I know this issue has been discussed extensively in different posts, and I believe I read all of them, but still I can't get it working.
I'm trying to drive three LEDs on pins P0.09, P0.10 and P0.11 of an nRF52832 on a custom board, using IAR as IDE. The LED connected to PIN 11 works fine, but the others don't. I understand these two are pins dedicated to the NFC functionality, and they require the last bit of NFCPINS to be set to 0 if you want to run them as GPIO.
(I know if using the DK, there is a HW issue regarding a couple of missing resistors, but that's not my concern since I am using my own board, and PINS 9 and 10 are connected directly to the LEDs circuit.)
I tried to add this line of code in "uicr_config.h":
const uint32_t UICR_ADDR_0x20C __attribute__((at(0x1000120C))) __attribute__((used)) = 0xFFFFFFFE;
But it didn't solve the problem. Besides, I'm getting a warning about the "at" attribute, but maybe that's not an issue, since it's actually not an error...(?)
I have included the "uicr_config.h" file in my libraries and I have defined "CONFIG_NFCT_PINS_AS_GPIOS" in my "main.c", but no luck yet.
Can anyone suggest other things to try, please?
Many thanks!
