After configured internal low frequency clock source,advertising stop but saadc still working
The program flow of the slave is to sample the analog signal source through the saadc and then send it to the host through the nus.
When debugging on nrf52dk, configure the chip to xtal mode and the program can run smoothly. But when the chip is configured as a 32.768k internal low-frequency clock source RC, after each reset, the broadcast signal appears for a while and disappears, but the saadc sampling continues to run. Why?
The strange thing is that the first run after programming the program is normal.
  • Thank you for your advice. And I have found many deficiencies in me, and I will try to improve them next.
    Because in the original code, I used non-blocking sampling mode. Under Simonr's suggestion, I changed to blocking mode and commented out the original non-blocking mode code, and did not use the code for switching mode.
    As for adc_timer_handle function,
    In blocking mode, I use it to start adc sampling periodically, and send the sampling results to the host through the nus after the sampling is completed.
    In non-blocking mode, this piece of code takes effect when the adc sampling generates the NRF_DRV_SAADC_EVT_DONE callback event. At this time, adc_timer is only used to periodically trigger sampling in non-blocking mode.
    No problem at all, I am happy to hear that you found my comments helpful and glad that you want to make the improvements! :)
    Thank you for clarifying on this - this is what I thought you were doing, but I had to ask to be sure. Especially some of the commented out code made me unsure, but now it is much clearer!
    So then, let us continue with the debugging of the non-blocking mode. You may then remove the timer and timer handler entirely while we do so, as suggested in my previous comment.
    If you want the saadc sampling to happen periodically, without requiring CPU interaction, then I suggest that you change your non-blocking implementation to match that of the SAADC example from the SDK. The SAADC example shows how to implement the sample task triggering by a timer through PPI, which does not require the CPU to intervene for each sampling. In your current code, I cant see how you actually trigger the periodic samplings, since you do not intend to keep the saadc timer callback.
    Could you share with me you loggers output, when you run your non-blocking saadc sampling code?
    If you make the improvements to the code, feel free to share the code here again so I may take a look at the improved version! :)
    Looking forward to resolving this issue together!
    Karl
  • Hi, I am sorry for replying to you too late.
    I have improved my code, and used ppi to trigger saadc sampling.But I meet new problem.The log as follows.
    00> <debug> nrf_sdh: State request: 0x00000000
    00> <debug> nrf_sdh: State change: 0x00000000
    00> <debug> nrf_sdh: State change: 0x00000001
    00> <debug> nrf_sdh_ble: RAM starts at 0x20002A00
    00> <info> app: Debug logging for advertising started.
    00> <error> app: SOFTDEVICE: INVALID MEMORY ACCESS
    And the new code as follows:
     * Copyright (c) 2014 - 2019, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_uart_over_ble_main main.c
     * @ingroup  ble_sdk_app_nus_eval
     * @brief    UART over BLE application main file.
     * This file contains the source code for a sample application that uses the Nordic UART service.
     * This application uses the @ref srvlib_conn_params module.
    #include <stdbool.h>
    #include <stdint.h>
    #include <stdio.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "app_error.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_delay.h"
    #include "boards.h"
    #include "bsp_btn_ble.h"
    #include "nrf_drv_timer.h"
    #include "nrf_drv_saadc.h"
    #include "nrf_drv_ppi.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrfx_saadc.h"
    #include "nrf_queue.h"
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME                     "zgs-nus-test"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    #define SAMPLES_IN_BUFFER         			3																						/**< adc buffer size*/
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static const nrf_drv_timer_t m_timer = NRF_DRV_TIMER_INSTANCE(0);
    static nrf_ppi_channel_t     m_ppi_channel;
    static uint32_t              m_adc_evt_counter;
    static nrf_saadc_value_t     m_buffer_pool[2][SAMPLES_IN_BUFFER];										/**<adc sampling value.*/
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    static bool m_saadc_calibrate= false;																								/**< Flag indicating that saadc is calibrating */
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
            uint32_t err_code;
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= m_ble_nus_max_data_len))
                    if (index > 1)
                        do
                        } while (err_code == NRF_ERROR_RESOURCES);
                    index = 0;
            case APP_UART_FIFO_ERROR:
        APP_ERROR_HANDLER(nrf_error);
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected. conn_handle: 0x%x",p_gap_evt->conn_handle);
                NRF_LOG_INFO("Disconnected. conn_handle: 0x%x, reason: 0x%x",
                             p_gap_evt->conn_handle,
                             p_gap_evt->params.disconnected.reason);
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        ret_code_t err_code;
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
    static void log_init(void)
            nrf_pwr_mgmt_run();
    void adc_timer_handler(nrf_timer_event_t event_type, void * p_context)
    void adc_calibrate(void)
        ret_code_t err_code =nrf_drv_saadc_calibrate_offset();
        while (nrf_drv_saadc_is_busy());
    //Hexadecimal to character
    uint8_t HexToChar(uint8_t temp)
        uint8_t dst;
        if (temp < 10)
            dst = temp + '0';
        }else
            dst = temp -10 +'A';
        return dst;
    //Convert hexadecimal array to string array
    void HexToString(uint8_t *pbDest, uint8_t *pbSrc, uint16_t nLen)
        uint16_t i;
        for (i=0; i<nLen; i++)
            pbDest[i*2] = HexToChar(pbSrc[i] / 16);
            pbDest[i*2+1] = HexToChar(pbSrc[i] % 16);
    		uint8_t adc_result[SAMPLES_IN_BUFFER*2],adc_string[SAMPLES_IN_BUFFER*4];
    			NRF_LOG_INFO ("%d evt_done",m_adc_evt_counter);
          if(m_adc_evt_counter%12000==0)
    				m_saadc_calibrate = true;                                           																		// Set flag to trigger calibration in main context
    			for(uint8_t i = 0 ;i<p_event->data.done.size;i++)
    				adc_result[(i*2)] = p_event->data.done.p_buffer[i] >> 8;
            adc_result[(i*2)+1] = p_event->data.done.p_buffer[i];
    			HexToString(adc_string,adc_result,SAMPLES_IN_BUFFER*2);
    			if(SAMPLES_IN_BUFFER <= 5)
    						uint16_t length = (uint16_t)(SAMPLES_IN_BUFFER*4);
    					  ble_nus_data_send(&m_nus, &adc_string[0], &length, m_conn_handle);																	  // send data through nus.
    			if(m_saadc_calibrate == false)
                err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);            //Set buffer when saadc is not in calibration state.
    			m_adc_evt_counter++;
    		else if (p_event->type == NRF_DRV_SAADC_EVT_CALIBRATEDONE)
            NRF_LOG_INFO("SAADC calibration complete ! \r\n");
    				err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);             					 		//Set buffer after calibration done.
    				err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);             	 				 	 //Need to setup both buffers, as they were both removed with the call to nrf_drv_saadc_abort before calibration.
    void BLE_saadc_init(void)
    			nrf_drv_saadc_config_t saadc_config;
    			saadc_config.low_power_mode = true;
    			saadc_config.resolution = NRF_SAADC_RESOLUTION_10BIT;
    			saadc_config.oversample = NRF_SAADC_OVERSAMPLE_2X;
    			saadc_config.interrupt_priority = APP_IRQ_PRIORITY_LOW;
    			nrf_saadc_channel_config_t channel_config 	=
    			NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE(NRF_SAADC_INPUT_AIN1);
          channel_config.burst =  NRF_SAADC_BURST_ENABLED;
    			channel_config.gain 			= NRF_SAADC_GAIN1_6;
    			err_code = nrf_drv_saadc_init(&saadc_config, saadc_callback);
    			err_code = nrf_drv_saadc_channel_init(0, &channel_config);
    #ifndef  SAADC_BLOCKING
        err_code = nrf_drv_timer_init(&m_timer, &timer_cfg, adc_timer_handler);
        /* setup m_timer for compare event every 400ms */
        uint32_t ticks = nrf_drv_timer_ms_to_ticks(&m_timer, 400);
                                       NRF_TIMER_CC_CHANNEL0,
                                       ticks,
                                       NRF_TIMER_SHORT_COMPARE0_CLEAR_MASK,
                                       false);
        uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer,
        NRF_TIMER_CC_CHANNEL0);
                                              timer_compare_event_addr,
                                              saadc_sample_task_addr);
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
    /**@brief Application main function.
        // Initialize.
    		uart_init();
        log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
    		gap_params_init();
    		gatt_init();
    		services_init();
    	  advertising_init();
        conn_params_init();
    		NRF_LOG_INFO("Debug logging for advertising started.");
    		advertising_start();
    		nrf_delay_ms(500);
    		BLE_saadc_init();
    		saadc_sampling_event_init();
        // Start execution.
        NRF_LOG_INFO("Debug logging for adc over RTT started.");
        // Enter main loop.
        for (;;)
    				if(m_saadc_calibrate == true)
                nrf_drv_saadc_abort();                                  // Abort all ongoing conversions. Calibration cannot be run if SAADC is busy
                adc_calibrate();
                m_saadc_calibrate = false;
    				while(NRF_LOG_PROCESS() != NRF_SUCCESS);
            idle_state_handle();
    Thank you.
  • Hello again,
    No problem at all - we'll continue this whenever you have the time.
    Great work, I am happy to see that! The code looks a lot better already, well done! :)
    In your ble_stack_init function you pass the ram start address 0 to the nrf_sdh_ble_default_cfg_set function - this is not a valid application start address, since the SoftDevice is present. Please change this to the value suggested in the log, RAM starts at 0x2002A00, and see if this resolves the error.
    Karl
  • Hi, I changed my code as follows,but it didn't work. And the uart log never changed.
        uint32_t ram_start = 0x20002A00;
    And the option for target setup in keil as follows:
    log as follows:
    (it seems that the main program has reached the step:
    NRF_LOG_INFO("Debug logging for advertising started."); )
    Looking forward to your reply.
