I am building the coded bluetooth gateway using nrf52840 and ENC28J60. Integrated between two examples:
- https://github.com/nrfconnect/sdk-nrf/tree/master/samples/bluetooth/central_hr_coded
- https://github.com/zephyrproject-rtos/zephyr/tree/master/samples/net/dhcpv4_client
I created two task:
void ethernet_task(void) {
struct net_if *iface;
printf("Run dhcpv4 client");
net_mgmt_init_event_callback(&mgmt_cb, net_handler,
NET_EVENT_IPV4_ADDR_ADD);
net_mgmt_add_event_callback(&mgmt_cb);
iface = net_if_get_default();
net_dhcpv4_start(iface);
/* Wait for a lease. */
k_sem_take(&got_address, K_FOREVER);
printk("Got IP Address");
while(1) {
//printk("ethernet task polling");
k_msleep(1000);
void ble_task(void) {
int err;
err = bt_enable(NULL);
if (err) {
printk("Bluetooth init failed (err %d)\n", err);
return;
printk("Bluetooth initialized\n");
bt_conn_cb_register(&conn_callbacks);
scan_init();
err = bt_scan_start(BT_SCAN_TYPE_SCAN_ACTIVE);
if (err) {
printk("Scanning failed to start (err %d)\n", err);
return;
printk("Scanning successfully started\n");
while(1) {
//printk("ble task polling");
k_msleep(1500);
There is no main function. I start two tasks using:
K_THREAD_DEFINE(ethernet_task_id, 1024, ethernet_task, NULL, NULL, NULL, 3, 0, 0); K_THREAD_DEFINE(ble_task_id, 1024, ble_task, NULL, NULL, NULL, 3, 0, 0);
If I just run one task (comment one K_THREAD_DEFINE of another task to prevent it from running), the running task can work perfectly. But if I let two tasks to run simultaneously , the MPU fault occur and CPU reset.
I am using nRF Connect SDK v1.5.0 with Zephyr SDK v2.4.99-nsc1
�[1B�[9D�[8D�[J[00:00:00.542,663] �[1;31m os: ***** MPU FAULT *****�[0m
�[8D�[J[00:00:00.542,694] �[1;31m os: Data Access Violation�[0m
�[8D�[J[00:00:00.542,694] �[1;31m os: MMFAR Address: 0x30a03�[0m
�[8D�[J[00:00:00.542,694] �[1;31m os: r0/a1: 0x40003000 r1/a2: 0x20007174 r2/a3: 0x00030a03�[0m
�[8D�[J[00:00:00.542,694] �[1;31m os: r3/a4: 0x00000000 r12/ip: 0x20000618 r14/lr: 0x0002ac21�[0m
�[8D�[J[00:00:00.542,724] �[1;31m os: xpsr: 0x81003813�[0m
�[8D�[J[00:00:00.542,724] �[1;31m os: Faulting instruction address (r15/pc): 0x00034688�[0m
�[8D�[J[00:00:00.542,724] �[1;31m os: >>> ZEPHYR FATAL ERROR 0: CPU exception on CPU 0�[0m
�[8D�[J[00:00:00.542,724] �[1;31m os: Fault during interrupt handling
�[0m
�[8D�[J[00:00:00.542,755] �[1;31m os: Current thread: 0x20005718 (idle 00)�[0m
I checked with addr2line, the crash position is /nRFConnectSDK/v1.5.0/modules/hal/nordic/nrfx/drivers/src/nrfx_spi.c:254
It happens on the SPI transfer byte process. I increased thread stack size but the problem still occur.
Does anyone meet this problem? and Do you know any method to find out more information about this problem to solve it?
Thanks.
