I've created a BT peripheral based on the app_proximity example (SDK 8.0) and added code to implement paring with a static PIN per examples posted here. It works as expected if/when the correct PIN is entered at the client. However (after clearing all the bonds at the peripheral and on an iOS client) attempting to bind using the wrong PIN causes the device manager throw an event 0x14 (DM_EVT_SECURITY_SETUP_COMPLETE) result 0x84 (BLE_GAP_SEC_STATUS_CONFIRM_VALUE) that generates an exception/assert error when checked at the DM event handler. As far as I can tell the event/result doesn't necessarily indicate anything wrong has happened. See error log attached. I can provide additional info if needed. I can't figure why this is an error. Thanks.
