After configured internal low frequency clock source,advertising stop but saadc still working
The program flow of the slave is to sample the analog signal source through the saadc and then send it to the host through the nus.
When debugging on nrf52dk, configure the chip to xtal mode and the program can run smoothly. But when the chip is configured as a 32.768k internal low-frequency clock source RC, after each reset, the broadcast signal appears for a while and disappears, but the saadc sampling continues to run. Why?
The strange thing is that the first run after programming the program is normal.
  • Hi
    Ok, that seems to be correct then. It seems like there might e some issues with the memory configuration on your application, and that you need to increase the allocated amount of RAM/Flash memory for the SoftDevice in your application.
    Please check out our Adjustment of RAM and Flash memory guide here explaining how to do so. As to what it should be set as, this is something the IDE generally reports back once you build and flash the program onto your device.
    Simon
    I have dealed with my problem. Thanks for helping me.But I also want to know the reason for the failure in non-blocking mode. Is that any bug in my program or I do anything wrong?
    Best regards.
  • Hi
    Glad to hear you've solved your problem. If you upload your whole main.c file, we can help you find out what exactly causes the non-blocking mode failures, as we're not able to see what's causing this by the snippets you've uploaded as of yet.
    Simon
    I am ashamed that my script is very messy. and hope you can understand.
     * Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_uart_over_ble_main main.c
     * @ingroup  ble_sdk_app_nus_eval
     * @brief    UART over BLE application main file.
     * This file contains the source code for a sample application that uses the Nordic UART service.
     * This application uses the @ref srvlib_conn_params module.
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_delay.h"
    #include "bsp_btn_ble.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_drv_saadc.h"
    #include "nrfx_saadc.h"
    #include "nrf_queue.h"
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME                     "zgs-nus-test"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    #define SAMPLES_IN_BUFFER         			1																					/**< adc buffer size*/
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static nrf_saadc_value_t     m_buffer_pool[2][SAMPLES_IN_BUFFER];											/**<adc sampling value.*/
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    typedef union
        float 	value;
        uint8_t data[4];
    }U_IntData;
    ** custom code
    #define SAADC_BLOCKING
    #define APP_QUEUE
    //#define CONN_INTERVAL_OPTIMIZE
    //#define EVT_LEN_EXT_ON
    //#define DLE_ON
    #ifdef CONN_INTERVAL_OPTIMIZE
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(8, UNIT_1_25_MS)
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(12, UNIT_1_25_MS)
    void ble_data_send_with_queue(void);
    typedef struct {
        uint8_t * p_data;
        uint16_t length;
    } buffer_t;
    NRF_QUEUE_DEF(buffer_t, m_buf_queue, 60, NRF_QUEUE_MODE_NO_OVERFLOW);
    APP_TIMER_DEF(m_timer);
    //APP_TIMER_DEF(m_timer_speed);
    uint8_t m_data_array[27];//6300
    uint32_t m_len_sent;
    uint32_t m_cnt_10ms;
    static uint32_t m_adc_count=0;
    bool cccd_flag= false;
    uint16_t  sample_ave;
    int  sample_ave_buf[8000];
    static bool m_saadc_calibrate= false;
    static int buf_i;
    static uint8_t uart_send_buf[4];
    //static bool m_flag_calibrate= false;
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    void uint_char(uint16_t l,uint8_t *s )
    		*(s+1) = l>>8;
        *(s+2) = l;
    void float_char(float f,uint8_t *s)
     unsigned char *p;
     p = (unsigned char *)&f;
        *s = *p;
        *(s+1) = *(p+1);
        *(s+2) = *(p+2);
        *(s+3) = *(p+3);
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
            uint32_t err_code;
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
    void adc_calibrate(void)
        ret_code_t err_code =nrf_drv_saadc_calibrate_offset();
        while (nrf_drv_saadc_is_busy());
    		NRF_LOG_INFO("SAADC calibrated.");
    		//err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);             //Set buffer so the SAADC can write to it again.
        //APP_ERROR_CHECK(err_code);
        //err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);             //Need to setup both buffers, as they were both removed with the call to nrf_drv_saadc_abort before calibration.
    static void adc_timer_handler(void * p_context)
    		ret_code_t err_code;
    		NRF_LOG_INFO("SAADC loop.");
    		//err_code = nrf_drv_saadc_sample();
    		err_code = nrf_drv_saadc_sample_convert(0,m_buffer_pool[0]);;
    		/** blocking mode code**/
    			NRF_LOG_INFO ("%d evt_done",m_adc_count);
          if(m_adc_count%12000==0)
    				m_saadc_calibrate = true;                                           // Set flag to trigger calibration in main context when SAADC is stopped
    			sample_ave=(uint16_t)((int)m_buffer_pool[0]*3.6/1024*100);
    			NRF_LOG_INFO("result:%d",sample_ave);
    			uart_send_buf[0]=0xFF;
    			uart_send_buf[3]=0xAF;
    			uint_char(sample_ave,uart_send_buf);
    			//uart_data.value=sample_ave;
    			//float_char(sample_ave,uart_send_buf);
          NRF_LOG_DEBUG("sending data from saadc. Writing data on UART.");
          NRF_LOG_HEXDUMP_DEBUG(uart_send_buf,4);
            for (uint32_t i = 0; i < 4; i++)
                do
    								err_code = app_uart_put(uart_send_buf[i]);
                        NRF_LOG_ERROR("Failed receiving adc message. Error 0x%x. ", err_code);
    				//while (app_uart_put('\n') == NRF_ERROR_BUSY);
    			if (buf_i<8000)
    			sample_ave_buf[buf_i]=(int) (sample_ave*1000);
    			NRF_LOG_DEBUG("%p,%p",&sample_ave_buf[0],&sample_ave_buf[7999]);
    			buf_i++;
    			m_adc_count++;
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= m_ble_nus_max_data_len))
                    if (index > 1)
                        do
                        } while (err_code == NRF_ERROR_RESOURCES);
                    index = 0;
            case APP_UART_FIFO_ERROR:
        APP_ERROR_HANDLER(nrf_error);
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected. conn_handle: 0x%x",p_gap_evt->conn_handle);
                NRF_LOG_INFO("Disconnected. conn_handle: 0x%x, reason: 0x%x",
                             p_gap_evt->conn_handle,
                             p_gap_evt->params.disconnected.reason);
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
    static void log_init(void)
            nrf_pwr_mgmt_run();
    void saadc_test()
    	err_code	=	app_timer_create(&m_timer,APP_TIMER_MODE_REPEATED,adc_timer_handler);
    	err_code	=	app_timer_start(m_timer, APP_TIMER_TICKS(5),NULL);
    	NRF_LOG_INFO("app_timer_start erecode==%x",err_code);
    		//U_IntData uart_data;
    		uint16_t sample_sum=0;
    			for(uint8_t i = 0 ; i < SAMPLES_IN_BUFFER ; i++)
    				sample_sum+= abs(p_event->data.done.p_buffer[i]);
    				NRF_LOG_INFO ("%d /n",p_event->data.done.p_buffer[i]);
    			sample_ave=(uint16_t)(sample_sum/(int)(SAMPLES_IN_BUFFER)*3.6/1024*100);
                do
    			if (buf_i<8000)
    			buf_i++;
    			if(m_saadc_calibrate == false)
                //err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);             //Set buffer so the SAADC can write to it again.
    			m_adc_count++;
    		else if (p_event->type == NRF_DRV_SAADC_EVT_CALIBRATEDONE)
            NRF_LOG_INFO("SAADC calibration complete ! \r\n");                                              //Print on UART
    void BLE_saadc_init(void)
    			nrf_drv_saadc_config_t saadc_config;
    			saadc_config.low_power_mode = true;                                                   //Enable low power mode.
    			saadc_config.resolution = NRF_SAADC_RESOLUTION_10BIT;                                 //Set SAADC resolution to 12-bit. This will make the SAADC output values from 0 (when input voltage is 0V) to 2^12=4096 (when input voltage is 3.6V for channel gain setting of 1/6).
    			saadc_config.oversample = NRF_SAADC_OVERSAMPLE_2X;                                           //Set oversample to 4x. This will make the SAADC output a single averaged value when the SAMPLE task is triggered 4 times.
    			saadc_config.interrupt_priority = APP_IRQ_PRIORITY_LOW;
    			nrf_saadc_channel_config_t channel_config 	=
    			//NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_DIFFERENTIAL(NRF_SAADC_INPUT_AIN1,NRF_SAADC_INPUT_AIN2);
    			NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN1);
          channel_config.burst =  NRF_SAADC_BURST_ENABLED;                                   //Configure burst mode for channel 0. Burst is useful together with oversampling. When triggering the SAMPLE task in burst mode, the SAADC will sample "Oversample" number of times as fast as it can and then output a single averaged value to the RAM buffer. If burst mode is not enabled, the SAMPLE task needs to be triggered "Oversample" number of times to output a single averaged value to the RAM buffer.
    			channel_config.gain 			= NRF_SAADC_GAIN1_6;
    			//channel_config.reference	=	SAADC_CH_CONFIG_REFSEL_VDD1_4;
    		  //channel_config.resistor_p = NRF_SAADC_RESISTOR_DISABLED;                              //Disable pullup resistor on the input pin
    			//channel_config.resistor_n = NRF_SAADC_RESISTOR_DISABLED;
    			err_code = nrf_drv_saadc_init(&saadc_config, saadc_callback);    //&saadc_config
    			err_code = nrf_drv_saadc_channel_init(0, &channel_config);
    #ifndef  SAADC_BLOCKING
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
    /**@brief Application main function.
        // Initialize.
    		uart_init();
        log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
    		gap_params_init();
    		gatt_init();
    		services_init();
    	  advertising_init();
        conn_params_init();
    		NRF_LOG_INFO("Debug logging for advertising started.");
    		advertising_start();
    		nrf_delay_ms(1000);
    		BLE_saadc_init();
        // Start execution.
        NRF_LOG_INFO("Debug logging for adc over RTT started.");
    	  nrf_delay_ms(500);
        saadc_test();
        // Enter main loop.
        for (;;)
    				if(m_saadc_calibrate == true)
                nrf_drv_saadc_abort();                                  // Abort all ongoing conversions. Calibration cannot be run if SAADC is busy
                adc_calibrate();
                m_saadc_calibrate = false;
    				while(NRF_LOG_PROCESS() != NRF_SUCCESS);
            idle_state_handle();
    Thank you.
  • Hello Zaki,
    Simon has been called away on another task, so I will be taking over this ticket.
    Looking at the code, I do not understand what you are trying to achieve with the saadc_test's adc_timer_handler function. Could you elaborate on this?
    I see that you have commented out a call to nrf_drv_saadc_sample, and replaced it with the blocking call to nrf_drv_sample_convert - is this how you change between blocking an non-blocking version?
    The nrf_drv_saadc_sample function will trigger a sampling, but it will not be returned by the function, so this would not work with the rest of your test adc_timer function.
    In the application you are developing (in the non-test case), how would you like the saadc's sampling to be triggered? Do you intend for it to be triggered periodically, or when a certain other event happens, or only when a certain block of your application code is executed (whenever that may be)?
    If you do not intend to keep the adc_timer function from your saadc_test function in the actual application, I think we should focus our debugging of the non-blocking sampling issue on what is happening in the saadc event handler instead, and maybe exclude this test all together for the time being.
    No need to be ashamed - recognizing that something is less than ideal is a good first step to making it better! :)
    I notice in the code you have provided that you use a lot of magic numbers. I would advice against this, as it is generally not a good practice. Instead, you should create defines for each such number you need to use, this will increase the readability and the maintainability of you code drastically. For example, if somebody else ever have to read it (or yourself in 6 months), it will be a lot easier to understand why you are doing the things you do, and it will also be easier to change certain things later, if the development continues.
    I dont know if it is an artifact of copy-pasting the code, but your indentations are also not always aligned, which reduces readability further. If this is not an artifact of the copy-pasting, I highly recommend that you make sure to align them orderly from now on - this might seem like a nitpicking comment, but all the small improvements quickly add up to some great improving of the code.
    You also keep a lot of commented out code in your code. This reduces readability as well, and should be avoided when possible. Instead, I recommend that you create a separate document with 'scrap code' that you wish to keep for potential use or reference later. Keeping the actual application code clean and simple (and readable) makes for easier development and less time spent debugging and looking through the code.
    Looking forward to resolving this issue together!
    Karl
