nRFgo Studio and IAR Using SEGGER J-Link Question
Hello all,
I'm new to embedded development and could use some help here.
I am currently working on our own board with a nRF51822 chip on it and using SEGGER j-link to program. It took quite a bit of work, but I eventually got it to compile the HRS example onto the board and get it to show up on my phone. During that process, I realized I had to use nRFGo Studio to upload the softdevice.hex file first before I used IAR to add the example code.
I was wondering, how can I use IAR to reduce this two step process to one step so that I don't have to do this for every test board?
Thanks.
  • Hi John,
    Yes, it is possible to load the softdevice directly from IAR. First, I would recommend that you start off with a "nrfjprog -e" to ensure that your device is blank.
    If you go to your IAR project settings
    Options.. -> Debugger
    Then select the "Images" tab, you have the option to download an extra image when entering debug mode.
    You check this option and browse to the selected softdevice .hex location. image description
    Now, when you enter debug mode from IAR, it will load the softdevice .hex as well.
    Cheers, Håkon
  • I see the same issue with EWB 7.30. If there's something present in flash, IAR will erase the sections and flash the softdevice. In this scenario, I see errors sometime, and have to restart the session. Haven't seen a workaround yet, but I recommend checking out their latest EWB version to see if it has improved. Also try to update your Segger drivers to the latest.
