BME280 error "#error Your devicetree has no enabled nodes with compatible "bosch,bme280""
This is the second time posting this issue. Using nRF9160 dk with nRF Connect SDK v1.3.1 with zepyhr v2.3.0-rc1-ncs2. I tried the BME280 sample from zephyr which gives an error. I also looked into all the posts regarding it and followed the Walkthrough for BME280.
Main.c
#include <zephyr.h>
#include <device.h>
#include <devicetree.h>
#include <drivers/sensor.h>
#define BME280 DT_INST(0, bosch_bme280)
#if DT_NODE_HAS_STATUS(BME280, okay)
#define BME280_LABEL DT_LABEL(BME280)
#else
#define BME280_LABEL "<none>"
void main(void)
	struct device *dev = device_get_binding(BME280_LABEL);
	if (dev == NULL) {
		printk("No device \"%s\" found; did initialization fail?\n",
		       BME280_LABEL);
		return;
	} else {
		printk("Found device \"%s\"\n", BME280_LABEL);
	while (1) {
		struct sensor_value temp, press, humidity;
		sensor_sample_fetch(dev);
		sensor_channel_get(dev, SENSOR_CHAN_AMBIENT_TEMP, &temp);
		sensor_channel_get(dev, SENSOR_CHAN_PRESS, &press);
		sensor_channel_get(dev, SENSOR_CHAN_HUMIDITY, &humidity);
		printk("temp: %d.%06d; press: %d.%06d; humidity: %d.%06d\n",
		      temp.val1, temp.val2, press.val1, press.val2,
		      humidity.val1, humidity.val2);
		k_sleep(K_MSEC(1000));
overlay
&i2c3 {
    status = "ok";
    sda-pin = <30>;
    scl-pin = <31>;
    clock-frequency = <I2C_BITRATE_FAST>;
    bme280@76 {
        compatible = "bosch,bme280";
        reg = <0x76>;
        label = "BME280";
prj.confg
CONFIG_STDOUT_CONSOLE=y
CONFIG_I2C=y
CONFIG_SENSOR=y
CONFIG_BME280=y
CONFIG_I2C_3=y
CONFIG_SENSOR_LOG_LEVEL_DBG=y
CONFIG_LOG_IMMEDIATE=y
CONFIG_LOG=y
kconfig
# Copyright (c) 2020, Nordic Semiconductor ASA
config LOG
	default y
config LOG_PRINTK
	default y
config SENSOR_LOG_LEVEL
	default 4
# Workaround for not being able to have commas in macro arguments
DT_COMPAT_BOSCH_BME280 := bosch,bme280
# Enable SPI support by default if there are any BME280 sensors
# on a SPI bus.
config SPI
	default $(dt_compat_on_bus,$(DT_COMPAT_BOSCH_BME280),spi)
# Enable I2C support by default if there are any BME280 sensors
# on an I2C bus.
config I2C
	default $(dt_compat_on_bus,$(DT_COMPAT_BOSCH_BME280),i2c)
source "Kconfig.zephyr"
When building I get  "/src/main.c:17:2: error: #error Your devicetree has no enabled nodes with compatible "bosch,bme280".  When I update the code and remove the error I get this warning
#warning "BME280 driver enabled without any devices" [-Wcpp]
/home/am/nrfmix/zephyr/drivers/sensor/bme280/bme280.c:397:39: warning: 'bme280_api_funcs' defined but not used [-Wunused-const-variable=]
static const struct sensor_driver_api bme280_api_funcs = {
I already tried the BME280 sensor with older version and it is working fine.
