I am currently working on SDK 15.2.0 on my NRF52840 DK to program a bootloader that can do DFUs over SPI. I have been following the protocol found in this link. I have been able to get a DFU_Master to talk to the Slave_bootloader, however, when it gets to the execute command, I am getting a "NRF_DFU_RES_CODE_OPERATION_NOT_PERMITTED" error from the bootloader. The log error says that it is running "execute with faulty offset", which lead me to believe that I there is something wrong with how I am executing the DFU protocol. I believe that it has something to do with how I am using the offset and the crc values given from the bootloader. I am also especially confused as to how to write the if statement shown in the picture below:
Currently I have the if statement set in my spi_send_object() function as you can see in the code below. I also included the functions for the corresponding protocols that are I think are supposed to occur in the if statement.
uint32_t MAX_OBJECT_SIZE, OFFSET,CRC, SEL_OFFSET, SEL_CRC;
static void spi_send_object(uint8_t type, uint8_t *data, uint32_t length, int size)
uint8_t payload[127];
length = 256;
select_object(type,data,payload);//select the current object
if (SEL_OFFSET==0 || SEL_OFFSET>length || SEL_CRC != CRC)
create_object(type,data,length,payload);
else if (OFFSET==length || CRC == SEL_CRC)
execute_object(payload);
write_object(type,data,length,payload);//transfer write data
calculate_crc(payload);//calculate crc
static void create_object(uint8_t type, uint8_t *data, uint32_t length, uint8_t* payload)
//Create Object
printf("In create object\n");
payload[0]=0x01;
payload[1]=type;//Command or Data Object
payload[2]=length;
payload[3]=length>>8;
payload[4]=length>>16;
payload[5]=length>>24;
APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, payload, 6, NULL, 0));
spi_response_polling(m_rx_buf,3,5);
check_response(NRF_DFU_OP_OBJECT_CREATE,type,data,length,payload);
//for(int loop = 0; loop < 10; loop++)
//printf("Create Response m_rx_buf[%i]: 0x%X \r\n",loop, m_rx_buf[loop]);
static void select_object(uint8_t type, uint8_t *data, uint8_t* payload)
//string temp;
//int j = 0;
//Select Object
printf("In select object\n");
payload[0] = 0x06;
payload[1] = type;
APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, payload, 2, NULL, 0));
spi_response_polling(m_rx_buf,11,15);
check_response(NRF_DFU_OP_OBJECT_SELECT,type,data,NULL,payload);
MAX_OBJECT_SIZE = m_rx_buf[3] | (m_rx_buf[4] << 8)| (m_rx_buf[5] << 16);
SEL_OFFSET = m_rx_buf[6] | (m_rx_buf[7] << 8) | (m_rx_buf[8] << 16);
SEL_CRC = m_rx_buf[9] | (m_rx_buf[10] << 8);
//if(m_rx_buf[1]!=0x06)
//select_object(type,data,length);
static void calculate_crc(uint8_t* payload)
//Ask for CRC
printf("In calculate crc\n");
payload[0]=0x03;
APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, payload, 1, NULL, 0));
nrf_delay_ms(5);
spi_response_polling(m_rx_buf,11,5);
check_response(NRF_DFU_OP_CRC_GET,NULL,NULL,NULL,payload);
OFFSET = m_rx_buf[3] | (m_rx_buf[4] << 8)| (m_rx_buf[5] << 16);
CRC = m_rx_buf[7] | (m_rx_buf[8] << 8) | (m_rx_buf[9] << 16) | (m_rx_buf[10] << 24);
If someone can please help me understand how I should be using the offset and crc values, I would greatly appreciate it!
