BLE board communicate with battery by receiving the command from android
How can i give command from android device to ble board to get the percentage, temperature, or reset or shutdown the device with the help of receiving command from android device
    It sounds to me like you might be looking for the Battery Service.
    You can see an example of how this can be implemented and used in the Proximity BLE peripheral example (or many of the other BLE peripheral examples made for battery powered devices too).
    The Proximity example does not have any implementation of receiving a BLE command to go to sleep, but it does contain the sleep-on-button-press functionality, which you could change to trigger on a particular BLE action or command.
    The BLE peripheral UART example might be a good place to start your development, as this example demonstrates how to send whatever is received over UART to a connected device over BLE, and vice versa. You could then merge the Battery Service and sleep-on-button-press implementation into this example, and have it trigger on a specific command, for example.
    Karl
  • im already working on uART
    but im getting automatic data from battery chip data through ble to my phone
  • i need to get the data when I send command through my phone .but I'm getting only temperature details. not any other details I'm recieving
     * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_uart_over_ble_main main.c
     * @ingroup  ble_sdk_app_nus_eval
     * @brief    UART over BLE application main file.
     * This file contains the source code for a sample application that uses the Nordic UART service.
     * This application uses the @ref srvlib_conn_params module.
    #include "main_header.h"
                                          /* TWI instance ID. */
    #define TWI_INSTANCE_ID     0
    /* Common addresses definition for battery . */
    #define LM75B_ADDR          (0x17U >> 1)
    #define LM75B_REG_TEMP      0x00U
    #define LM75B_REG_CONF      0x01U
    #define LM75B_REG_THYST     0x02U
    #define LM75B_REG_TOS       0x03U
    /* Mode for LM75B. */
    #define NORMAL_MODE 0U
    //#define  NRF_TWI0
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN
             /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    //#define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                    /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    #define SAMPLES_IN_BUFFER               4
    #define SAADC_SAMPLE_RATE		00                                         /**< SAADC sample rate in ms. */
    /* Indicates if operation on TWI has ended. */
    static volatile bool m_xfer_done = false;
    static uint32_t  size_of_battery_percentage=9;
    static uint32_t  battery_value_compared_output;
    static uint32_t  uam_adc_value;
    static uint16_t  m_sample ;
    static uint16_t  reset_compared_value;
    static uint16_t  reset_compared_value_flag;
    static uint16_t  uam_adc_value_flag;
    static uint16_t  battery_value_compared_output_flag;
    static uint16_t  uam_i2c_value;
    static uint32_t  flag_increment_batt=1;
    static bool      test10Percent = 1;
    static uint32_t  set_communication_i2c;
    /* TWI instance. */
    static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
    static uint32_t android_data_send=0;
    static uint32_t android_data_open;
    static uint32_t android_data_close;
    /* Buffer for samples read from temperature sensor. */
    static uint32_t below_ten;
    static const nrf_drv_timer_t   m_timer = NRF_DRV_TIMER_INSTANCE(0);
    static nrf_saadc_value_t       m_buffer_pool[2][SAMPLES_IN_BUFFER];
    static nrf_ppi_channel_t       m_ppi_channel;
    static uint32_t                m_adc_evt_counter;
    static uint32_t     data;
    static uint32_t      cmd;
    static uint32_t      buf;
    static uint32_t     disp;
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
            uint32_t err_code;
           // uint32_t err_code1=1;
            nrf_delay_ms(UAM_DELAY);
             cmd=atoi(p_evt->params.rx_data.p_data);
             buf=cmd;
             uam_android_read_communication();        // read_sensor_data();
           reset_compared_value=strcmp(p_evt->params.rx_data.p_data,"reset");
             if(reset_compared_value==0)
               RESET_RFID();
               battery_value_compared_output_flag=1;
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        //cp_init.next_conn_params_update_delay  = NEXT_CONN_PARAMS_UPDATE_DELAY;
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
          case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
               // NRF_LOG_INFO("Connected");
                //NRF_LOG_INFO("Disconnected");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
            case BLE_GATTC_EVT_TIMEOUT:
           case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        ret_code_t err_code;
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            //NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
       NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
             case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') || (index >= (m_ble_nus_max_data_len)))
                    do
                        if ( (err_code != NRF_ERROR_INVALID_STATE) && (err_code != NRF_ERROR_BUSY) &&
                             (err_code != NRF_ERROR_NOT_FOUND) )
                    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
    #if defined (UART_PRESENT)
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
        UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
        nrf_pwr_mgmt_run();
     * @brief Function for handling data from temperature sensor.
     * @param[in] temp          Temperature in Celsius degrees read from sensor.
    __STATIC_INLINE void data_handler(int temp)
     NRF_LOG_INFO("Temperature: %d Celsius degrees.", data);//uam_i2c_value
     uam_i2c_value =temp;
     // uint32_t data;
     data =(short)temp;
     //uint32_t       err_code;
     * @brief TWI events handler.
    void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
      switch (p_event->type)
          case NRF_DRV_TWI_EVT_DONE:
            if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
             data_handler(m_sample);
             m_xfer_done = true;
         m_xfer_done = true;
     * @brief UART initialization.
    void twi_init (void)
        uint32_t define;
        const nrf_drv_twi_config_t twi_lm75b_config = {
           .scl                = ARDUINO_SCL_PIN,
           .sda                = ARDUINO_SDA_PIN,
           .frequency          = NRF_DRV_TWI_FREQ_100K,
           .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
           .clear_bus_init     = false
        err_code = nrf_drv_twi_init(&m_twi, &twi_lm75b_config, twi_handler, NULL);
        nrf_drv_twi_enable(&m_twi);
    * @brief Function for reading data from temperature sensor.
    * Function Name: uam_usb_control
    * Purpose      : To Configure the 12v Input and
    *                to set the OTG pin pull up value to HIGH
    * Input        : None
    * Output       : GPIO OUT for OTG pull HIGH, P0.14
    * Return       : None
    * Requirement No: UAM_REQ_BT_x
    void timer_handler(nrf_timer_event_t event_type, void* p_context)
        uint32_t timer_compare_event_addr = nrf_drv_timer_compare_event_address_get(&m_timer, NRF_TIMER_CC_CHANNEL0);
        uint32_t saadc_sample_event_addr = nrf_drv_saadc_sample_task_get();
        err_code = nrf_drv_ppi_channel_assign(m_ppi_channel, timer_compare_event_addr, saadc_sample_event_addr);
            uint32_t data;
            err_code = nrf_drv_saadc_buffer_convert(p_event->data.done.p_buffer, SAMPLES_IN_BUFFER);
            uam_adc_value=p_event->data.done.p_buffer[2];
            if(uam_adc_value>=400)
              /* flag will set if the adc value above 400 means when charger connected*/
              uam_adc_value_flag=1;
              uam_batt_belowten();
            /* It  checks the battery percentage and it takes the action if it is less than 10 percent*/
            /* it stops the adc peration*/
            uam_stop_adc();
            //Function to perform the gpio opertion
            uam_usb_control(uam_adc_value_flag);
    void saadc_init(void)
        nrf_saadc_channel_config_t channel_config =
        NRF_DRV_SAADC_DEFAULT_CHANNEL_CONFIG_SE( NRF_SAADC_INPUT_AIN6   );//NRF_SAADC_INPUT_VDD//NRF_SAADC_INPUT_AIN6
        channel_config.reference = SAADC_CH_CONFIG_REFSEL_VDD1_4;
        err_code = nrf_drv_saadc_init(NULL, saadc_callback);
        err_code = nrf_drv_saadc_channel_init(0, &channel_config);
        err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[0], SAMPLES_IN_BUFFER);
       err_code = nrf_drv_saadc_buffer_convert(m_buffer_pool[1], SAMPLES_IN_BUFFER);
      * Function Name: uam_start_adc
      * Purpose      : To initiate the adc operation.
      * Input        : None
      * Output       : None
      * Return       : None
       void  uam_batt_belowten()
         //it compares the battery percentage below ten percent and the device is in discharging mode
         if((uam_i2c_value<=10)&&(uam_adc_value>=400))
              //The flag set 0 if the both the condition satisify
              flag_increment_batt=0;
          //if above condition fails below function will exceute
           uam_battery_tenpercent();
    void uam_battery_tenpercent()
           if((uam_i2c_value<=10) && (test10Percent==1))
               flag_increment_batt++;
               if(uam_i2c_value<=10)
                   test10Percent=0;
                  test10Percent=1;
           if(flag_increment_batt==10)
                test10Percent=0;
               battery_value_compared_output_flag=0;
    void  LM75B_set_mode(void)
             uint8_t reg[2] = {1, 0};
             err_code = nrf_drv_twi_tx(&m_twi, LM75B_ADDR, reg, 1, false);
             while (m_xfer_done == false);
            reg[0] =cmd;//Percentage command to the Battery through I2c Communication
    void read_sensor_data()
           char snum[5];
           /* Read 1 byte from the specified address - skip 3 bits dedicated for fractional part of temperature. */
           ret_code_t err_code = nrf_drv_twi_rx(&m_twi, LM75B_ADDR, &m_sample, sizeof(m_sample));
           itoa(data, snum, 10);
                    if((uam_i2c_value>=9)&&(android_data_send==0))
                    if(cmd==8)
                    data*=0.1;
                    data-=273;
                    itoa(data,snum,10);
                    strcat(snum,"'c");
                    ble_nus_data_send(&m_nus, snum, sizeof(snum), m_conn_handle);
                    NRF_LOG_FLUSH();
                    //strcat(snum,".");
                    NRF_LOG_FLUSH();
                    cmd=buf;
                    LM75B_set_mode();
                    read_sensor_data();
                    NRF_LOG_FLUSH();
          //NRF_LOG_FLUSH();
    void battery_set_mode(void)
          if((uam_adc_value<=400)&&(battery_value_compared_output_flag==1))
             uint8_t reg[2] = {0x00,0x0010};
             err_code = nrf_drv_twi_tx(&m_twi, LM75B_ADDR, reg, sizeof(reg), true);
             nrf_delay_ms(2000);
             /* Writing to pointer byte. */
             reg[1] = 0x0010;//Write  the values to the battery to shut down
             err_code = nrf_drv_twi_tx(&m_twi,LM75B_ADDR , &reg, 1, false);
             while (m_xfer_done ==false);
             nrf_delay_ms(8000);
             //SHUTDOWN_BATTERY();
            reg[0] =0x0D;//Percentage command to the Battery through I2c Communication
    void read_battery_data()
           char snum[5];
           itoa(uam_i2c_value, snum, 10);
           if((uam_adc_value>=400)&&(disp>=20))
               /*it concatenate the c with the battery current value while it is charging*/
               strcat(snum,"ch");
               /*It sends the current from battery through i2c communication and it sends  the value to the ble*/
               ble_nus_data_send(&m_nus, snum, 9, m_conn_handle);
               disp=0;
    void uam_start_adc()
           saadc_init();//it initates the adc
           uam_adc_value_flag=0;
      * Function Name: stop_adc
      * Purpose      : To disable the adc operation.
      * Input        : None
      * Output       : None
      * Return       : None
     void uam_stop_adc()
          /*This function stops all ongoing conversions and disables all channels.*/
          nrfx_saadc_uninit();
      * Function Name: start_i2c
      * Purpose      : To establish the i2c connection when
                        the battery above ten percent
      * Input        : None
      * Output       : None
      * Return       : None
    void uam_android_read_communication()
         LM75B_set_mode();
         read_sensor_data();
         NRF_LOG_FLUSH();
    void uam_batt_read_communication()
         battery_set_mode();
         read_battery_data();
         NRF_LOG_FLUSH();
    /**@brief Application main function.
        bool erase_bonds;
        // Initialize.
        uart_init();
        log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        //functions for adc operation
        saadc_sampling_event_init();
        saadc_init();
        advertising_start();
        NRF_LOG_FLUSH();
        twi_init();
        LM75B_set_mode();
        // Enter main loop.
        for (;;)
        	disp++;
            uam_start_adc();
            uam_batt_read_communication();
            // advertising_start();
    By this, do you mean that you would like the peripheral to send the data only when prompted to?
    The way the NUS service works is to transmit data as a notification in the next communication event, as soon as new data has been made available.
    You are only seeing temperature details. Have you verified that you are getting the other measurements into your code? I.e is the current issue to have the measurements successfully sent to the central device, or is it to gather these other measurements entirely?
    Is there anything in particular you would like me to take a look at in your code? It seems you have provided your complete main.c file without any comment on what you would like me to do with it.
    Karl
