HTTPS connection using AT#XHTTPCCON fails to connect to server
I'm using the serial_lte_modem application from Tag v1.5.0-rc1, on the nrf9160dk evaluation board to make a secure connection to google.com but it returns #XHTTPCCON:0.
The local service provider uses NB-Iot and I'm able to connect to a server using a none secure connection.
Could you please look at the evidence and remark on what I'm doing wrong?
The CA certificate is loaded in the modem certificate storage. No other certificates are loaded.
AT%CMNG=2,42,0
%CMNG: 42,0,"0000000000000000000000000000000000000000000000000000000000000000","-----BEGIN CERTIFICATE-----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==
-----END CERTIFICATE-----"
This is the AT commands I send to the modem using a script:
Nordic AT Client
COM /dev/ttyACM0 Open
AT
OK
AT#XSLMUART?
#XSLMUART: 115200
OK
AT+CFUN=0
OK
AT%XSYSTEMMODE=0,1,0,2
OK
AT%XBANDLOCK=1,"10000000"
OK
AT%XDEEPSEARCH=1
OK
AT+CGDCONT=0,"IP","nbiot.vodacom.za"
OK
AT+COPS=0
OK
AT+CEREG=5
OK
AT+CFUN=21
OK
AT%XICCID
ERROR
Check SIM
AT+CPIN="3349"
OK
+CEREG: 2,"5209","0A19790D",9,0,0,"11100000","11100000"
+CEREG: 1,"5209","0A19790D",9,,,"11100000","00000110"
AT%XICCID
%XICCID: 89330000000020549718
OK
Waiting 1 sec
AT#XHTTPCCON=1,"google.com",443,42
#XHTTPCCON:0
ERROR
Attached is a modem trace for your perusal
trace-2021-04-22T10-26-22.978Z.bin
  • Hi!
    First question, did you add CONFIG_SLM_HTTPC=y to the prj.conf file, to enable the HTTP module in the SLM application?
    In the meantime, I will take a look at the trace.
    Heidi
  • The serial_lte_modem application does have the necessary configurations set:
    # Copyright (c) 2020 Nordic Semiconductor ASA
    # General config
    CONFIG_LOG=y
    CONFIG_LOG_DEFAULT_LEVEL=3
    CONFIG_STACK_SENTINEL=y
    CONFIG_NEWLIB_LIBC=y
    CONFIG_RING_BUFFER=y
    # Segger RTT
    CONFIG_USE_SEGGER_RTT=y
    CONFIG_RTT_CONSOLE=y
    CONFIG_UART_CONSOLE=n
    CONFIG_LOG_BACKEND_RTT=y
    CONFIG_LOG_BACKEND_UART=n
    # Network
    CONFIG_NETWORKING=y
    CONFIG_NET_SOCKETS=y
    CONFIG_NET_NATIVE=n
    # Modem library
    CONFIG_NRF_MODEM_LIB=y
    # Align the max FD entry to NRF_MODEM_MAX_SOCKET_COUNT(8)
    CONFIG_POSIX_MAX_FDS=8
    # Enable below for modem trace
    CONFIG_NRF_MODEM_LIB_TRACE_ENABLED=y
    # Use GPIO
    CONFIG_GPIO=y
    CONFIG_GPIO_NRFX=y
    CONFIG_GPIO_NRF_P0=y
    # UART interface
    CONFIG_SERIAL=y
    CONFIG_UART_ASYNC_API=y
    CONFIG_NRFX_TIMER2=y
    # LTE link control
    CONFIG_LTE_LINK_CONTROL=y
    CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
    # Stacks and heaps
    CONFIG_MAIN_STACK_SIZE=4096
    CONFIG_HEAP_MEM_POOL_SIZE=16384
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096
    # AT_CMD
    # Enable AT_CMD debug for details
    #CONFIG_AT_CMD_LOG_LEVEL_DBG=y
    CONFIG_AT_CMD_RESPONSE_MAX_LEN=4096
    # Device power management
    CONFIG_DEVICE_POWER_MANAGEMENT=y
    # Enable SUPL client support
    #CONFIG_SUPL_CLIENT_LIB=y
    # FOTA
    CONFIG_HTTP_PARSER_URL=y
    CONFIG_FOTA_DOWNLOAD=y
    CONFIG_FOTA_DOWNLOAD_PROGRESS_EVT=y
    CONFIG_DFU_TARGET=y
    CONFIG_DOWNLOAD_CLIENT=y
    CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096
    CONFIG_BOOTLOADER_MCUBOOT=y
    CONFIG_IMG_MANAGER=y
    CONFIG_FLASH=y
    CONFIG_IMG_ERASE_PROGRESSIVELY=y
    # SLM-specific configurations
    CONFIG_SLM_LOG_LEVEL_INF=y
    # Configure external XTAL for UART
    CONFIG_SLM_EXTERNAL_XTAL=n
    # Enable GPIO wakeup if sleep is expected
    #CONFIG_SLM_GPIO_WAKEUP=y
    # Use UART_0 (when working with PC terminal)
    CONFIG_UART_0_NRF_HW_ASYNC_TIMER=2
    CONFIG_SLM_DATAMODE_HWFC=n
    # Use UART_2 (when working with external MCU)
    #CONFIG_SLM_CONNECT_UART_2=y
    #CONFIG_UART_2_NRF_HW_ASYNC_TIMER=2
    # Use optional GPS service
    #CONFIG_SLM_GPS=y
    # Use optional FTP client service
    #CONFIG_SLM_FTPC=y
    # Use optional MQTT client service
    #CONFIG_SLM_MQTTC=y
    # Use optional HTTP client service
    CONFIG_SLM_HTTPC=y
    # Enable Key Management Library
    CONFIG_MODEM_KEY_MGMT=y
    #Enable Debug symbols
    CONFIG_DEBUG_OPTIMIZATIONS=y
  • Hi
    It looks like you're not waiting for +CEREG to return status 5, Registered, roaming before running the #HTTPCCON command. Could that be right?
    Also, could you change this to CONFIG_SLM_LOG_LEVEL_DBG=y to get all log messages and add CONFIG_AT_CMD_LOG_LEVEL_DBG=y as well.
