MCUBOOT Hardware Key
I trying to enable Hardware Key for mcuboot.
I do the following at mcuboot.conf
CONFIG_BOOT_HW_KEY=y
But I got the following error:
C:/nrfconnect/v1.5.0/bootloader/mcuboot/boot/zephyr/keys.c:70:21: error: conflicting types for 'bootutil_keys'
   70 | struct bootutil_key bootutil_keys[1] = {
In file included from C:/nrfconnect/v1.5.0/bootloader/mcuboot/boot/zephyr/keys.c:20:
C:/nrfconnect/v1.5.0/bootloader/mcuboot/boot/bootutil/include/bootutil/sign_key.h:38:34: note: previous declaration of 'bootutil_keys' was here
   38 | extern const struct bootutil_key bootutil_keys[];
Do I miss something? Thanks,
    This is a type conflict. One is const struct while the other is struct. Try defining the array as const
    const struct bootutil_key bootutil_keys[1] = {...};
    -Amanda H.
  • #ifndef MCUBOOT_HW_KEY
    struct bootutil_key {
        const uint8_t *key;
        const unsigned int *len;
    #else
        uint8_t *key;
        unsigned int *len;
    extern struct bootutil_key bootutil_keys[];
     * Retrieve the hash of the corresponding public key for image authentication.
     * @param[in]      image_index      Index of the image to be authenticated.
     * @param[out]     public_key_hash  Buffer to store the key-hash in.
     * @param[in,out]  key_hash_size    As input the size of the buffer. As output
     *                                  the actual key-hash length.
     * @return                          0 on success; nonzero on failure.
    int boot_retrieve_public_key_hash(uint8_t image_index,
                                      uint8_t *public_key_hash,
                                      size_t *key_hash_size);
    #endif /* !MCUBOOT_HW_KEY */
    The above is from sign_key.h
    You can see that if MCUBOOT_HW_KEY is defined
    It will use
    So the issue is why MCUBOOT_HW_KEY is not define if I enable BOOT_HW_KEY
    But in keys.c, MCUBOOT_HW_KEY is defined.
    I think this is the main issue.
    modify the code in your way is not appropriated
  • Hi Jasonho,
    Mcuboot Hardware Key feature is not supported on NCS 1.5.
    -Amanda H.
    Is Mcuboot Hardware Key feature supported on NCS 1.8.0?
    I'm getting exactly the same build error as was reported for 1.5.0.
    Thanks
  • This looks to me to be a bug in keys.c, because sign_key.h is being #include'd before mcuboot_config.h rather than after it.
    As a result, MCUBOOT_HW_KEY is not defined when sign_key.h is processed at the start of compiling keys.c.
    If you swap those two #includes around, you should get further, and will then have to figure out the best way to incorporate an implementation of boot_retrieve_public_key_hash() into MCUBoot when it is built. I am not yet sure the best way to do that without having to maintain our own fork of the sdk-nrf repo (which we are trying hard to avoid).
