_workq)
    E: Resetting system
    I'll try to re-setup the OpenThread border router from scratch tomorrow. How did you setup your own?
