I am working on an application where the device will be in off mode(only timer and BSP initialized in main ) initially and when I long press button_0 for 5 sec the remaining function will initialize and the device start advertising.
My main function:
int main(void){
// off mode
// Initialize.
log_init();
nrf_cal_init();
timers_init();
power_management_init();
scheduler_init();
ble_stack_init();
// Enter main loop.
for (;;)
// ideal state
idle_state_handle();
My Function for handling events from the BSP module.
* @param[out] p_erase_bonds Will be true if the clear bonding button was pressed to wake the application up.
static void buttons_leds_init(bool * p_erase_bonds){
ret_code_t err_code;
bsp_event_t startup_event;
err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
err_code = bsp_event_to_button_action_assign(BSP_BOARD_BUTTON_0, BSP_BUTTON_ACTION_LONG_PUSH, BT0_LONG_PUSH);
void bsp_event_handler(bsp_event_t event){
switch (event)
case BT0_LONG_PUSH:
// advertising mode
gap_params_init();
gatt_init();
db_discovery_init();
services_init();
advertising_init();
peer_manager_init();
conn_params_init();
advertising_start(erase_bonds);
NRF_LOG_INFO("Application started in Advertising Mode.");
Problem: the power consumption in off mode is almost the same as the advertising mode ( after the long button press), equal to almost 0.500mA.
Please let me know which min. functions I needed to initialize in the main function to minimize my power consumption during off mode.
thanks
