nRF Sniffer intercept ADV, SCAN and CONNECT packages but no data packages
I have a BLE thermometer I want to snif using nRF-Sniffer and Wireshark.
Unfortunately I'm unable to sniff the data, I only see the initial "hand-shake".
Process:
a) I start RF-Sniffer and then Wireshark
b) I initialize pairing between the themometer and an iOS device.
What I see:
Approx. 35 packages are exchanged as the pairing is initialized (screenshot below). Most are ADV packages but there are also some SCAN packages too and then finally a CONNECT package. After that all goes silent.
After the pairing: On the iOS device I can see that the temparature changes up and down as I apply different temperatures on thermometer - i.e. data most be exchanging between the devices. Unfortunately I'm unable to intercepting any of those data packages.
The set-up:
  • nRF51 dongle - PCA10031
  • nRF-Sniffer 1.0.1_1111
  • Wireshark 1.12
The thermometer and the Ios device is placed on a table approx. 15 cm appart with the nRF51 dongle placed in the middle between them
Any suggestiongs would be highly appreciated...
Note: I have also tested another BLE device (i.e. a heart rate monitor) with the same iOS device and same set-up. Here I see a flood of data packages being intercepted. I therefore assume that there is something special about this particular thermometer that I am overlooking. But what might it be?
image description Capture 2 (used at forum).pcapng
  • @Zitter: We did some more investigation on the trace you sent us. The interesting part is that the CONNECT REQ was on channel 38 but there was no advertising packet on channel 38 captured right before that. The way our chip broadcasting (and scanner scanning) by default hopping from channel 37 to 38 and then 39. I suspect that the hopping sequence could be different on Broadcom chip. The sniffer didn't expect the CONNECT REQ in that case (because it hasn't received the advertising packet to perpare for the connect request) so this explain why the connection wasn't followed.
    My suggestion for you is to try changing the channel hopping secquence for scanning. You can do that by pressing "h" in the scaner console. Then you can select the hopping sequence, or can select to scan for just 1 channel. Note that if you scan for 1 channel there is only 33% chance that you can catch a connection. But it worth some tries. I would suggest to try on channel 38.
