About Mesh "Node" controls
Hi, we're just starting with BLE and Mesh.  Very confusing and find it hard to follow the on line information.  Hopefully someone can point us in the right direction :
My understand about BLE Mesh is "Relay Node", "Proxy Node", "Low Power Node" and "Friend Node" are all "optional features".  The "very basic" function of "a node" in a Mesh is basically using the "advertising" and "receiving response" using the Mesh method "IF" none of the 4 "optional function" is added.  Is this correct ?
If "yes", then how can we control the activating or de-activating those 4 "optional function" ?  What are the proper procedure (ie chain of "command") ?
To make it clear of my confusion, I have added the questions on the attached screen shots on "LPN Life Cycle" and "LPN Topology".  I hope someone can help us out and/or point us to some good readings.  Many thanks.
Many thanks.
    Yes, you are correct the feature you mentioned is optional feature and does not need to be added. How to activate/implement these different feature I suggest you have look at the different examples in our SDK. They will show you how these feature are implemented.
    Regarding the first picture, I suggest you to look at the LPN example and Integrating Low Power node feature.
    As for your second picture:
    Edge node means end node/end device. Unless it is a Low Power node then it does normal operation with Mesh/High power Operation.
    "Should this be Proxy node"
    Yes, the relay node shown in the picture is a Proxy node for it to be able to connect to a phone. But a relay node does not need to be a proxy node,
    "Is it possible to switch in and out of the different mode"
    I'm not sure what you mean by this. Just to clarify, a LPN can also be an Edge node and a node can be both a Relay node and a Proxy node.
    Hope this helped.
