So ...
I'm still trying to get peripheral_uart running.
I'm using a nRF53 PDK (PCA 10095 - rev 0.8.0) (I've received two 0.11.0 boards, both of which died).
I'm using SDK 1.5.0
I've done the following.
Using ses I loaded and compiled zephyr/samples/bluetooth/hci_rpmsg as nrf5340pdk_nrf5340_cpunet. It compiles with no problems, but can't be loaded via target-> Download zephyr/zephyr.elf.
I've attached the ses log to this message as log1.txt.
I am able to download zephyr.hex o the board via NRF CONNECT->PROGRAMMER
I've attached the PROGRAMMER log as log2.txt.
Using ses I loaded and compiled peripheral_uart as nrf5340pdk_nrf5340_cpuappns. It compiles fine. When I start a debug session it fires up nicely - I've attached the debug output as log3.txt. Note that there is a warning message.
The advertising led flashes, I can see the board from my phone using the nRF Toolbox Uart app. When I try to connect the log on the phone shows it connecting, then disconnecting.
Any help would be appreciated.
2021-04-13T09:33:24.383Z INFO Application data folder: C:\Users\kover\AppData\Roaming\nrfconnect\pc-nrfconnect-programmer 2021-04-13T09:33:24.602Z DEBUG App pc-nrfconnect-programmer v1.4.8 official 2021-04-13T09:33:24.602Z DEBUG App path: C:\Users\kover\.nrfconnect-apps\node_modules\pc-nrfconnect-programmer 2021-04-13T09:33:24.603Z DEBUG nRFConnect 3.6.1 is supported by the app (^3.6.0) 2021-04-13T09:33:24.603Z DEBUG nRFConnect path: C:\Users\kover\AppData\Local\Programs\nrfconnect\resources\app.asar 2021-04-13T09:33:24.603Z DEBUG HomeDir: C:\Users\kover 2021-04-13T09:33:24.606Z DEBUG TmpDir: C:\Users\kover\AppData\Local\Temp 2021-04-13T09:33:24.682Z INFO Using nrfjprog library 10.12.1, pc-nrfjprog-js 1.7.6 2021-04-13T09:33:32.127Z INFO Using nrfjprog to communicate with target 2021-04-13T09:33:33.283Z INFO Using J-Link Software version 6.88 2021-04-13T09:33:34.368Z INFO Segger serial: 960125438 2021-04-13T09:33:34.368Z INFO Segger speed: 2000 kHz 2021-04-13T09:33:34.368Z INFO Segger version: J-Link OB-K22-NordicSemi compiled Jan 21 2020 17:33:01 2021-04-13T09:33:34.369Z INFO Core probed: 960125438 2021-04-13T09:33:34.369Z INFO Core RAM: 512KiB 2021-04-13T09:33:34.369Z INFO Core ROM: 1024KiB in pages of 4KiB 2021-04-13T09:33:34.617Z INFO Model: NRF5340_xxAA_ENGA. 2021-04-13T09:33:36.924Z INFO Segger serial: 960125438 2021-04-13T09:33:36.924Z INFO Segger speed: 2000 kHz 2021-04-13T09:33:36.925Z INFO Segger version: J-Link OB-K22-NordicSemi compiled Jan 21 2020 17:33:01 2021-04-13T09:33:36.927Z INFO Core probed: 960125438:1 2021-04-13T09:33:36.928Z INFO Core RAM: 64KiB 2021-04-13T09:33:36.928Z INFO Core ROM: 256KiB in pages of 2KiB 2021-04-13T09:33:38.388Z INFO Core0: Reading device non-volatile memory. This may take a few seconds. 2021-04-13T09:33:39.668Z INFO Core0: UICR has been read. Click read button to read full non-volatile memory. 2021-04-13T09:33:39.785Z INFO Core1: Reading device non-volatile memory. This may take a few seconds. 2021-04-13T09:33:41.191Z INFO Core1: UICR has been read. Click read button to read full non-volatile memory. 2021-04-13T09:34:14.328Z INFO Using nrfjprog to communicate with target 2021-04-13T09:34:15.445Z INFO Using J-Link Software version 6.88 2021-04-13T09:34:16.586Z INFO Segger serial: 960125438 2021-04-13T09:34:16.586Z INFO Segger speed: 2000 kHz 2021-04-13T09:34:16.586Z INFO Segger version: J-Link OB-K22-NordicSemi compiled Jan 21 2020 17:33:01 2021-04-13T09:34:16.587Z INFO Core probed: 960125438 2021-04-13T09:34:16.587Z INFO Core RAM: 512KiB 2021-04-13T09:34:16.587Z INFO Core ROM: 1024KiB in pages of 4KiB 2021-04-13T09:34:16.841Z INFO Model: NRF5340_xxAA_ENGA. 2021-04-13T09:34:19.342Z INFO Segger serial: 960125438 2021-04-13T09:34:19.342Z INFO Segger speed: 2000 kHz 2021-04-13T09:34:19.343Z INFO Segger version: J-Link OB-K22-NordicSemi compiled Jan 21 2020 17:33:01 2021-04-13T09:34:19.343Z INFO Core probed: 960125438:1 2021-04-13T09:34:19.343Z INFO Core RAM: 64KiB 2021-04-13T09:34:19.344Z INFO Core ROM: 256KiB in pages of 2KiB 2021-04-13T09:34:20.813Z INFO Core0: Reading device non-volatile memory. This may take a few seconds. 2021-04-13T09:34:31.121Z INFO Core0: Non-volatile memory has been read. 5 non-empty memory blocks identified 2021-04-13T09:34:31.239Z INFO Core1: Reading device non-volatile memory. This may take a few seconds. 2021-04-13T09:34:35.072Z INFO Core1: Non-volatile memory has been read. 2 non-empty memory blocks identified 2021-04-13T09:34:50.828Z INFO Parsing HEX file: C:\Users\kover\ncs\v1.5.0\zephyr\samples\bluetooth\hci_rpmsg\build_nrf5340pdk_nrf5340_cpunet\zephyr\zephyr.hex 2021-04-13T09:34:50.857Z INFO File was last modified at 4/13/2021, 4:54:53 AM 2021-04-13T09:38:26.607Z INFO Does not need to be reloaded: C:\Users\kover\ncs\v1.5.0\zephyr\samples\bluetooth\hci_rpmsg\build_nrf5340pdk_nrf5340_cpunet\zephyr\zephyr.hex 2021-04-13T09:38:26.608Z INFO Writing procedure starts for core0 2021-04-13T09:38:26.626Z INFO Writing procedure starts for core1 2021-04-13T09:38:43.168Z INFO Write procedure finished 2021-04-13T09:38:43.176Z INFO Using nrfjprog to communicate with target 2021-04-13T09:38:44.268Z INFO Using J-Link Software version 6.88 2021-04-13T09:38:45.390Z INFO Segger serial: 960125438 2021-04-13T09:38:45.390Z INFO Segger speed: 2000 kHz 2021-04-13T09:38:45.391Z INFO Segger version: J-Link OB-K22-NordicSemi compiled Jan 21 2020 17:33:01 2021-04-13T09:38:45.391Z INFO Core probed: 960125438 2021-04-13T09:38:45.391Z INFO Core RAM: 512KiB 2021-04-13T09:38:45.392Z INFO Core ROM: 1024KiB in pages of 4KiB 2021-04-13T09:38:45.649Z INFO Model: NRF5340_xxAA_ENGA. 2021-04-13T09:38:47.955Z INFO Segger serial: 960125438 2021-04-13T09:38:47.955Z INFO Segger speed: 2000 kHz 2021-04-13T09:38:47.955Z INFO Segger version: J-Link OB-K22-NordicSemi compiled Jan 21 2020 17:33:01 2021-04-13T09:38:47.956Z INFO Core probed: 960125438:1 2021-04-13T09:38:47.956Z INFO Core RAM: 64KiB 2021-04-13T09:38:47.956Z INFO Core ROM: 256KiB in pages of 2KiB 2021-04-13T09:38:49.344Z INFO Core0: Reading device non-volatile memory. This may take a few seconds. 2021-04-13T09:38:50.598Z INFO Core0: UICR has been read. Click read button to read full non-volatile memory. 2021-04-13T09:38:50.715Z INFO Core1: Reading device non-volatile memory. This may take a few seconds. 2021-04-13T09:38:52.192Z INFO Core1: UICR has been read. Click read button to read full non-volatile memory. 2021-04-13T09:39:13.465Z INFO Using nrfjprog to communicate with target 2021-04-13T09:39:14.608Z INFO Using J-Link Software version 6.88 2021-04-13T09:39:15.671Z INFO Segger serial: 960125438 2021-04-13T09:39:15.671Z INFO Segger speed: 2000 kHz 2021-04-13T09:39:15.671Z INFO Segger version: J-Link OB-K22-NordicSemi compiled Jan 21 2020 17:33:01 2021-04-13T09:39:15.674Z INFO Core probed: 960125438 2021-04-13T09:39:15.674Z INFO Core RAM: 512KiB 2021-04-13T09:39:15.674Z INFO Core ROM: 1024KiB in pages of 4KiB 2021-04-13T09:39:15.928Z INFO Model: NRF5340_xxAA_ENGA. 2021-04-13T09:39:18.300Z INFO Segger serial: 960125438 2021-04-13T09:39:18.300Z INFO Segger speed: 2000 kHz 2021-04-13T09:39:18.300Z INFO Segger version: J-Link OB-K22-NordicSemi compiled Jan 21 2020 17:33:01 2021-04-13T09:39:18.301Z INFO Core probed: 960125438:1 2021-04-13T09:39:18.301Z INFO Core RAM: 64KiB 2021-04-13T09:39:18.301Z INFO Core ROM: 256KiB in pages of 2KiB 2021-04-13T09:39:19.752Z INFO Core0: Reading device non-volatile memory. This may take a few seconds. 2021-04-13T09:39:30.097Z INFO Core0: Non-volatile memory has been read. 5 non-empty memory blocks identified 2021-04-13T09:39:30.219Z INFO Core1: Reading device non-volatile memory. This may take a few seconds. 2021-04-13T09:39:33.960Z INFO Core1: Non-volatile memory has been read. 2 non-empty memory blocks identified
Connecting �J-Link� using �USB� Connecting to target using SWD Loaded C:/Users/kover/ncs/v1.5.0/toolchain/segger_embedded_studio/bin/JLink_x64.dll Firmware Version: J-Link OB-K22-NordicSemi compiled Jan 21 2020 17:33:01 DLL Version: 6.94a Hardware Version: V1.00 Target Voltage: 3.300 Device "NRF5340_XXAA_NET" selected. ConfigTargetSettings() start ConfigTargetSettings() end InitTarget() start InitTarget() end Found SW-DP with ID 0x6BA02477 DPIDR: 0x6BA02477 AP map detection skipped. Manually configured AP map found. AP[0]: AHB-AP (IDR: Not set) AP[1]: AHB-AP (IDR: Not set) AP[2]: MEM-AP (IDR: Not set) AP[3]: MEM-AP (IDR: Not set) AP[1]: Core found AP[1]: AHB-AP ROM base: 0xE00FF000 CPUID register: 0x410FD214. Implementer code: 0x41 (ARM) Found Cortex-M33 r0p4, Little endian. FPUnit: 8 code (BP) slots and 0 literal slots Security extension: not implemented CoreSight components: ROMTbl[0] @ E00FF000 ROMTbl[0][0]: E000E000, CID: B105900D, PID: 000BBD21 Cortex-M33 ROMTbl[0][1]: E0001000, CID: B105900D, PID: 000BBD21 DWT ROMTbl[0][2]: E0002000, CID: B105900D, PID: 000BBD21 FPB ROMTbl[0][6]: E0042000, CID: B105900D, PID: 000BBD21 CSS600-CTI Preparing target for download Executing Reset script TargetInterface.resetAndStop() ResetTarget() start ResetTarget() end Downloading �zephyr.elf� to J-Link Programming 174.5 KB of addresses 01000000 � 0102ba23 Programming 1.3 KB of addresses 0102ba24 � 0102bfbb T-bit of XPSR is 0 but should be 1. Changed to 1. Timeout while preparing target, RAMCode did not respond in time. (PC = 0x00000000, CPSR = 0x00000000, LR = 0x61000003)! Failed to prepare RAMCode using RAM Failed to download application. Generic error. Please check J-Link and target connection. Illegal value 0x21009F90 written to register 67 (PSP_NS) ignored
[00:00:00.007,110] [0m<inf> fs_nvs: 2 Sectors of 4096 bytes[0m [00:00:00.007,141] [0m<inf> fs_nvs: alloc wra: 0, fd8[0m [00:00:00.007,141] [0m<inf> fs_nvs: data wra: 0, 1c[0m [00:00:00.034,576] [1;33m<wrn> bt_hci_core: ECC HCI commands not available[0m [00:00:00.034,606] [0m<inf> bt_hci_core: No ID address. App must call settings_load()[0m [00:00:00.034,606] [0m<inf> peripheral_uart: Bluetooth initialized
