peer_manager_pds: Could not initialize flash storage. fds_init() returned 0x860A
When the application is started I get the following error:
<error> peer_manager_pds: Could not initialize flash storage. fds_init() returned 0x860A.
00>
00> <error> peer_manager: pm_init failed because pds_init() returned NRF_ERROR_STORAGE_FULL.
00>
00> <error> app: ERROR 3 [NRF_ERROR_INTERNAL] at C:\Users\Samo\Documents\nRF52_SDK\examples\ble_peripheral\ble_Indu4s_improved3\main.c:2689
00>
00> PC at: 0x0002065B
00>
00> <error> app: End of error report
In my application, I wrote some data in flash. More precisely, I reserved 8kB for my data from 0x2E000 to 0x30000. This is 8kB which means that I have two pages. The first page goes from 0x2E000 to 0x2F000and from 0x2F000 to  0x30000. Because I use the nrf52811 chip (s112) these flash addresses are located at the end of the flash. Now comes the most interesting part. If I erase the flash before peer_manager_init is called then the error does not occur. Due to this fact, I believe that the problem is somehow related to the flash but I do not know what exactly can be the cause of the problem. According to my knowledge the flash addresses above 100kB and not reserved. I will appreciate for help.
err_code = nrf_fstorage_erase(&fstorage, 0x2F000, 1,NULL);
wait_for_flash_ready(&fstorage);
Here is my memory layout. Why such periodicity occurs at the top of flash memory? This periodicity is generated when peer_manager_init() method is called.
    This is expected behavior. You need to provide erased pages for the system to be able to setup. FDS requires fully erased pages, and it will not erase any unknown pages by itself. You can erase the flash pages before flashing the application, or you can use the NVMC driver. When FDS initializes the pages it will use, the pages will be tagged with a "magic word" that FDS recognizes.
    -Amanda H.
  • Thanks for the reply. Every time I load the program the entire flash is erased. Due to this fact, I think that this is not the problem. I am wondering why error NRF_ERROR_STORAGE_FULL is thrown from pm_init method. If the problem lies in the fact that the pages are not erased then fstorage_init should throw an error and not peer_manager_init(). Which addresses the peer_manager occupies for storing the data in the flash? Thanks for your help in advance.
    How do you erase the entire flash?
    Do you run 'nrfjprog --eraseall' command on your board or Erasing the kit before flashing the application?
    The log indicates the error comes from fds_init(). Error 34314 (0x860A) means FDS_ERR_NO_PAGES. Does pages_init() return NO_SWAP and fds_init() quit with FDS_ERR_NO_PAGES? If so, it seem you didn't erase the page fully at first, and the nrf_fstorage_erase did that later.
     -Amanda H.
  • The chip is erased with the help of Erasing the kit.  I have one concern regarding erasing the chip. Please let me know if I have to erase the chip just the first time or every time it is restarted. At the moment, I erase the chip just the first time (this is actually done with the help of Erasing the kit and in code) and then I start adding some data in flash.  if I reset the chip I get the mentioned problem. Please note, when the module is reset the erase function is not called just read the data from flash.  Is it ok or I have to ease the flash every time it is reset of course after the data are read from flash.
    Do you see any errors?
    Reset will not erase the device/flash. If you initial FDS after the reset, it might be better to erase the flash every time.
    -Amanda H.
