[NRF91] B0 + MCUBOOT (+ SPM + APP) -> updating MCUBoot over fota results in bootloop
After figuring out why MCUBoot wasn't updating my application (https://devzone.nordicsemi.com/f/nordic-q-a/74145/nrf91-b0-mcuboot-app---mcuboot-not-actually-updating-app-after-fota) I'm now trying to get B0 to update MCUBoot with fota in my application.
I have the same setup based op the asset_tracker_v2 example: B0 + MCUBoot + SPM + App.
I'm trying to update MCUBoot over FOTA.
In `./child_image/mcuboot.conf` I have the following config:
CONFIG_BOOT_SIGNATURE_KEY_FILE="/hard/coded/path/to/priv.pem"
CONFIG_FW_INFO_FIRMWARE_VERSION=1
I'm compiling both S0 and S1 versions of mcuboot. And copying `signed_by_mcuboot_and_b0_s0_image_update.bin` and `signed_by_mcuboot_and_b0_s1_image_update.bin` to AWS S3.
When flashing my application to my device (with --erase) I get following logs:
*** Booting Zephyr OS build zephyr-v2.5.0-1102-g6a1d340b632e  ***
Attempting to boot slot 0.
Attempting to boot from address 0x8200.
Verifying signature against key 0.
Hash: 0xff...a8
Firmware signature verified.
Firmware version 1
Setting monotonic counter (version: 1, slot: 0)
I: Starting bootloader V1
I: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
I: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3
I: Boot source: none
I: Swap type: none
I: Swap type: none
I: Bootloader chainload address offset: 0x28000
�*** Booting Zephyr OS build zephyr-v2.5.0-1102-g6a1d340b632e  ***
Flash regions		Domain		Permissions
00 06 0x00000 0x38000 	Secure		rwxl
07 31 0x38000 0x100000 	Non-Secure	rwxl
Non-secure callable region 0 placed in flash region 5 with size 32.
SRAM region		Domain		Permissions
00 07 0x00000 0x10000 	Secure		rwxl
08 31 0x10000 0x40000 	Non-Secure	rwxl
Peripheral		Domain		Status
00 NRF_P0               Non-Secure	OK
01 NRF_CLOCK            Non-Secure	OK
02 NRF_RTC0             Non-Secure	OK
03 NRF_RTC1             Non-Secure	OK
04 NRF_NVMC             Non-Secure	OK
05 NRF_UARTE1           Non-Secure	OK
06 NRF_UARTE2           Secure		SKIP
07 NRF_TWIM2            Non-Secure	OK
08 NRF_SPIM3            Non-Secure	OK
09 NRF_TIMER0           Non-Secure	OK
10 NRF_TIMER1           Non-Secure	OK
11 NRF_TIMER2           Non-Secure	OK
12 NRF_SAADC            Non-Secure	OK
13 NRF_PWM0             Non-Secure	OK
14 NRF_PWM1             Non-Secure	OK
15 NRF_PWM2             Non-Secure	OK
16 NRF_PWM3             Non-Secure	OK
17 NRF_WDT              Non-Secure	OK
18 NRF_IPC              Non-Secure	OK
19 NRF_VMC              Non-Secure	OK
20 NRF_FPU              Non-Secure	OK
21 NRF_EGU1             Non-Secure	OK
22 NRF_EGU2             Non-Secure	OK
23 NRF_DPPIC            Non-Secure	OK
24 NRF_REGULATORS       Non-Secure	OK
25 NRF_PDM              Non-Secure	OK
26 NRF_I2S              Non-Secure	OK
27 NRF_GPIOTE1          Non-Secure	OK
SPM: NS image at 0x38200
SPM: NS MSP at 0x2002b9d0
SPM: NS reset vector at 0x45bd1
SPM: prepare to jump to Non-Secure image.
[00:00:00.214,202] <dbg> cloud_module.state_set: State: STATE_LTE_DISCONNECTED
--> continues booting app
Note firmware version 1 recognized by B0, and corresponding `I: Starting bootloader V1` debug output by MCUBoot (version printout added by me in MCUBoot code).
Afterwards I recompile the project with `CONFIG_FW_INFO_FIRMWARE_VERSION` of MCUBoot bumped to 2 and manually changed the print out in main.c to say V2.
Then I upload both S0 and S1 versions to AWS S3 and initiate a FOTA update of MCUBoot via AWS jobs:
[00:02:45.868,743] <dbg> aws_fota.on_publish_evt: Received topic: $aws/things/352656105128063/jobs/notify-next
[00:02:45.879,150] <dbg> aws_fota.on_publish_evt: Checking for an available job
[00:02:45.887,084] <dbg> aws_fota.get_job_execution: Job doc: {"timestamp":1619420012,"execution":{"jobId":"test_fota_352656105128063_1619420010","status":"QUEUED","queuedAt":1619420012,"lastUpdatedAt":1619420012,"versionNumber":1,"executionNumber":1,"jobDocument":{"operation":"mcuboot_fw_update","fwversion":"v0.0.0","size":1,"location":{"protocol":"http:","host":"*****.s3-eu-west-1.amazonaws.com","path":"fota/mcuboot/signed_by_mcuboot_and_b0_s0_image_update.bin fota/mcuboot/signed_by_mcuboot_and_b0_s1_image_update.bin"}}}}
[00:02:45.936,431] <dbg> aws_fota.get_job_execution: Job ID: test_fota_352656105128063_1619420010
[00:02:45.945,678] <dbg> aws_fota.get_job_execution: hostname: *****.s3-eu-west-1.amazonaws.com
[00:02:45.955,780] <dbg> aws_fota.get_job_execution: file_path fota/mcuboot/signed_by_mcuboot_and_b0_s0_image_update.bin fota/mcuboot/signed_by_mcuboot_and_b0_s1_image_update.bin
[00:02:45.972,137] <dbg> aws_fota.get_job_execution: execution_version_number: 1
[00:02:45.981,201] <dbg> aws_fota.get_job_execution: Subscribed to FOTA update topic $aws/things/352656105128063/jobs/test_fota_352656105128063_1619420010/update/#
[00:02:46.212,371] <dbg> aws_fota.update_job_execution: update_job_execution, state: 1, version_number: 1
[00:02:46.778,411] <dbg> aws_iot.mqtt_evt_handler: MQTT_EVT_PUBACK: id = 7291 result = 0
[00:02:46.787,109] <dbg> aws_fota.on_publish_evt: Received topic: $aws/things/352656105128063/jobs/test_fota_352656105128063_1619420010/update/accepted
[00:02:46.801,147] <dbg> aws_fota.job_update_accepted: Start downloading firmware from ****.s3-eu-west-1.amazonaws.com/fota/mcuboot/signed_by_mcuboot_and_b0_s0_image_update.bin fota/mcuboot/signed_by_mcuboot_and_b0_s1_image_update.bin
[00:02:46.823,455] <inf> fota_download: B1 update, selected file:
Note that the S1 version is being downloaded.
After downloading and rebooting:
Hash: 0xff...a8
Firmware version 1
I: Secondary image: magic=good, swap_type=0x2, copy_done=0x3, image_ok=0x3
I: Swap type: test
D: erasing trailer; fa_id=7
D: initializing status; fa_id=7
D: writing swap_info; fa_id=7 off=0xc1d8 (0x241d8), swap_type=0x2 image_num=0x1
D: writing swap_size; fa_id=7 off=0xc1d0 (0x241d0)
D: writing magic; fa_id=7 off=0xc1f0 (0x241f0)
D: erasing trailer; fa_id=17
D: writing copy_done; fa_id=7 off=0xc1e0 (0x241e0)
Note that B0 is still booting from slot 0 and MCUBoot firmware version isn't bumped to V2 -> MCUBoot isn't updated. Looks like B0 isn't selecting the downloaded version in S1.
After this, I retry the FOTA process without changing anything to the compiled binaries. So no re-compiling or bumping versions:
[00:01:00.817,565] <dbg> aws_fota.on_publish_evt: Checking for an available job
[00:01:00.825,500] <dbg> aws_fota.get_job_execution: Job doc: {"timestamp":1619420123,"execution":{"jobId":"test_fota_352656105128063_1619420122","status":"QUEUED","queuedAt":1619420122,"lastUpdatedAt":1619420122,"versionNumber":1,"executionNumber":1,"jobDocument":{"operation":"mcuboot_fw_update","fwversion":"v0.0.0","size":1,"location":{"protocol":"http:","host":"*****.s3-eu-west-1.amazonaws.com","path":"fota/mcuboot/signed_by_mcuboot_and_b0_s0_image_update.bin fota/mcuboot/signed_by_mcuboot_and_b0_s1_image_update.bin"}}}}
[00:01:00.874,877] <dbg> aws_fota.get_job_execution: Job ID: test_fota_352656105128063_1619420122
[00:01:00.884,124] <dbg> aws_fota.get_job_execution: hostname: *****.s3-eu-west-1.amazonaws.com
[00:01:00.894,226] <dbg> aws_fota.get_job_execution: file_path fota/mcuboot/signed_by_mcuboot_and_b0_s0_image_update.bin fota/mcuboot/signed_by_mcuboot_and_b0_s1_image_update.bin
[00:01:00.910,583] <dbg> aws_fota.get_job_execution: execution_version_number: 1
[00:01:00.919,616] <dbg> aws_fota.get_job_execution: Subscribed to FOTA update topic $aws/things/352656105128063/jobs/test_fota_352656105128063_1619420122/update/#
[00:01:01.185,882] <dbg> aws_fota.update_job_execution: update_job_execution, state: 1, version_number: 1
[00:01:01.715,881] <dbg> aws_iot.mqtt_evt_handler: MQTT_EVT_PUBACK: id = 39191 result = 0
[00:01:01.740,722] <dbg> aws_fota.on_publish_evt: Received topic: $aws/things/352656105128063/jobs/test_fota_352656105128063_1619420122/update/accepted
[00:01:01.754,760] <dbg> aws_fota.job_update_accepted: Start downloading firmware from *****.s3-eu-west-1.amazonaws.com/fota/mcuboot/signed_by_mcuboot_and_b0_s0_image_update.bin fota/mcuboot/signed_by_mcuboot_and_b0_s1_image_update.bin
[00:01:01.777,038] <inf> fota_download: B1 update, selected file:
[00:01:02.025,177] <inf> download_client: Configuring socket timeout (30 s)
[00:01:02.032,531] <inf> download_client: Connecting to *****.s3-eu-west-1.amazonaws.com
[00:01:02.251,159] <inf> download_client: Downloading: fota/mcuboot/signed_by_mcuboot_and_b0_s0_image_update.bin [0]
[00:01:02.262,054] <dbg> aws_iot.aws_fota_cb_handler: AWS_FOTA_EVT_START
[00:01:02.269,195] <dbg> aws_iot_integration.aws_iot_event_handler: AWS_IOT_EVT_FOTA_START
[00:01:02.277,923] <dbg> cloud_module.cloud_wrap_event_handler: CLOUD_WRAP_EVT_FOTA_START
[00:01:02.577,819] <inf> download_client: Downloaded 1024/37443 bytes (2%)
[00:01:03.050,628] <inf> download_client: Downloaded 2048/37443 bytes (5%)
Note that now the S0 version is downloaded.
And after the reset:
Attempting to boot slot 1.
Attempting to boot from address 0x18200.
Hash: 0xff...a8
Firmware version 2
Setting monotonic counter (version: 2, slot: 1)
E: >>> ZEPHYR FATAL ERROR 1: Unhandled interrupt on CPU 0
E: Current thread: (nil) (unknown)
Hash: 0xff...a8
Firmware version 2
Hash: 0xff...a8
Firmware version 2
Now B0 does select slot 1 and firmware version 2, but when jumping to S1 I get a fatal error. And a boot-loop ensues.
It seems some of the logic in B0 isn't selecting the correct slot after the first time the FOTA is ran.
I have set both
CONFIG_SB_SIGNING_KEY_FILE="keys/priv.pem"
CONFIG_SB_PUBLIC_KEY_FILES="keys/publ1.pem,keys/publ2.pem,keys/publ3.pem"
What am I / is B0 doing wrong?
Thanks!
