Get the lib time in the thingy 91
I'm coming to you with a beginner question, I would like to use the functions localtime, difftime, strftime but I saw that time.h is not included. Is it possible to get it or to do the same thing as these functions? I tried including NEWLIB but there is no time lib.
In my project I get a timestamp and I would like to have the difference of time elapsed between this timestamp and the timestamp of now.
Thanks in advance for your help!
    No problem at all, we are happy to help with any question you might have! Slight smile
    When you say that you need a timestamp, do you mean a timestamp from the network, or a RTC counting locally on your device? As in, do you need the timestamp to be the actual current time, which is used in the network?
    Or, do you just need to see how long time has elapsed since the previous timestamp, with no regards to what the time actually is in the network?
    In the first case, where you need the network time, please see the answer by my colleague in this ticket.
    In the latter case, where you just need to see how long time has passed since last, you can use the nRF9160's RTC peripheral directly.
    Please do not hesitate to let me know if any part of my answer is unclear, or if you should have any other issues or questions!
    Karl
  • Hello !
    Thank you for your answer, I understand better! I would like to recover the timestamp network which must be the gmtime, I use this command:
    char buf_time[MODEM_INFO_JSON_STRING_SIZE];
    modem_info_string_get(MODEM_INFO_DATE_TIME, buf_time, MODEM_INFO_JSON_STRING_SIZE);
    printk("%s\n",buf_time);
    double diff_t = atoi(payload_buf) - atoi(buf_time);
    However, I can't read the result. There would be something that I missed? thank you in advance for your time ;) !
    Great, I am happy to hear that! :)
    What happens when you run the code snippet above? What is printed to your logger?
    Please check the returned value of the modem_info_string_get call, it will return the length of the received data if the call was successful - or a negative error code if the call failed.
    Please check this, and let me know what modem_info_string_get returns.
    On a general note, you should always make sure to check the returned values and error codes from your functions if there are any, as this is your only indication whether the function call succeeded or not.
    Karl
  • Oh you're right, I should have thought to check the return of the function! It's return -5.  With the debugger I see that in the lib modem_info line 482  the response in recv_buf is empty.
    err = at_cmd_write(modem_data[info]->cmd,
    			  recv_buf,
    			  CONFIG_MODEM_INFO_BUFFER_SIZE,
    			  NULL);
    But when I made
    modem_info_string_get(MODEM_INFO_RSRP, buf_rsrp, MODEM_INFO_JSON_STRING_SIZE);
    I have something in recv_buf and no error.
    Do you have an idea please ?
    Have a nice day Smiley
    Hehe, yes, it is always good to check the return value of the function. In this case, it returned a negative number which means an error occurred - this is very helpful for us to know!
    The specific -5 error is I/O Error, and could be generated if the IO has not been initialized. Have you made sure to run modem_info_init prior to the command?
    Could you try using the Date Time library for retrieving the timestamp instead?
    The Date Time library checks more thoroughly for available system time.
    Have you also ensured that the network actually provides the network time? I recently spoke to a colleague that told me that there exists some that do not always provide this.
    It sounds strange to me that you get the error when calling date time but not when calling for recv info.
    ActiTAG said:
    Have a nice day
    Thank you for saying that, I hope you have a nice day as well! :)
    Karl
