nRF52840 Zephyr dual QSPI MX25R64 flash example
I am trying to modify the nRF52840dk_nrf52840 spi_flash sample, ncs/zephyr/samples/drivers/spi_flash, to use dual QSPI.
Following is my device tree configuration:
&spi1 {
	compatible = "nordic,nrf-spi";
	status = "okay";
	sck-pin = <31>;
	mosi-pin = <30>;
	miso-pin = <45>;
&qspi {
	status = "okay";
	sck-pin = <31>;
	io-pins = <30 45>;
	csn-pins = <29>;
	mx25r64: mx25r6435f@0 {
		compatible = "nordic,qspi-nor";
		reg = <0>;
		quad-enable-requirements = "NONE";
		/* MX24R64 supports only pp and pp4io */
		writeoc = "pp";
		/* MX24R64 supports all readoc options */
		readoc = "fastread";
		sck-frequency = <8000000>;
		label = "MX25R64";
		jedec-id = [c2 28 17];
		sfdp-bfp = [
			e5 20 f1 ff  ff ff ff 03  44 eb 08 6b  08 3b 04 bb
			ee ff ff ff  ff ff 00 ff  ff ff 00 ff  0c 20 0f 52
			10 d8 00 ff  23 72 f5 00  82 ed 04 cc  44 83 68 44
			30 b0 30 b0  f7 c4 d5 5c  00 be 29 ff  f0 d0 ff ff
		size = <67108864>;
		has-dpd;
		t-enter-dpd = <10000>;
		t-exit-dpd = <35000>;
I am using the main.c from the ncs/zephyr/samples/drivers/spi_flash example code.
JEDEC QSPI-NOR SPI flash testing
SPI flash driver MX25R64 was not found!
If I debug it and step into "device_get_binding()" and go down to '*z_impl_device_get_binding()" it will find the device with the following details.
dev->name = "MX25R64"
dev->config = 0x15884 <flash_id>
dev->api = 0x158d4 <qspi_nor_api>
dev->data = 0x200000e4 <qspi_nor_memory_data>
However, "sys_bitfield_test_bit()", in "z_device_ready()", indicates that the device failed initialization.
I am running this code on a custom board that is known good. I have existing code using the nRF_SDK v15.3.0 that successfully uses the MX25R64 with SPI.
What am I missing to get the MX25R64 to work with dual QSPI in Zephyr?
  • From the following https://infocenter.nordicsemi.com/index.jsp?topic=%2Fps_nrf52840%2Fqspi.html, it mentions that the QSPI can be used for “Single/dual/quad SPI input/output”
  • Response;
    "I think the problem here is that the spi1 node is enabled with the same pins assigned that the QSPI is to use. The spi_flash sample by default enables SPI, so such configuration leads to two peripherals trying to use the same pins. As the Product Specification says, this "may result in unpredictable behavior".
    Otherwise, the configuration looks okay. I tried to use the MX25R64 on nRF52840 DK in the two IO pins configuration with "pp" and "fastread" operation modes, and it worked fine. I tried this with the recent Zephyr (commit 3d39f72a88b3100ac83e7c6c285ae567aca640d0)."
  • I removed the SPI1 portion from the device tree and I still have the same error.
    Now that section of my device tree is simply
    &qspi {
    	status = "okay";
    	sck-pin = <31>;
    	io-pins = <30 45>;
    	csn-pins = <29>;
    		reg = <0>;
    		writeoc = "pp";
    		label = "MX25R64";
    		sfdp-bfp = [
    		size = <67108864>;
    		has-dpd;
    And my prj.conf settings are
    CONFIG_NORDIC_QSPI_NOR=y
    CONFIG_NORDIC_QSPI_NOR_FLASH_LAYOUT_PAGE_SIZE=4096
    CONFIG_DEBUG=y
    CONFIG_FLASH=y
    CONFIG_FLASH_MAP=y
    CONFIG_FLASH_PAGE_LAYOUT=y
    Following is my testing code, based on the nRF52840dk_nrf52840 spi_flash sample in ncs/zephyr/samples/drivers/spi_flash,
    #if (CONFIG_NORDIC_QSPI_NOR - 0) || \
        DT_NODE_HAS_STATUS(DT_INST(0, nordic_qspi_nor), okay)
    #define FLASH_DEVICE DT_INST(0, nordic_qspi_nor)
    #if DT_NODE_HAS_STATUS(FLASH_DEVICE, okay)
    #define FLASH_DEVICE_LABEL DT_LABEL(FLASH_DEVICE)
    #define FLASH_NAME         "NORDIC QSPI-NOR"
    #else
    #error "Your device tree has no enabled nodes with compatible "nordic,qspi_nor""
    #define FLASH_DEVICE_LABEL "<none>"
    #endif  ///< #if DT_NODE_HAS_STATUS(FLASH_DEVICE, okay)
    #else
    #error Unsupported flash driver
    #define FLASH_TEST_REGION_OFFSET 0xff000
    #define FLASH_SECTOR_SIZE 4096
    void testMx25r64(void) {
        const uint8_t  expected[] = {0x55, 0xaa, 0x66, 0x99};
        const size_t   len        = sizeof(expected);
        uint8_t        buf[sizeof(expected)];
        struct device *flash_dev;
        int            rc;
        printk("\n" FLASH_NAME " SPI flash testing\n");
        printk("==========================\n");
        flash_dev = device_get_binding(FLASH_DEVICE_LABEL);
        if (!flash_dev) {
            printk(RED("SPI flash driver %s was not found!\n"),
            return;
        /* Write protection needs to be disabled before each write or
    	 * erase, since the flash component turns on write protection
    	 * automatically after completion of write and erase
    	 * operations.
        printk("\nTest 1: Flash erase\n");
        flash_write_protection_set(flash_dev, false);
        rc = flash_erase(flash_dev, FLASH_TEST_REGION_OFFSET,
                         FLASH_SECTOR_SIZE);
        if (rc != 0) {
            printk(RED("Flash erase failed! %d\n"), rc);
        } else {
            printk("Flash erase succeeded!\n");
        printk("\nTest 2: Flash write\n");
        printk("Attempting to write %u bytes\n", len);
        rc = flash_write(flash_dev, FLASH_TEST_REGION_OFFSET, expected, len);
        if (rc != 0) {
            printk(RED("Flash write failed! %d\n"), rc);
            return;
        memset(buf, 0, len);
        rc = flash_read(flash_dev, FLASH_TEST_REGION_OFFSET, buf, len);
        if (rc != 0) {
            printk(RED("Flash read failed! %d\n"), rc);
            return;
        if (memcmp(expected, buf, len) == 0) {
            printk("Data read matches data written. Good!!\n");
        } else {
            const uint8_t *wp  = expected;
            const uint8_t *rp  = buf;
            const uint8_t *rpe = rp + len;
            printk(RED("Data read does not match data written!!\n"));
            while (rp < rpe) {
                printk(RED("%08x wrote %02x read %02x %s\n"),
                       (uint32_t)(FLASH_TEST_REGION_OFFSET + (rp - buf)),
                       *wp, *rp, (*rp == *wp) ? "match" : "MISMATCH");
                ++rp;
                ++wp;
    In this testing code I get “SPI flash driver MX25R64 was not found!
  • I finally got it working, I had mis-labeled one of the pins in the device tree.
  • Hi Matt,
    If you got this working, can you share the final device tree file you are using? Thanks.
