NCS: SRAM usage overflow with data length extension support on hci_rpmsg
Hi
I'm playing around with the configuration of the hci_rpmsg as child image in the NCS 1.5.1 release. I've added a hci_rpmsg.conf file in a "child_image" folder and added there my configuration extension for the hci_rpmsg project. It worked properly, but when I tried to enable the data length extension I've struggled over a massive SRAM usage for this feature.
When I compile it without any configuration change I get the following memory footprint for the network CPU:
Memory region Used Size Region Size %age Used
FLASH: 179084 B 256 KB 68.32%
SRAM: 45836 B 64 KB 69.94%
IDT_LIST: 168 B 2 KB 8.20%
When I try to enable the data length extension to the max supported size of 251 the memory already overflows:
SRAM: 67340 B 64 KB 102.75%
If we divide the difference of SRAM usage and the increase of the buffer we should get the number of buffers that are using this "size", right?
BufferCount = (67340 - 45836) / (251 - 27) = 96
Why is this buffer used 96 times? Is there some other configuration wrong? What would be a good configuration for maximal data length extention?
Regards Adrian
