I have application with functional configuration MCUBoot + (Spm + application). Now i'm trying to add immutable bootloader which works.
However when i attempt to update te immutable bootlaoder using dfu_target_mcuboot. The update fails. Resulting into bootloop.
The immage is uploaded successfuly, however the swapping done by the mcuboot must be somehow corrupted, because the image is functional in slot S1.
I have validated its functionality by uploading the s1 image using nrfjprog with sector erase and the MCUBoot s1 image booted without the BUS FAULT.
Configuration:
Immutable,
S0 - Mcuboot(FW_INFO=1)
S1 - Mcuboot(FW_INFO=2) - Working when uploaded with programmer, with sector erase.
S1 - Mcuboot(FW_INFO=2) - Not working when uploaded with dfu target.
I'm attaching RTT output from the mcuboot which shows the update process.
1 - Application performing update using dfu_target_mcuboot
2 - Mcuboot swaping the s1 image into PM_S1.
The mcuboot is jumping according to pm_partions.yml into mcuboot_pad from some reason instead of the application. Which i dont know is correct or not. During normal boot the RTT always cuts of to verify the address from wokring mcuboot.
3 - Mcuboot trying to revert the S1 image. Fails.
4 - Mcuboot is stuck inside bootloop.
Could somebody provide me with some hints why would the mcuboot image inside the S1 partition fails when update though dfu_target_mcuboot ?
NCS Version 1.5.0mcuboot_pad:
address: 0x58000
end_address: 0x58200
placement:
before:
- mcuboot_primary_app
region: flash_primary
sharers: 0x2
mcuboot_primary:
address: 0x58000
end_address: 0xfa000
orig_span: &id002
- mcuboot_pad
- app
- spm
span: *id002
mcuboot_primary_app:
address: 0x58200
orig_span: &id003
- app
- spm
span: *id003
Standard boot. Used DFU target to upload new version of MCUBoot S1 image. 00> *** Booting Zephyr OS build v2.4.99-ncs1-16-g1f4e57428539 *** 00> 00> [00:00:00.014,495] <inf> mcuboot: Starting bootloader 00> [00:00:00.015,289] <inf> mcuboot: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3 00> [00:00:00.015,777] <inf> mcuboot: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3 00> [00:00:00.015,777] <inf> mcuboot: Boot source: none 00> [00:00:00.016,448] <inf> mcuboot: Swap type: none 00> [00:00:00.016,937] <inf> mcuboot: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3 00> [00:00:00.017,395] <inf> mcuboot: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3 00> [00:00:00.017,395] <inf> mcuboot: Boot source: none 00> [00:00:00.018,066] <inf> mcuboot: Swap type: none Boot swaping the S1 image from the MCUBOOT_SECONDARY to the PM_S1 00> *** Booting Zephyr OS build v2.4.99-ncs1-16-g1f4e57428539 *** 00> 00> [00:00:00.014,495] <inf> mcuboot: Starting bootloader 00> [00:00:00.015,289] <inf> mcuboot: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3 00> [00:00:00.015,777] <inf> mcuboot: Secondary image: magic=good, swap_type=0x2, copy_done=0x3, image_ok=0x3 00> [00:00:00.015,777] <inf> mcuboot: Boot source: none 00> [00:00:00.016,448] <inf> mcuboot: Swap type: test 00> [00:00:00.274,688] <inf> mcuboot: Primary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3 00> [00:00:00.275,146] <inf> mcuboot: Secondary image: magic=good, swap_type=0x2, copy_done=0x3, image_ok=0x3 00> [00:00:00.275,177] <inf> mcuboot: Boot source: none 00> [00:00:00.275,848] <inf> mcuboot: Swap type: test 00> [00:00:46.803,802] <inf> mcuboot: Bootloader chainload address offset: 0x58000 00> [00:00:46.803,833] <inf> mcuboot: Jumping to the first image slot 00> [00:00:46.803,833] <err> os: ***** BUS FAULT ***** 00> [00:00:46.803,863] <err> os: Precise data bus error 00> [00:00:46.803,863] <err> os: BFAR Address: 0x5 00> [00:00:46.803,863] <err> os: r0/a1: 0x00000381 r1/a2: 0x00014d6b r2/a3: 0x20024f88 00> [00:00:46.803,863] <err> os: r3/a4: 0x00000381 r12/ip: 0x00000380 r14/lr: 0xe000ed00 00> [00:00:46.803,863] <err> os: xpsr: 0x0000ce00 00> [00:00:46.803,863] <err> os: Faulting instruction address (r15/pc): 0x200232c7 00> [00:00:46.803,863] <err> os: >>> ZEPHYR FATAL ERROR 0: CPU exception on CPU 0 00> [00:00:46.803,863] <err> os: Current thread: 0x20018c08 (unknown) 00> [00:00:46.803,863] <err> fatal_error: Resetting system Trying to revert the crashed mcuboot image: 00> *** Booting Zephyr OS build v2.4.99-ncs1-16-g1f4e57428539 *** 00> 00> [00:00:00.014,465] <inf> mcuboot: Starting bootloader 00> [00:00:00.015,258] <inf> mcuboot: Primary image: magic=good, swap_type=0x2, copy_done=0x1, image_ok=0x3 00> [00:00:00.015,747] <inf> mcuboot: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3 00> [00:00:00.015,747] <inf> mcuboot: Boot source: none 00> [00:00:00.016,418] <inf> mcuboot: Swap type: revert 00> [00:00:00.274,475] <inf> mcuboot: Primary image: magic=good, swap_type=0x2, copy_done=0x1, image_ok=0x3 00> [00:00:00.274,932] <inf> mcuboot: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3 00> [00:00:00.274,963] <inf> mcuboot: Boot source: none 00> [00:00:00.275,634] <inf> mcuboot: Swap type: revert 00> [00:00:00.533,813] <inf> mcuboot: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3 00> [00:00:09.288,757] <inf> mcuboot: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3 00> [00:00:10.245,056] <inf> mcuboot: Bootloader chainload address offset: 0x58000 00> [00:00:10.245,086] <inf> mcuboot: Jumping to the first image slot 00> [00:00:10.245,086] <err> os: ***** BUS FAULT ***** 00> [00:00:10.245,117] <err> os: Precise data bus error 00> [00:00:10.245,117] <err> os: BFAR Address: 0x5 00> [00:00:10.245,117] <err> os: r0/a1: 0x00000381 r1/a2: 0x00014d6b r2/a3: 0x20024f88 00> [00:00:10.245,117] <err> os: r3/a4: 0x00000381 r12/ip: 0x00000380 r14/lr: 0xe000ed00 00> [00:00:10.245,117] <err> os: xpsr: 0x0000ce00 00> [00:00:10.245,117] <err> os: Faulting instruction address (r15/pc): 0x200232c7 00> [00:00:10.245,117] <err> os: >>> ZEPHYR FATAL ERROR 0: CPU exception on CPU 0 00> [00:00:10.245,117] <err> os: Current thread: 0x20018c08 (unknown) 00> [00:00:10.245,117] <err> fatal_error: Resetting system Stuck in boot loop. 00> *** Booting Zephyr OS build v2.4.99-ncs1-16-g1f4e57428539 *** 00> 00> [00:00:00.014,495] <inf> mcuboot: Starting bootloader 00> [00:00:00.015,289] <inf> mcuboot: Primary image: magic=good, swap_type=0x4, copy_done=0x1, image_ok=0x1 00> [00:00:00.015,777] <inf> mcuboot: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3 00> [00:00:00.015,777] <inf> mcuboot: Boot source: none 00> [00:00:00.016,448] <inf> mcuboot: Swap type: none 00> [00:00:00.016,937] <inf> mcuboot: Primary image: magic=good, swap_type=0x0, copy_done=0x1, image_ok=0x1 00> [00:00:00.017,395] <inf> mcuboot: Secondary image: magic=unset, swap_type=0x1, copy_done=0x3, image_ok=0x3 00> [00:00:00.017,395] <inf> mcuboot: Boot source: none 00> [00:00:00.018,066] <inf> mcuboot: Swap type: none 00> [00:00:00.172,241] <inf> mcuboot: Bootloader chainload address offset: 0x58000 00> [00:00:00.172,241] <inf> mcuboot: Jumping to the first image slot 00> [00:00:00.172,271] <err> os: ***** BUS FAULT ***** 00> [00:00:00.172,271] <err> os: Precise data bus error 00> [00:00:00.172,271] <err> os: BFAR Address: 0x5 00> [00:00:00.172,271] <err> os: r0/a1: 0x00000381 r1/a2: 0x00014d6b r2/a3: 0x20024f68[0m 00> [00:00:00.172,271] <err> os: r3/a4: 0x00000381 r12/ip: 0x00000380 r14/lr: 0xe000ed00 00> [00:00:00.172,271] <err> os: xpsr: 0x0000ce00 00> [00:00:00.172,271] <err> os: Faulting instruction address (r15/pc): 0x200232c7 00> [00:00:00.172,271] <err> os: >>> ZEPHYR FATAL ERROR 0: CPU exception on CPU 0 00> [00:00:00.172,271] <err> os: Current thread: 0x20018c08 (unknown) 00> [00:00:00.172,271] <err> fatal_error: Resetting system
