getting NRF_LIBUARTE_ASYNC_EVT_OVERRUN_ERROR after long time of use
im using nrf52840 with sd140 and sdk17.0.1
in my project i have implemented a libuarte communication that works well usually, but rarely, and usually after days of running i get this error:
i do nothing to handle this error and continue regularly and after this i start getting jumbled strings from the libuarte.
meaning if i send something like this:
123456789
123456789
123456789
123456789
abcdefghijklmnopqrstvuwxyz
i might get something like this:
123456789\n
123456789\n
123456789\n
123456789\n
abcdefghijklm123456789\n
nopqrstvuwxyz
i have seen a similar question in the following link:
https://devzone.nordicsemi.com/f/nordic-q-a/63905/libuarte-issue-nrf_balloc_alloc-retuns-null-after-a-while
and it ended up in saying that it got resolved somehow with the timers, which i kind of suspected,  but still don't know how to resolve.
i init the libuarte by:
NRF_LIBUARTE_ASYNC_DEFINE(xxxxx_libuarte0, 0, 1, 2, NRF_LIBUARTE_PERIPHERAL_NOT_USED, ATCMD_LIBUARTE0_RX_BUF_SIZE, ATCMD_LIBUARTE0_RX_BUF_CNT);    // using uart0 ; TIMER1; RTC2
this problem is very rare which makes it difficult to debug.
please advise,
Roy Barak
TechPack Lab
  • Hi
    I'm guessing the HWFC might be "stalling" the error for some time, but that it does not solve the problem. The only other suggestions I have is that this is likely caused either by the buffer_size or the timeout of your libuarte implementation. Can you try tweaking these somewhat to see if that helps?
    As a back-up plan, I guess you can try just disabling and enabling the libuarte peripheral, but you should test this to make sure it works.
    Simon
    yes, i figured that this is the next step and modified the libuarte init.
    #define ATCMD_LIBUARTE0_RX_BUF_CNT 3
    #define ATCMD_LIBUARTE0_RX_BUF_SIZE 255
    NRF_LIBUARTE_ASYNC_DEFINE(atcmd_libuarte0, 0, 2, NRF_LIBUARTE_PERIPHERAL_NOT_USED , 3 , ATCMD_LIBUARTE0_RX_BUF_SIZE, ATCMD_LIBUARTE0_RX_BUF_CNT); // using uart0 ; TIMER2; TIMER3
    to:
    #define ATCMD_LIBUARTE0_RX_BUF_CNT 9
    though i believe that this is more avoiding the issue then handle it, since i just increased the buffer so it will probably never (or much more rarely) will get overflowed.
    it is running for several days now, will update regarding results.
    Roy
    to:
    Roy
