How to scan only advertising name??
i used nrf52840 and scanning.
'A'(nrf52) is scanning and 'B'(nrf52) is advertising.. (with 2 products)
How do I find it by name 'B'?
i couldn't get NRF_BLE_SCAN_EVT_FILTER_MATCH...
i get NRF_BLE_SCAN_EVT_NOT_FOUND...
thankyou..
/**< Scan parameters requested for scanning and connection. */
static ble_gap_scan_params_t const m_scan_param =
    .active        = 0x01,
    .interval      = NRF_BLE_SCAN_SCAN_INTERVAL,
    .window        = NRF_BLE_SCAN_SCAN_WINDOW,
    .filter_policy = BLE_GAP_SCAN_FP_ACCEPT_ALL, //BLE_GAP_SCAN_FP_WHITELIST,BLE_GAP_SCAN_FP_ACCEPT_ALL
    .timeout       = SCAN_DURATION_WITELIST,
    .scan_phys     = BLE_GAP_PHY_1MBPS,
/**@brief Function for handling Scanning Module events.
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
    ret_code_t err_code;
    data_t   adv_data;
    // Initialize advertisement report for parsing
    adv_data.p_data   = (uint8_t *) p_scan_evt->params.p_not_found->data.p_data;
    adv_data.data_len = p_scan_evt->params.p_not_found->data.len;
    uint8_t         ad_types[N_AD_TYPES];
    uint8_t       * p_parsed_uuid;
    uint16_t        parsed_uuid_len = adv_data.data_len;
    uint8_t         uuid_buffer[UUID128_SIZE];
    uint16_t parsed_name_len;
    uint8_t * p_parsed_name;
    uint16_t data_offset = 0;
    uint16_t target_name_len= strlen(m_target_periph_name);
    ble_gap_evt_adv_report_t const * adv_report = p_scan_evt->params.p_not_found;
    switch(p_scan_evt->scan_evt_id)
        case NRF_BLE_SCAN_EVT_FILTER_MATCH:
            DEBUG_PRINTF("___FILTER_MATCH!\r\n");
        } break;
        case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
            err_code = p_scan_evt->params.connecting_err.err_code;
        } break;
        case NRF_BLE_SCAN_EVT_NOT_FOUND:
            //DEBUG_PRINTF("___NOT FOUND!\r\n");
            #if 0
            ad_types[0] = BLE_GAP_AD_TYPE_128BIT_SERVICE_UUID_COMPLETE;
            ad_types[1] = BLE_GAP_AD_TYPE_128BIT_SERVICE_UUID_MORE_AVAILABLE;
            for (uint8_t i = 0; (i < N_AD_TYPES) && (data_offset == 0); i++)
                parsed_uuid_len = ble_advdata_search(adv_data.p_data, adv_data.data_len, &data_offset, ad_types[i]);
            if (data_offset == 0 )
                // Could not find any relevant UUIDs in the encoded data.
                return;
            p_parsed_uuid = &adv_data.p_data[data_offset]; //The UUID we found
            //Copy the UUID to our list of devices
            memset(uuid_buffer,0,UUID128_SIZE);
            memcpy(uuid_buffer, p_parsed_uuid, parsed_uuid_len);
             NRF_LOG_INFO("Device-addr %02x:%02x:%02x:%02x:%02x:%02x",
             p_scan_evt->params.p_not_found->peer_addr.addr[5],
             p_scan_evt->params.p_not_found->peer_addr.addr[4],
             p_scan_evt->params.p_not_found->peer_addr.addr[3],
             p_scan_evt->params.p_not_found->peer_addr.addr[2],
             p_scan_evt->params.p_not_found->peer_addr.addr[1],
             p_scan_evt->params.p_not_found->peer_addr.addr[0]
            NRF_LOG_INFO("Hexdump:");
            NRF_LOG_HEXDUMP_INFO(p_parsed_uuid,parsed_uuid_len);
        case NRF_BLE_SCAN_EVT_CONNECTED:
        } break;
        case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
            NRF_LOG_INFO("Scan timed out.");
            //scan_start();
        } break;
void ble_scan_init(void)
    nrf_ble_scan_init_t init_scan;
    memset(&init_scan, 0, sizeof(init_scan));
    init_scan.p_scan_param     = &m_scan_param;
    init_scan.connect_if_match = true;
    init_scan.conn_cfg_tag     = APP_BLE_CONN_CFG_TAG;
    err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
    ble_uuid_t uuid =
        .uuid = TARGET_UUID,
        .type = BLE_UUID_TYPE_BLE,
    err_code = nrf_ble_scan_filter_set(&m_scan,
                                       SCAN_UUID_FILTER,
                                       &uuid);
                                        SCAN_NAME_FILTER,
    err_code = nrf_ble_scan_filters_enable(&m_scan,
                                           NRF_BLE_SCAN_ALL_FILTER,
                                           false);
  • case NRF_BLE_SCAN_EVT_NOT_FOUND:
                //name check
                /* Scan encoded adv. payload for data of type BLE_GAP_AD_TYPE_COMPLETE_LOCAL_NAME */
                parsed_name_len = ble_advdata_search(adv_report->data.p_data, adv_report->data.len, &data_offset, BLE_GAP_AD_TYPE_SHORT_LOCAL_NAME);
                /* Name found if parsed_name_len != 0 */
                p_parsed_name = &adv_report->data.p_data[data_offset];
                // if p_parsed_name == target name, then Connect with peripheral
                if(memcmp(m_target_periph_name, p_parsed_name, target_name_len)== 0)                    // compare only target_name_len chars of advertised name and target name
                        DEBUG_PRINTF("SEARCH OK!\r\n");
     I solved. [BLE_GAP_AD_TYPE_SHORT_LOCAL_NAME]
    Product search was successful, but the connection was unsuccessful.
    how to connect??
    is not working init_scan.connect_if_match = true;
  • Hi Hwang,
    The reason it doesn't connect because it didn't consider that it's a name matched.
    As you can see you found the packet inside NRF_BLE_SCAN_EVT_NOT_FOUND.
    I would suggest to use SCAN_SHORT_NAME_FILTER instead of SCAN_NAME_FILTER when you call ble_scan_init()
    Like this:
    err_code = nrf_ble_scan_filter_set(&m_scan,SCAN_SHORT_NAME_FILTER ,m_target_periph_name);
    Another option is to connect manually using the address of the advertiser that you find inside NRF_BLE_SCAN_EVT_NOT_FOUND using sd_ble_gap_connect().
