I posted a similar question yesterday for an example using the standard SDK. The fix was to make the flag set by the event handler andI used for the IF statement in my main loop from a standard variable to a volatile. I tried the same test using the Light Switch Client example and adding a application timer. As with the SDK example, the event handler was being fired properly from the timer but I never execute the main loop after the first pass. I have posted the code below. Can you tell me why execution never returns to main()? My additions to the client example are from lines 54-85 and then in the main loop inside the for(;;) loop. I set breakpoints in the handler and main loop and the code executed 5 times and then stopped completely and seems to be in sleep_forever() [app_error_weak.c]
#include <stdint.h>
#include <string.h>
/* HAL */
#include "boards.h"
#include "simple_hal.h"
#include "app_timer.h"
#include "nrf_delay.h"
/* Core */
#include "nrf_mesh_config_core.h"
#include "nrf_mesh_gatt.h"
#include "nrf_mesh_configure.h"
#include "nrf_mesh.h"
#include "mesh_stack.h"
#include "device_state_manager.h"
#include "access_config.h"
/* Provisioning and configuration */
#include "mesh_provisionee.h"
#include "mesh_app_utils.h"
/* Models */
#include "generic_onoff_client.h"
/* Logging and RTT */
#include "log.h"
#include "rtt_input.h"
/* Example specific includes */
#include "app_config.h"
#include "nrf_mesh_config_examples.h"
#include "light_switch_example_common.h"
#include "example_common.h"
#include "ble_softdevice_support.h"
* Definitions
#define APP_STATE_OFF (0)
#define APP_STATE_ON (1)
#define APP_UNACK_MSG_REPEAT_COUNT (2)
/* Controls if the model instance should force all mesh messages to be segmented messages. */
#define APP_FORCE_SEGMENTATION (false)
/* Controls the MIC size used by the model instance for sending the mesh messages. */
#define APP_MIC_SIZE (NRF_MESH_TRANSMIC_SIZE_SMALL)
/* Delay value used by the OnOff client for sending OnOff Set messages. */
#define APP_ONOFF_DELAY_MS (50)
/* Transition time value used by the OnOff client for sending OnOff Set messages. */
#define APP_ONOFF_TRANSITION_TIME_MS (100)
#define APPTIMER_INTERVAL APP_TIMER_TICKS(200)
// For each application timer we need to create a handle which points to that instance
// so for evey application timer (Software timer) you create, you need to define a handle
// create a handle and name it as: m_app_timer_id
APP_TIMER_DEF(appTimer_id);
bool appTimerIsInitialized;
extern bool is_app_timer_init();
volatile uint32_t timerCount;
volatile uint8_t appTimerExpired;
uint32_t loopCount;
// create a simple handler function which will be called once the timer reaches its
// desired number of ticks value
static void appTimer_handler(void * p_context)
appTimerExpired = true;
return;
static void appTimerInit(void)
// a variable to hold error value
ret_code_t err_code;
// Create an application timer with the handle, mode and interrupt event handle function
err_code = app_timer_create(&appTimer_id, APP_TIMER_MODE_REPEATED, appTimer_handler);
* Forward declaration of static functions
static void app_gen_onoff_client_publish_interval_cb(access_model_handle_t handle, void * p_self);
static void app_generic_onoff_client_status_cb(const generic_onoff_client_t * p_self,
const access_message_rx_meta_t * p_meta,
const generic_onoff_status_params_t * p_in);
static void app_gen_onoff_client_transaction_status_cb(access_model_handle_t model_handle,
void * p_args,
access_reliable_status_t status);
* Static variables
static generic_onoff_client_t m_clients[CLIENT_MODEL_INSTANCE_COUNT];
static bool m_device_provisioned;
const generic_onoff_client_callbacks_t client_cbs =
.onoff_status_cb = app_generic_onoff_client_status_cb,
.ack_transaction_status_cb = app_gen_onoff_client_transaction_status_cb,
.periodic_publish_cb = app_gen_onoff_client_publish_interval_cb
static void device_identification_start_cb(uint8_t attention_duration_s)
hal_led_mask_set(HAL_LED_MASK, false);
hal_led_blink_ms(HAL_LED_MASK_HALF,
LED_BLINK_ATTENTION_INTERVAL_MS,
LED_BLINK_ATTENTION_COUNT(attention_duration_s));
static void provisioning_aborted_cb(void)
hal_led_blink_stop();
static void unicast_address_print(void)
dsm_local_unicast_address_t node_address;
dsm_local_unicast_addresses_get(&node_address);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Node Address: 0x%04x \n", node_address.address_start);
static void provisioning_complete_cb(void)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Successfully provisioned\n");
#if MESH_FEATURE_GATT_ENABLED
/* Restores the application parameters after switching from the Provisioning
* service to the Proxy */
gap_params_init();
conn_params_init();
unicast_address_print();
hal_led_mask_set(HAL_LED_MASK, LED_MASK_STATE_OFF);
hal_led_blink_ms(HAL_LED_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_PROV);
/* This callback is called periodically if model is configured for periodic publishing */
__LOG(LOG_SRC_APP, LOG_LEVEL_WARN, "Publish desired message here.\n");
/* Acknowledged transaction status callback, if acknowledged transfer fails, application can
* determine suitable course of action (e.g. re-initiate previous transaction) by using this
* callback.
void * p_args,
switch(status)
case ACCESS_RELIABLE_TRANSFER_SUCCESS:
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Acknowledged transfer success.\n");
case ACCESS_RELIABLE_TRANSFER_TIMEOUT:
hal_led_blink_ms(HAL_LED_MASK, LED_BLINK_SHORT_INTERVAL_MS, LED_BLINK_CNT_NO_REPLY);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Acknowledged transfer timeout.\n");
case ACCESS_RELIABLE_TRANSFER_CANCELLED:
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Acknowledged transfer cancelled.\n");
ERROR_CHECK(NRF_ERROR_INTERNAL);
/* Generic OnOff client model interface: Process the received status message in this callback */
if (p_in->remaining_time_ms > 0)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "OnOff server: 0x%04x, Present OnOff: %d, Target OnOff: %d, Remaining Time: %d ms\n",
p_meta->src.value, p_in->present_on_off, p_in->target_on_off, p_in->remaining_time_ms);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "OnOff server: 0x%04x, Present OnOff: %d\n",
p_meta->src.value, p_in->present_on_off);
static void node_reset(void)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- Node reset -----\n");
hal_led_blink_ms(HAL_LED_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_RESET);
/* This function may return if there are ongoing flash operations. */
mesh_stack_device_reset();
static void config_server_evt_cb(const config_server_evt_t * p_evt)
if (p_evt->type == CONFIG_SERVER_EVT_NODE_RESET)
node_reset();
#if NRF_MESH_LOG_ENABLE
static const char m_usage_string[] =
"\n"
"\t\t------------------------------------------------------------------------------------\n"
"\t\t Button/RTT 1) Send a message to the odd group (address: 0xC003) to turn on LED 1.\n"
"\t\t Button/RTT 2) Send a message to the odd group (address: 0xC003) to turn off LED 1.\n"
"\t\t Button/RTT 3) Send a message to the even group (address: 0xC002) to turn on LED 1.\n"
"\t\t Button/RTT 4) Send a message to the even group (address: 0xC002) to turn off LED 1.\n"
"\t\t------------------------------------------------------------------------------------\n";
static void button_event_handler(uint32_t button_number)
/* Increase button number because the buttons on the board is marked with 1 to 4 */
button_number++;
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Button %u pressed\n", button_number);
uint32_t status = NRF_SUCCESS;
generic_onoff_set_params_t set_params;
model_transition_t transition_params;
static uint8_t tid = 0;
switch(button_number)
case 1:
case 3:
set_params.on_off = APP_STATE_ON;
case 2:
case 4:
set_params.on_off = APP_STATE_OFF;
set_params.tid = tid++;
transition_params.delay_ms = APP_ONOFF_DELAY_MS;
transition_params.transition_time_ms = APP_ONOFF_TRANSITION_TIME_MS;
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Sending msg: ONOFF SET %d\n", set_params.on_off);
switch (button_number)
case 1:
case 2:
/* Demonstrate acknowledged transaction, using 1st client model instance */
/* In this examples, users will not be blocked if the model is busy */
(void)access_model_reliable_cancel(m_clients[0].model_handle);
status = generic_onoff_client_set(&m_clients[0], &set_params, &transition_params);
hal_led_pin_set(BSP_LED_0, set_params.on_off);
case 3:
case 4:
/* Demonstrate un-acknowledged transaction, using 2nd client model instance */
status = generic_onoff_client_set_unack(&m_clients[1], &set_params,
&transition_params, APP_UNACK_MSG_REPEAT_COUNT);
hal_led_pin_set(BSP_LED_1, set_params.on_off);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, m_usage_string);
switch (status)
case NRF_SUCCESS:
case NRF_ERROR_NO_MEM:
case NRF_ERROR_BUSY:
case NRF_ERROR_INVALID_STATE:
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Client %u cannot send\n", button_number);
case NRF_ERROR_INVALID_PARAM:
/* Publication not enabled for this client. One (or more) of the following is wrong:
* - An application key is missing, or there is no application key bound to the model
* - The client does not have its publication state set
* It is the provisioner that adds an application key, binds it to the model and sets
* the model's publication state.
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Publication not configured for client %u\n", button_number);
ERROR_CHECK(status);
static void rtt_input_handler(int key)
if (key >= '1' && key <= '4')
uint32_t button_number = key - '1';
button_event_handler(button_number);
static void models_init_cb(void)
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Initializing and adding models\n");
for (uint32_t i = 0; i < CLIENT_MODEL_INSTANCE_COUNT; ++i)
m_clients[i].settings.p_callbacks = &client_cbs;
m_clients[i].settings.timeout = 0;
m_clients[i].settings.force_segmented = APP_FORCE_SEGMENTATION;
m_clients[i].settings.transmic_size = APP_MIC_SIZE;
ERROR_CHECK(generic_onoff_client_init(&m_clients[i], i + 1));
static void mesh_init(void)
mesh_stack_init_params_t init_params =
.core.irq_priority = NRF_MESH_IRQ_PRIORITY_LOWEST,
.core.lfclksrc = DEV_BOARD_LF_CLK_CFG,
.core.p_uuid = NULL,
.models.models_init_cb = models_init_cb,
.models.config_server_cb = config_server_evt_cb
uint32_t status = mesh_stack_init(&init_params, &m_device_provisioned);
switch (status)
case NRF_ERROR_INVALID_DATA:
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Data in the persistent memory was corrupted. Device starts as unprovisioned.\n");
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Reboot device before starting of the provisioning process.\n");
case NRF_SUCCESS:
static void initialize(void)
__LOG_INIT(LOG_SRC_APP | LOG_SRC_ACCESS | LOG_SRC_BEARER, LOG_LEVEL_INFO, LOG_CALLBACK_DEFAULT);
__LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- BLE Mesh Light Switch Client Demo -----\n");
ERROR_CHECK(app_timer_init());
hal_leds_init();
#if BUTTON_BOARD
ERROR_CHECK(hal_buttons_init(button_event_handler));
ble_stack_init();
gap_params_init();
conn_params_init();
mesh_init();
static void start(void)
rtt_input_enable(rtt_input_handler, RTT_INPUT_POLL_PERIOD_MS);
if (!m_device_provisioned)
static const uint8_t static_auth_data[NRF_MESH_KEY_SIZE] = STATIC_AUTH_DATA;
mesh_provisionee_start_params_t prov_start_params =
.p_static_data = static_auth_data,
.prov_sd_ble_opt_set_cb = NULL,
.prov_complete_cb = provisioning_complete_cb,
.prov_device_identification_start_cb = device_identification_start_cb,
.prov_device_identification_stop_cb = NULL,
.prov_abort_cb = provisioning_aborted_cb,
.p_device_uri = EX_URI_LS_CLIENT
ERROR_CHECK(mesh_provisionee_prov_start(&prov_start_params));
mesh_app_uuid_print(nrf_mesh_configure_device_uuid_get());
ERROR_CHECK(mesh_stack_start());
hal_led_blink_ms(HAL_LED_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_START);
loopCount = 0;
timerCount = 0;
appTimerExpired = false;
initialize();
appTimerIsInitialized = is_app_timer_init();
appTimerInit();
// start the timer so that it can generate events on the desired tick value
uint32_t err_code = app_timer_start(appTimer_id, APPTIMER_INTERVAL, NULL);
start();
for (;;)
loopCount++;
if(appTimerExpired == true)
timerCount++;
(void)sd_app_evt_wait();
