peer_manager_pds: Could not initialize flash storage. fds_init() returned 0x860A
When the application is started I get the following error:
<error> peer_manager_pds: Could not initialize flash storage. fds_init() returned 0x860A.
00>
00> <error> peer_manager: pm_init failed because pds_init() returned NRF_ERROR_STORAGE_FULL.
00>
00> <error> app: ERROR 3 [NRF_ERROR_INTERNAL] at C:\Users\Samo\Documents\nRF52_SDK\examples\ble_peripheral\ble_Indu4s_improved3\main.c:2689
00>
00> PC at: 0x0002065B
00>
00> <error> app: End of error report
In my application, I wrote some data in flash. More precisely, I reserved 8kB for my data from 0x2E000 to 0x30000. This is 8kB which means that I have two pages. The first page goes from 0x2E000 to 0x2F000and from 0x2F000 to  0x30000. Because I use the nrf52811 chip (s112) these flash addresses are located at the end of the flash. Now comes the most interesting part. If I erase the flash before peer_manager_init is called then the error does not occur. Due to this fact, I believe that the problem is somehow related to the flash but I do not know what exactly can be the cause of the problem. According to my knowledge the flash addresses above 100kB and not reserved. I will appreciate for help.
err_code = nrf_fstorage_erase(&fstorage, 0x2F000, 1,NULL);
wait_for_flash_ready(&fstorage);
Here is my memory layout. Why such periodicity occurs at the top of flash memory? This periodicity is generated when peer_manager_init() method is called.
  • I observed the following situation. I using flash on the following addresses
    #define FLASH_START_ADD 0x2E000
    #define FLASH_HISTORY_ADD 0x2F000
    #define FLASH_END_ADD 0x2FFFF
    It means that my entire space is 8kB which means that 2 pages are reserved just for arbitrary data. If the write and the read command is executed in the first page address starts at 0x2E000 I do not get any kind of error even the chip is restarted. The error occurs just in case when the writing command is executed on address 0x2F000 ahead. I am wondering why erasing is not necessary after the chip restarts as long as the flash is used just on the first page.
    I do some additional tests. I changed the range of flash to one 4kB which is one page and addresses are the following ones
    #define FLASH_END_ADD  0x2EFFF
    when I check the flash without peer_manager_init it shows that the addresses which I reserved for my data are reserved and this behavior is expected.  If I add peer_manager_init and do not change FLASH_START_ADD and FLASH_END_ADD constants the addresses 0x2F000 and ahead are reserved. I suspect that this reservation id made by peer_manager_init, is it true?  Why these addresses are reserved and who reserved them? As I asked in my previous post, which flash memory is reserved for peer_manager?
    Yes, those id is reserved for the peer manager to store bond information for example. See this and this for more information and Restrictions on keys and IDs doc.
    -Amanda H.
  • Is the following statement really true?
    Record keys should be in the range 0x0001 - 0xBFFF. The value 0x0000 is reserved by the system. The values from 0xC000 to 0xFFFF are reserved for use by the Peer Manager module and can only be used in applications that do not include Peer Manager.
    My program is written based on ble_periperal_template and default FDS settings are used such as:
    FDS_VIRTUAL_PAGES 3
    FDS_VIRTUAL_PAGE_SIZE 1024
    It means that the peer manager will not reserve addresses from 0xC000 to 0xFFFF because this is one page more than it is actually needed. Is my observation correct? If so please let me know what is the starting address in this case? Is it 0xD000 instead of 0xC000?
    The FDS pages are allocated from the end of flash as shown here
    FDS address range on the 52810 is 0x2D 000 - 0x30 000 if the have set FDS_VIRTUAL_PAGES=3
    It sounds like you are writing some other user data that are overlapping with the FDS. You are probably corrupting the filesystem.
    You can use the FDS_VIRTUAL_PAGES_RESERVED option to allocate a free area for the other data.
    -Amanda H.
