SPI initialization according to spec
I am initializing an SPI master to talk to ADXL362 accelerometer using NRF51-DK.
Datasheet page 19: www.analog.com/.../ADXL362.pdf
No matter what I do connected or disconnected, I always get 0xFF back. Makes no difference changing transfer speed, MSB or LSB, IRQ priority or anything. So I have some questions to clarify.
Code
void Spi_Initialize()
	spi_master_config_t spi_config = SPI_MASTER_INIT_DEFAULT;
#if defined(SPI_MASTER_0_ENABLE)
	spi_config.SPI_Pin_SCK = SPIM0_SCK_PIN;
	spi_config.SPI_Pin_MISO = SPIM0_MISO_PIN;
	spi_config.SPI_Pin_MOSI = SPIM0_MOSI_PIN;
	spi_config.SPI_Pin_SS = SPIM0_SS_PIN;
#elif defined(SPI_MASTER_1_ENABLE)
	spi_config.SPI_Pin_SCK = SPIM1_SCK_PIN;
	spi_config.SPI_Pin_MISO = SPIM1_MISO_PIN;
	spi_config.SPI_Pin_MOSI = SPIM1_MOSI_PIN;
	spi_config.SPI_Pin_SS = SPIM1_SS_PIN;
#endif /* SPI_MASTER_ENABLE */
	spi_config.SPI_CONFIG_ORDER = SPI_CONFIG_ORDER_LsbFirst; // :     SPI_CONFIG_ORDER_MsbFirst);
	spi_config.SPI_CONFIG_CPOL = SPI_CONFIG_CPOL_ActiveHigh;
	spi_config.SPI_CONFIG_CPHA = SPI_CONFIG_CPHA_Leading;
	spi_config.SPI_Freq = SPI_FREQUENCY_FREQUENCY_M1;
	//spi_config.SPI_PriorityIRQ = APP_IRQ_PRIORITY_HIGH;
	uint32_t result = spi_master_open(SPI_MASTER_HW, &spi_config);
	APP_ERROR_CHECK(result);
	spi_master_evt_handler_reg(SPI_MASTER_HW, spi_master_event_handler);
	Adxl362_Setup();
I set SPI_MASTER_0_ENABLE in the makefile and make sure it is compiled with -DSPI_MASTER_0_ENABLE . Code runs fine, and no appearent hard faults while debugging, or sending the data through bluetooth.
  1. Datasheet says "The SPI timing scheme follows CPHA = CPOL = 0." spi_config.SPI_CONFIG_CPOL = SPI_CONFIG_CPOL_ActiveHigh; and spi_config.SPI_CONFIG_CPHA = SPI_CONFIG_CPHA_Leading; mean this? The actual #define values are 0, but high sounds like 1 to me? What is correct? isn't this "mode 0" ?
  2. When connecting "CS" from the ADXL362 to the NRF51-DK "SEL" Pin (24), does this mean that NRF51-DK will send CS 1 and 0 before and after each command automatically? In arduino etc you need to do this manually. Or does "SEL" on the NRF51-DK have another meaning? There's like 100 different words for "chip select" it seems like :)
  3. Pin 24 is also "LED 4". Does this mean that any CS output from ADXL362 will make it light up or the other way around? It is constantly lit. Should I disable this?
I am really stuck, and wonder if I have accidentally fried the ADXL362. Thanks!
UPDATE: I got a hold of a logic analyzer. Here is my output:
Logic Output
What's going on here. OK, there is some noise from the clock into MISO, but it is completely dead. Shouldn't the clock be sent when getting a reply?
Success = 0 = OK.
static uint16_t Adxl362_Read(unsigned reg)
	uint8_t buf[4];
	uint16_t rxcnt;
	buf[0] = ADXL34X_CMD_READ;
	buf[1] = reg;
	if (reg & REG_2B) {
		rxcnt = 2;
	else {
		rxcnt = 1;
		buf[3] = 0;
	uint32_t status = spi_master_send_recv(SPI_MASTER_HW, &buf[0], 2, &buf[2], rxcnt);
	APP_ERROR_CHECK(status);
	return (uint16_t)buf[2];
My current settings aside from pins are:
Any ideas?
Update 2:
3 bytes
Here's a screenshot of sending 3 bytes where the 3rd now is 0xFF. Which seems delayed a lot. I read that the SPI buffer is only 2 bytes, but is 30 µs too much of a separation? Also it seems to be dead with both LSB first and MSB first even when sending the dummy 1 byte.
I am using a ble uart sample with advertising etc with one ADC on another pin, can the IRQs and timers interfere with the SPI?
Here are the timings. Does NRF adhere to these timings? Timings
  • You are right. This is my pca10028.h (nRF51_SDK\examples\bsp\pca10028.h). release_notes.txt says "nRF51 SDK v8.1.0".
    #define SPIM0_SCK_PIN       4     /**< SPI clock GPIO pin number. */
    #define SPIM0_MOSI_PIN      1     /**< SPI Master Out Slave In GPIO pin number. */
    #define SPIM0_MISO_PIN      3     /**< SPI Master In Slave Out GPIO pin number. */
    #define SPIM0_SS_PIN        2     /**< SPI Slave Select GPIO pin number. */
    #define SER_APP_SPIM0_SCK_PIN       29     // SPI clock GPIO pin number.
    #define SER_APP_SPIM0_MOSI_PIN      25     // SPI Master Out Slave In GPIO pin number
    #define SER_APP_SPIM0_MISO_PIN      28     // SPI Master In Slave Out GPIO pin number
    #define SER_APP_SPIM0_SS_PIN        12     // SPI Slave Select GPIO pin number
    #define SER_APP_SPIM0_RDY_PIN       14     // SPI READY GPIO pin number
    #define SER_APP_SPIM0_REQ_PIN       13     // SPI REQUEST GPIO pin number
    The SPIM0_SCK_PIN etc was pulled from the master slave example. (nRF51_SDK\examples\peripheral\spi_master_with_spi_slave\main.c(92)) Which one should I actually use? :)
    EDIT: And NRF_ADC_CONFIG_INPUT_2 or ADC_CONFIG_PSEL_AnalogInput2 is actually P0.01 on the NRF51-DK board... But how I found out I can't even remember. :) I am already using ADC_CONFIG_PSEL_AnalogInput2 so if I use SPIM0_MOSI_PIN it will conflict? Aren't P0.01-P0.06 ADC inputs?
  • If you have defined SPI_MASTER_0_ENABLE in your makefile, as you say in your first post, you will need to use the upper block, SPIM0_SCK_PIN, etc. But, of course you will need to connect your sensor to the matching pin numbers OR change the defines in your code.
    EDIT: Yes AIN2 is mapped to pin 1, you can e.g. see this in the Pin Assignment chapter in the Product Specification document.
  • Thank you so much! This is exactly the document I was looking for (Page 11)!
  • Thanks a lot. I get NRF_ERROR_BUSY (17) from spi_master_send_recv, I made sure the connections are correct. When disconnecting everything I get no errors. Today I had some bad luck with the accelerometer (reversed the polarity, VS and GND are right next to eachother!) So that might be a problem. Could a toasted device cause the busy error or can it be something else? Thanks, and have a nice weekend :)
