Attempting to assign value to undefined symbol error
This question may be better suited for the Zephyr forum, but I figured I would ask it here as well in case somebody can easily see what I may be missing.
I am trying to work through the solved examples in the Bluetooth Mesh Developer Study Guide found here: Bluetooth Mesh Developer Study Guide v2.0 | BluetoothRegistered Technology Website
The code examples use Zephyr as a foundation for Bluetooth Mesh introductory examples. The Study Guide includes both starting point and solution code, and my focus is on getting the solution code examples for Switch and Light to compile.  For switch, I see this error message: "C:/Projects/BluetoothMeshDeveloperStudyGuideV2_0_0/code/solution/Switch/prj.conf:34: warning: attempt to assign the value '36' to the undefined symbol BT_MESH_RX_SDU_MAX" which appears to break the build. Complete build output here:
C:\Projects\BluetoothMeshDeveloperStudyGuideV2_0_0\code\solution\Switch>west build -b nrf52840dk_nrf52840 --pristine
-- west build: making build dir C:\Projects\BluetoothMeshDeveloperStudyGuideV2_0_0\code\solution\Switch\build pristine
-- Application: C:/Projects/BluetoothMeshDeveloperStudyGuideV2_0_0/code/solution/Switch
-- Using NCS Toolchain 1.5.0 for building. (C:/Users/mmarks/ncs/v1.5.0/toolchain/cmake)
-- Zephyr version: 2.4.99 (c:/users/mmarks/ncs/v1.5.0/zephyr)
-- Found Python3: C:/Users/mmarks/ncs/v1.5.0/toolchain/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Found west (found suitable version "0.9.0", minimum required is "0.7.1")
-- Board: nrf52840dk_nrf52840
-- Cache files will be written to: C:\Users\mmarks\AppData\Local/.cache/zephyr
-- Found dtc: C:/Users/mmarks/ncs/v1.5.0/toolchain/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found toolchain: gnuarmemb (C:/Users/mmarks/ncs/v1.5.0/toolchain/opt)
-- Found BOARD.dts: C:/Users/mmarks/ncs/v1.5.0/zephyr/boards/arm/nrf52840dk_nrf52840/nrf52840dk_nrf52840.dts
-- Generated zephyr.dts: C:/Projects/BluetoothMeshDeveloperStudyGuideV2_0_0/code/solution/Switch/build/zephyr/zephyr.dts
-- Generated devicetree_unfixed.h: C:/Projects/BluetoothMeshDeveloperStudyGuideV2_0_0/code/solution/Switch/build/zephyr/include/generated/devicetree_unfixed.h
-- Generated device_extern.h: C:/Projects/BluetoothMeshDeveloperStudyGuideV2_0_0/code/solution/Switch/build/zephyr/include/generated/device_extern.h
Parsing c:/users/mmarks/ncs/v1.5.0/zephyr/Kconfig
Loaded configuration 'C:/Users/mmarks/ncs/v1.5.0/zephyr/boards/arm/nrf52840dk_nrf52840/nrf52840dk_nrf52840_defconfig'
Merged configuration 'C:/Projects/BluetoothMeshDeveloperStudyGuideV2_0_0/code/solution/Switch/prj.conf'
error: Aborting due to Kconfig warnings
CMake Error at C:/Users/mmarks/ncs/v1.5.0/zephyr/cmake/kconfig.cmake:262 (message):
  command failed with return code: 1
  C:/Users/mmarks/ncs/v1.5.0/zephyr/cmake/app/boilerplate.cmake:534 (include)
  CMakeLists.txt:3 (include)
FATAL ERROR: command exited with status 1: 'C:\Program Files\CMake\bin\cmake.EXE' '-DWEST_PYTHON=c:\python39\python.exe' '-BC:\Projects\BluetoothMeshDeveloperStudyGuideV2_0_0\code\solution\Switch\build' '-SC:\Projects\BluetoothMeshDeveloperStudyGuideV2_0_0\code\solution\Switch' -GNinja -DBOARD=nrf52840dk_nrf52840
The symbol that it complains is undefined, BT_MESH_RX_SDU_MAX, is listed in prj.conf. Is there something I'm missing why the symbol shows up as undefined?
Mike Marks
