TWI Does not work
Hello, i am trying to develope a I2C  application.
I am using the twi_sensor example of the SDK 12.3.0
I have configured my pins to SDA 14 and SCL 30 and i just want to send some data with the  nrf_drv_twi_tx funtion... but nothing happens. I am monitoring the gpio 14 and the gpio 30 with my osciloscope and i just see the 3.3v provided by the pull up resistor... nothing else...
What i am doing wrong ?
Thank you so much in advance
Best regards
  • I have reduced the problem to the minimum now:
    • I am using sdk12 3 twi_sensor example
    • I am using pca10028 board
    • I have installed a 2,5k pull up resistor from gpio07 to vcc
    • I have installed a 2,5k pull up resistor form gpio30 to vcc
    I have no sensor connected now. I load the example and i see absolutely nothing in the scope...
    I have reset the device but even with this i can not see anything...
  • Here's my scope when triggering on SDA line:
    I used internal pullup in the GPIO. Since you use 2.5kOhm, you sink ~1 mA, which might require you to setup the GPIOs in high-drive mode (See NRF_GPIO->PIN_CNF[] register). You could try a bit of a weaker pull-resistor, but you should still see something on your oscilloscope just after reset.
    for testing purposes: You could also set m_xfer_done=true in function main.c::twi_handler(), regardless of event received. This will then send every ~0.5 second.
    Håkon
  • Ok, now i can see that setting  m_xfer_done to true the system sends a command each 0,8s more or less... What  m_xfer_done does? Does it is set to true when the master receive an ACK? Why if i force this variable to true it sends periodically a command?
    In my real application i want to use this twi with:
    Soft device (Timer 0) for BLE_UART
    Timer 1: interruption
    Timer 2: pwm
    If i copy the twi code to my real app... it does not generate any command even if i force m_xfer_done to true. Is there any conflict with the resources i mention before?
    Thanks a lot!
    Timer 2: pwm
    Thanks a lot!
