My i2c or twi code is not working. Plz help me
#include "twi_master.h"
#include "twi_master_config.h"
#include <stdbool.h>
#include <stdint.h>
#include "nrf.h"
#include "nrf_delay.h"
#include "nrf_gpio.h"
/* Max cycles approximately to wait on RXDREADY and TXDREADY event,
 * This is optimized way instead of using timers, this is not power aware. */
#define MAX_TIMEOUT_LOOPS (20000UL) /**< MAX while loops to wait for RXD/TXD event */
static bool twi_master_write(uint8_t *data, uint8_t data_length, bool issue_stop_condition)
 uint32_t timeout = MAX_TIMEOUT_LOOPS; /* max loops to wait for EVENTS_TXDSENT event*/
 if (data_length == 0)
 /* Return false for requesting data of size 0 */
 return false;
 NRF_TWI1->TXD = *data++;
 NRF_TWI1->TASKS_STARTTX = 1;
 /** @snippet [TWI HW master write] */
 while (true)
 while(NRF_TWI1->EVENTS_TXDSENT == 0 && NRF_TWI1->EVENTS_ERROR == 0 && (--timeout))
 // Do nothing.
 if (timeout == 0 || NRF_TWI1->EVENTS_ERROR != 0)
 // Recover the peripheral as indicated by PAN 56: "TWI: TWI module lock-up." found at
 // Product Anomaly Notification document found at
 // www.nordicsemi.com/.../
 NRF_TWI1->EVENTS_ERROR = 0;
 NRF_TWI1->ENABLE = TWI_ENABLE_ENABLE_Disabled << TWI_ENABLE_ENABLE_Pos;
 NRF_TWI1->POWER = 0;
 nrf_delay_us(5);
 NRF_TWI1->POWER = 1;
 NRF_TWI1->ENABLE = TWI_ENABLE_ENABLE_Enabled << TWI_ENABLE_ENABLE_Pos;
 (void)twi_master_init();
 return false;
 NRF_TWI1->EVENTS_TXDSENT = 0;
 if (--data_length == 0)
 if (issue_stop_condition)
 NRF_TWI1->EVENTS_STOPPED = 0;
 NRF_TWI1->TASKS_STOP = 1;
 /* Wait until stop sequence is sent */
 while(NRF_TWI1->EVENTS_STOPPED == 0)
 // Do nothing.
	 //uint8_t wdata = NRF_TWI1->TXD;
 return true;
/** @brief Function for read by twi_master.
static bool twi_master_read(uint8_t *data, uint8_t data_length, bool issue_stop_condition)
 uint32_t timeout = MAX_TIMEOUT_LOOPS; /* max loops to wait for RXDREADY event*/
				NRF_TWI1->SHORTS = 0; //short are not enabled yet, may not be necessary
		return false;
 else if (data_length == 1)
				NRF_TWI1->SHORTS = TWI_SHORTS_BB_STOP_Enabled << TWI_SHORTS_BB_STOP_Pos;
                NRF_TWI1->SHORTS = TWI_SHORTS_BB_SUSPEND_Enabled << TWI_SHORTS_BB_SUSPEND_Pos;
 NRF_TWI1->EVENTS_RXDREADY = 0;
 NRF_TWI1->TASKS_STARTRX = 1;
 /** @snippet [TWI HW master read] */
 while (true)
 while(NRF_TWI1->EVENTS_RXDREADY == 0 && NRF_TWI1->EVENTS_ERROR == 0 && (--timeout))
 // Do nothing.
 nrf_delay_us(5);
 return false;
 *data++ = NRF_TWI1->RXD;
 if (--data_length == 1)
 nrf_delay_us(20);
 NRF_TWI1->TASKS_RESUME = 1;
 // Do nothing.
 return true;
 * @brief Function for detecting stuck slaves (SDA = 0 and SCL = 1) and tries to clear the bus.
 * @return
 * @retval false Bus is stuck.
 * @retval true Bus is clear.
static bool twi_master_clear_bus(void)
 uint32_t twi_state;
 bool bus_clear;
 uint32_t clk_pin_config;
 uint32_t data_pin_config;
 // Save and disable TWI hardware so software can take control over the pins.
 twi_state = NRF_TWI1->ENABLE;
 clk_pin_config = \
 NRF_GPIO->PIN_CNF[TWI_MASTER_CONFIG_CLOCK_PIN_NUMBER];
 NRF_GPIO->PIN_CNF[TWI_MASTER_CONFIG_CLOCK_PIN_NUMBER] = \
 (GPIO_PIN_CNF_SENSE_Disabled << GPIO_PIN_CNF_SENSE_Pos) \
 | (GPIO_PIN_CNF_DRIVE_S0D1 << GPIO_PIN_CNF_DRIVE_Pos) \
 | (GPIO_PIN_CNF_PULL_Disabled << GPIO_PIN_CNF_PULL_Pos) \
 | (GPIO_PIN_CNF_INPUT_Connect << GPIO_PIN_CNF_INPUT_Pos) \
 | (GPIO_PIN_CNF_DIR_Output << GPIO_PIN_CNF_DIR_Pos);
 data_pin_config = \
 NRF_GPIO->PIN_CNF[TWI_MASTER_CONFIG_DATA_PIN_NUMBER];
 NRF_GPIO->PIN_CNF[TWI_MASTER_CONFIG_DATA_PIN_NUMBER] = \
 TWI_SDA_HIGH();
 TWI_SCL_HIGH();
 TWI_DELAY();
 if ((TWI_SDA_READ() == 1) && (TWI_SCL_READ() == 1))
 bus_clear = true;
 uint_fast8_t i;
 bus_clear = false;
 // Clock max 18 pulses worst case scenario(9 for master to send the rest of command and 9
 // for slave to respond) to SCL line and wait for SDA come high.
 for (i=18; i--;)
 TWI_SCL_LOW();
 TWI_DELAY();
 TWI_SCL_HIGH();
 TWI_DELAY();
 if (TWI_SDA_READ() == 1)
 bus_clear = true;
 NRF_GPIO->PIN_CNF[TWI_MASTER_CONFIG_CLOCK_PIN_NUMBER] = clk_pin_config;
 NRF_GPIO->PIN_CNF[TWI_MASTER_CONFIG_DATA_PIN_NUMBER] = data_pin_config;
 NRF_TWI1->ENABLE = twi_state;
 return bus_clear;
/** @brief Function for initializing the twi_master.
bool twi_master_init(void)
 /* To secure correct signal levels on the pins used by the TWI
 master when the system is in OFF mode, and when the TWI master is
 disabled, these pins must be configured in the GPIO peripheral.
 | (GPIO_PIN_CNF_DIR_Input << GPIO_PIN_CNF_DIR_Pos);
 NRF_TWI1->PSELSCL = TWI_MASTER_CONFIG_CLOCK_PIN_NUMBER;
 NRF_TWI1->PSELSDA = TWI_MASTER_CONFIG_DATA_PIN_NUMBER;
 NRF_TWI1->FREQUENCY = TWI_FREQUENCY_FREQUENCY_K100 << TWI_FREQUENCY_FREQUENCY_Pos;
 return twi_master_clear_bus();
/** @brief Function for transfer by twi_master.
bool twi_master_transfer(uint8_t address,
 uint8_t * data,
 bool transfer_succeeded = false;
 if (data_length > 0 && twi_master_clear_bus())
 uint8_t twi_read_bit = (address & 0x01UL);
	 NRF_TWI1->ADDRESS = (address >> 1);
 if ((address & twi_read_bit))
 transfer_succeeded = twi_master_read(data, data_length, issue_stop_condition);
 transfer_succeeded = twi_master_write(data, data_length, issue_stop_condition);
 return transfer_succeeded;
/*lint --flb "Leave library region" */
