Dear Sir/Madam
We are planning to use P0.17 (RXD ) and P0.19 (TXD) as serial communication port connecting to Microchip SAM L10 Xplained Pro - Dm320204. I wonder if there is any sample code or UART driver available for nRF52832?
Thanks
Victor
Dear Sir/Madam
Thanks
Victor
There are multiple UART examples in the SDK, but none of these uses the UART driver directly.
You can chose from the following examples:
If you are planning to send/receiving large amounts of data, I would highly recommend that you use the last example/library.
The pin configuration can be set in the examples.
Jørgen
Hi Jorgen
I compiled & ran the Libuarte Example successfully. Will take your recommendation to use UARTE. Thanks.
Which file(s) contains the pin configuration? Any advice will be appreciated.
Thanks
Victor
I found following code in file pca10040.h
// serialization APPLICATION board - temp. setup for running serialized MEMU tests
#define SER_APP_RX_PIN 23 // UART RX pin number.
#define SER_APP_TX_PIN 24 // UART TX pin number.
#define SER_APP_CTS_PIN 2 // UART Clear To Send pin number.
#define SER_APP_RTS_PIN 25 // UART Request To Send pin number.
However, when I search the entire solution, no where uses it. Is there other place define them?
Thanks
The LIBUARTE example uses the default UART pin configurations from the board header file:
//From main.c
nrf_libuarte_async_config_t nrf_libuarte_async_config = {
.tx_pin = TX_PIN_NUMBER,
.rx_pin = RX_PIN_NUMBER,
//From pca10040.h #define RX_PIN_NUMBER 8 #define TX_PIN_NUMBER 6
You can change the pin configurations directly in main.c, either by passing the GPIO numbers directly, or by defining new symbols.
The SER_APP_* defines are used by the serialization solution examples.
Hi Jorgen
I tried serialization solution examples you mentioned. Connected the two nRF52 development boards as in the instruction of serialization hardware uart. , which is very clear. Serialization software setup installation are easy to follow too. However, after install Heart Rate application on app board and serialized example project onto connectivity board, then I don't know what & where to look the logs or activity. I used RTT to connect to application board, and no RX/TX activities. I assume this example will show user how two boards can communicate each other via UART with PINS connected, right? Further info will be appreciated.
Thanks
Victor
