Dear Nordic,
We've faced with the issue on Zephyr Shell NUS module.
The other side is ble_uart_c example at nRF52840DK. (edited)
P.S. Do you have ready to use HEX with BLE_UART_C example compiled for nRF52840Dongle with UART-over-USB emulation?
Dear Nordic,
Dear Sigurd,
I've found it works with two devboards (52840 + 5340) one running central_uart and another running shell_bt_nus examples. This issue definately related to some middleware modules of Zephyr that we enable on our board (e.g. USB or others). We'll check that.
Dear Sigurd,
Finally we've made that, the shell works over BT NUS connection. We've checked it with nRF52840DK running BT UART CENTRAL example.
Could you please advice if we have ability to:
1. Speed up NUS transport over BT connection.
2. Make it possible to transfer special symbols (up-arrow, down-arrow, Tab and so on) - it works but after pressing 'Enter' key. E.g. to get command list it should be pressed Tab then Enter. Is there any setting in Shell NUS or NUS layer to send the byte(s) not only after receiving 'Enter' chars, but after some timeout too?
Do you have any suggestions on that?
Dmitry Kr said:Finally we've made that, the shell works over BT NUS connection.
Great!
Dmitry Kr said:1. Speed up NUS transport over BT connection.
Lower the connection interval(latency). For higher throughput try CONFIG_BT_CTLR_DATA_LENGTH_MAX=251
The throughput sample show-cases the configuration for max throughput: https://github.com/nrfconnect/sdk-nrf/tree/master/samples/bluetooth/throughput
Dmitry Kr said:2. Make it possible to transfer special symbols (up-arrow, down-arrow, Tab and so on)
Please create a new case for this: https://devzone.nordicsemi.com/support/add
If the original issue in this case(case id 269127) is resolved, then I suggest closing this case(269127).
