After addition SPI to softdevice, some unknown error happened. Even the circulation in main function didn't work?
I just want to add SPI to my BLE project to read some data from my gyro, but after spi's addition, the code doesn't work normally anymore. I print a log in the cycle of main function, after add spi, the circulation in main function just cycle limited times.
Before adding spi, i've defined a timer and timerout handler existed, but after spi's addition, the code can't enter the " timerout_handler" function, because i found some logs i've defined in " timerout_handler"  didn't print and display.
main function:
timer_handler:
Settings related to spi:
the LOG sequence: it stop print when "i" in increase to 35
If anyone have some opinions ?
best regards,
jerry
    Are you able to use debug in SES to found out where it hangs?
    We do have some examples with SPI that you cant test out with SPI, SPI Master Example, nrfx SPI Master Example, SPI Slave Example and SPI Transaction Manager Example.
    Side note: You can upload code snippets here by using the  insert > code function, like this:
    Here is some code
    Jonathan
    I didn't use SES, i used KEIL5. So far,I can't find wherer it hangs.
    I used the "ble_app_template"  example,  and i used the spi example in SDK 15.0,  the picture below.
    Is there any problem that i use spi example instead of spi_master?
    Here is the main fuction:
        bool erase_bonds;
        // Initialize.
        log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        advertising_init();
        services_init();
        conn_params_init();
        peer_manager_init();
        // Start execution.
        NRF_LOG_INFO("Template example started.");
        nrf_gpio_cfg_output(11);
        spi_init();
    		NRF_LOG_INFO("spi init");
    		spi_enable();
    		NRF_LOG_INFO("spi enable");
    		ICM_init();
    		NRF_LOG_INFO("ICM init");
        advertising_start(erase_bonds);
        // Enter main loop.
        for (;;)
    			i++;
            NRF_LOG_INFO("while cycle");
    			NRF_LOG_INFO("i=%d\n",i);
            idle_state_handle();
    			nrf_delay_ms(10);
    timer handler:(the "data_upload_immediate()" function was used to send some data)
    static void timer_timeout_handler1(void* p_context)
    	NRF_LOG_INFO("timerout_handler");
    	UNUSED_PARAMETER(p_context);
    	int32_t temp;
    	uint8_t value[2];
    	uint8_t* icm_x_acc;
    	temp=temp_read()/4;
    	value[0]='0'+temp/10;
    	value[1]='0'+(temp%10)/1;
    	NRF_LOG_INFO("the tenth place is£º%c\n",value[0]);
      NRF_LOG_INFO("the ones place is£º%c\n",value[1]);
      icm_x_acc[0]=ICM_Get_Accelerometer(ICM20602_ACCEL_XOUT_H);//0x43
    	icm_x_acc[1]=ICM_Get_Accelerometer(ICM20602_ACCEL_XOUT_L);
    	NRF_LOG_INFO("ACCEL_XOUT_H is£º%x\n",icm_x_acc[0]);
      NRF_LOG_INFO("ACCEL_XOUT_L is£º%x\n",icm_x_acc[1]);
          if(connect_flag==1)
    	      err_code22=data_upload_immediate(m_conn_handle, &m_lbs,value);
    			else if(connect_flag==0)
    			{nrf_gpio_pin_toggle(11);}
    data_upload_immediate():
    uint32_t data_upload_immediate(uint16_t conn_handle, ble_lbs_t * p_lbs, uint8_t*data)
        ble_gatts_hvx_params_t params;
        uint16_t len = 2;
        memset(&params, 0, sizeof(params));
        params.type   = BLE_GATT_HVX_NOTIFICATION;
        params.handle = p_lbs->data_upload_char_handles.value_handle;
        params.p_data = data;
        params.p_len  = &len;
        return sd_ble_gatts_hvx(conn_handle, &params);
    settings related to spi:
    void spi_init()
        nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
        spi_config.ss_pin   = NRF_DRV_SPI_PIN_NOT_USED;
        spi_config.miso_pin = SPI_MISO_PIN;
        spi_config.mosi_pin = SPI_MOSI_PIN;
        spi_config.sck_pin  = SPI_SCK_PIN;
    		spi_config.irq_priority = SPI_DEFAULT_CONFIG_IRQ_PRIORITY;
        spi_config.orc          = 0xFF;
        spi_config.frequency    = NRF_DRV_SPI_FREQ_8M;
        spi_config.mode         = NRF_DRV_SPI_MODE_3;
        spi_config.bit_order    = NRF_DRV_SPI_BIT_ORDER_MSB_FIRST;
        APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler, NULL));
  • This is a bug:
      uint8_t* icm_x_acc;
    The pointer is uninitialised, so a memory corruption is inevitable. Try this:
    static uint8_t SomeBuffer[2];
      uint8_t* icm_x_acc = SomeBuffer;
    or
      uint8_t icm_x_acc[2];
    yes, it is a bug. But after i fixed it, the code still went wrong.
    I found once i add the code below to "timeout_handler" , it went wrong.
    However, if i annotate these, everything work well. I guess  it didn't get the acceleration??so the code hangs?
