No OTA consistency board to board on the same firmware/layout PCBA
Recently, we have ordered PCBAs using nrf52832 to online PCB manufacturers.
During a test, we found that some boards can use OTA firmware update, but some are not.
We use the same software/softdevice/bootloader, but the results vary from board to board.
Logs are listed below for okay cases and ng cases.
Does anyone have an idea what kind of factor affects the result of the OTA process?
Any suggestion will help.
## Device and Tools
  • The device: nrf52832 EYSHCNZWZ(TAIYO YUDEN)
  • SoftDevice: 15.3
  • Software used for OTA: nrf connect(iOS)
  • Bootloader: secure bootloader(based on secure_bootloader example)
## Logs
ok.txt - log from nrf connect the successful case
fail.txt - log from nrf connect the failed case
Hiroto
File Name: xxxxxx-0.135-7.zip
Parts: 1
Soft Device Size: Zero KB
Bootloader Size: Zero KB
[Callback] Central Manager did update state to: Powered ON
Connecting to Xxxxxx-xxxx...
centralManager.connect(peripheral, options: nil)
[Callback] Central Manager did connect peripheral
Connected to Xxxxxx-xxxx
Discovering services...
peripheral.discoverServices(nil)
Services discovered
Starting Secure DFU...
Services discovered
Secure DFU Service found
Discovering characteristics in DFU Service...
peripheral.discoverCharacteristics(nil, for: FE59)
DFU characteristics discovered
Enabling indications for 8EC90003-F315-4F60-9FB8-838830DAEA50...
peripheral.setNotifyValue(true, for: 8EC90003-F315-4F60-9FB8-838830DAEA50)
Indications enabled for 8EC90003-F315-4F60-9FB8-838830DAEA50
Buttonless DFU indications enabled
Application with buttonless update found
Trying setting bootloader name to Dfu63837
Writing to characteristic 8EC90003-F315-4F60-9FB8-838830DAEA50...
peripheral.writeValue(0x02084466753633383337, for: 8EC90003-F315-4F60-9FB8-838830DAEA50, type: .withResponse)
Data written to 8EC90003-F315-4F60-9FB8-838830DAEA50
Indication received from 8EC90003-F315-4F60-9FB8-838830DAEA50, value (0x):200201
Response (Op Code = 2, Status = 1) received
Bootloader name changed successfully
peripheral.writeValue(0x01, for: 8EC90003-F315-4F60-9FB8-838830DAEA50, type: .withResponse)
Indication received from 8EC90003-F315-4F60-9FB8-838830DAEA50, value (0x):200101
Response (Op Code = 1, Status = 1) received
[Callback] Central Manager did disconnect peripheral
Disconnected by the remote device
Buttonless service not configured, see: https://devzone.nordicsemi.com/f/nordic-q-a/59881/advertising-rename-feature-not-working/243566#243566. To workaround, disable alternative advertising name.
Scanning for the DFU Bootloader...
centralManager.scanForPeripherals(withServices, [FE59]
DFU Bootloader found with name Dfu63837
Connecting to DfuTarg...
Connected to DfuTarg
peripheral.discoverServices([FE59])
Services discovered
MTU set to 247
Enabling notifications for 8EC90001-F315-4F60-9FB8-838830DAEA50...
peripheral.setNotifyValue(true, for: 8EC90001-F315-4F60-9FB8-838830DAEA50)
Notifications enabled for 8EC90001-F315-4F60-9FB8-838830DAEA50
Secure DFU Control Point notifications enabled
Writing to characteristic 8EC90001-F315-4F60-9FB8-838830DAEA50...
peripheral.writeValue(0x0601, for: 8EC90001-F315-4F60-9FB8-838830DAEA50, type: .withResponse)
Data written to 8EC90001-F315-4F60-9FB8-838830DAEA50
Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 600601000200000000000000000000
Command object info (Max size = 512, Offset = 0, CRC = 00000000) received
peripheral.writeValue(0x01018d000000, for: 8EC90001-F315-4F60-9FB8-838830DAEA50, type: .withResponse)
Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 600101
peripheral.writeValue(0x020000, for: 8EC90001-F315-4F60-9FB8-838830DAEA50, type: .withResponse)
Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 600201
Packet Receipt Notif disabled (Op Code = 2, Value = 0)
Writing to characteristic 8EC90002-F315-4F60-9FB8-838830DAEA50...
peripheral.writeValue(0x128a010a4408011240080910341a02b70120002800300038ec9f034224080312204174c2615bb91d090cc8739f6a9fad3049f6902d8b69cf00bcdb906ba1739df6480052040801120010001a4027bf09646e27a64d611b6a5c8483de4adfe459eb4b65a2d16063f35692e4f30070d8672f7d3fb35e3a906d47f94de00f8e0835169702d9f07b68e0a6e038ecd1, for: 8EC90002-F315-4F60-9FB8-838830DAEA50, type: .withoutResponse)
Command object sent (CRC = 0AE65B6D)
peripheral.writeValue(0x03, for: 8EC90001-F315-4F60-9FB8-838830DAEA50, type: .withResponse)
Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 6003018d0000006d5be60a
Checksum (Offset = 141, CRC = 0AE65B6D) received
peripheral.writeValue(0x04, for: 8EC90001-F315-4F60-9FB8-838830DAEA50, type: .withResponse)
Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 600401
Command object executed
peripheral.writeValue(0x020c00, for: 8EC90001-F315-4F60-9FB8-838830DAEA50, type: .withResponse)
Packet Receipt Notif enabled (Op Code = 2, Value = 12)
peripheral.writeValue(0x0602, for: 8EC90001-F315-4F60-9FB8-838830DAEA50, type: .withResponse)
Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 600601001000000000000000000000
Data object info (Max size = 4096, Offset = 0, CRC = 00000000) received
peripheral.writeValue(0x010200100000, for: 8EC90001-F315-4F60-9FB8-838830DAEA50, type: .withResponse)
Data object 1/13 created
wait(400)
Uploading firmware...
Sending firmware to DFU Packet characteristic...
Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100100000d3ab6f17
Checksum (Offset = 4096, CRC = 176FABD3) received
Data object executed
Data object 2/13 created
Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 600301002000009f221e00
Checksum (Offset = 8192, CRC = 001E229F) received
Data object 3/13 created
Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100300000d86886d4
Checksum (Offset = 12288, CRC = D48668D8) received
Data object 4/13 created
Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 6003010040000028d1939c
Checksum (Offset = 16384, CRC = 9C93D128) received
Data object 5/13 created
Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100500000814cae07
Checksum (Offset = 20480, CRC = 07AE4C81) received
Data object 6/13 created
Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 600301006000004640d7ba
Checksum (Offset = 24576, CRC = BAD74046) received
Data object 7/13 created
Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100700000f290ebe7
Checksum (Offset = 28672, CRC = E7EB90F2) received
Data object 8/13 created
Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 6003010080000002582789
Checksum (Offset = 32768, CRC = 89275802) received
Data object 9/13 created
Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 600301009000009d98c996
Checksum (Offset = 36864, CRC = 96C9989D) received
Data object 10/13 created
Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100a00000f9a89260
Checksum (Offset = 40960, CRC = 6092A8F9) received
Data object 11/13 created
Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100b00000c640beaa
Checksum (Offset = 45056, CRC = AABE40C6) received
Data object 12/13 created
Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 60030100c00000b33f31e0
Checksum (Offset = 49152, CRC = E0313FB3) received
peripheral.writeValue(0x0102ec0f0000, for: 8EC90001-F315-4F60-9FB8-838830DAEA50, type: .withResponse)
Data object 13/13 created
Notification received from 8EC90001-F315-4F60-9FB8-838830DAEA50, value (0x): 600301eccf000068fd68a8
Checksum (Offset = 53228, CRC = A868FD68) received
Upload completed in 6.81 seconds
Parts: 1
Services discovered
Services discovered
Trying setting bootloader name to Dfu33264
peripheral.writeValue(0x02084466753333323634, for: 8EC90003-F315-4F60-9FB8-838830DAEA50, type: .withResponse)
Scanning timed out returning no matching peripherals!
centralManager.stopScan()
    Looks like the central device was not able to find the device(It should be advertising as "DfuTarg#your number after going into bootloader mode).
    1)
    Are you able to get the nrf_log output from the bootloader, either via UART or Segger RTT viewer as log backend? The _debug prefix projects have logging enabled. So use the pca10040_ble_debug secure_bootloader project. Maybe the log from the nRF52 might reveal something about why it's failing.
    2) Do you see this issue when testing with different phones as well?
  • Hi Sigurd,
    I do appreciate the instructions you've given.
    You literally saved my day.
    As soon as I use debug bootloader, I found I left LED code for nrf52DK in "dfu_observer()" without modification.
    And it was stacked on "nrf_gpio_cfg_output()".
    After removing unnecessary codes, it works perfectly.
    I'm now assuming variation between the board is due to a bad reflowing process that some pads are shorted.
    Thank you sooo much.
    Hiroto
