TWI Does not work
Hello, i am trying to develope a I2C  application.
I am using the twi_sensor example of the SDK 12.3.0
I have configured my pins to SDA 14 and SCL 30 and i just want to send some data with the  nrf_drv_twi_tx funtion... but nothing happens. I am monitoring the gpio 14 and the gpio 30 with my osciloscope and i just see the 3.3v provided by the pull up resistor... nothing else...
What i am doing wrong ?
Thank you so much in advance
Best regards
Parents Reply
  • Ok, now i can see that setting  m_xfer_done to true the system sends a command each 0,8s more or less... What  m_xfer_done does? Does it is set to true when the master receive an ACK? Why if i force this variable to true it sends periodically a command?
    In my real application i want to use this twi with:
    Soft device (Timer 0) for BLE_UART
    Timer 1: interruption
    Timer 2: pwm
    If i copy the twi code to my real app... it does not generate any command even if i force m_xfer_done to true. Is there any conflict with the resources i mention before?
    Thanks a lot!
