nRF5340 can't connect to nRF52840 with coded phy
Hello, this is my current setup:
- nRF52840 acting as NUS peripheral, with properly configured coded phy (nRF SDK)
- nRF5340 acting as NUS central, with properly configured coded phy (nRF Connect SDK)
I have those testing devices:
- OnePlus 6T
- another nRF52840 using NUS central with properly configured coded phy (nRF SDK)
The problem:
I'm trying to connect with nRF5340 via coded phy to nRF52840 NUS service. nRF5340 finds the nRF52's advertising, but connection fails:
*** Booting Zephyr OS build v2.4.99-ncs2  ***
[00:00:00.418,457] <inf> fs_nvs: 2 Sectors of 4096 bytes
[00:00:00.418,457] <inf> fs_nvs: alloc wra: 0, fd8
[00:00:00.418,457] <inf> fs_nvs: data wra: 0, 1c
[00:00:00.441,802] <wrn> bt_hci_core: ECC HCI commands not available
[00:00:00.441,802] <inf> bt_hci_core: No ID address. App must call settings_load()
[00:00:00.441,802] <inf> central_uart: Bluetooth initialized
[00:00:00.444,732] <inf> central_uart: Scan module initialized
[00:00:00.444,732] <inf> central_uart: NUS Client module initialized
Starting Bluetooth Central UART example
[00:00:00.448,883] <inf> central_uart: Scanning successfully started
[00:00:00.482,482] <inf> central_uart: Filters matched. Address: F9:XX:4A:XX:XX:XX (random) connectable: 1
[00:00:03.485,382] <inf> central_uart: Failed to connect to F9:XX:4A:XX:XX:XX (random) (2)
So I decided  to make following tests:
- nRF52840 (peripheral) <===> nRF52840 (central) (nRF SDK, no Zephyr) - works absolutely good
- nRF52840 (peripheral) <===> OnePlus 6T (central) - bit hard to connect, but else good (phone's fault)
- nRF52840 (peripheral) <===> nRF5340 (central) but using normal PHY (no coded) - works good
Thus, I see the problem is in nRF5340 configuration. In attachment, I'm sending my edited UART NUS central code + .config for app and HCI RPMSG.
In those configs, I enabled coded phy support and also extended advertising support
8304.sample.zip
with regards,
Marek Kraus
