nRF52840 Zephyr dual QSPI MX25R64 flash example
I am trying to modify the nRF52840dk_nrf52840 spi_flash sample, ncs/zephyr/samples/drivers/spi_flash, to use dual QSPI.
Following is my device tree configuration:
&spi1 {
	compatible = "nordic,nrf-spi";
	status = "okay";
	sck-pin = <31>;
	mosi-pin = <30>;
	miso-pin = <45>;
&qspi {
	status = "okay";
	sck-pin = <31>;
	io-pins = <30 45>;
	csn-pins = <29>;
	mx25r64: mx25r6435f@0 {
		compatible = "nordic,qspi-nor";
		reg = <0>;
		quad-enable-requirements = "NONE";
		/* MX24R64 supports only pp and pp4io */
		writeoc = "pp";
		/* MX24R64 supports all readoc options */
		readoc = "fastread";
		sck-frequency = <8000000>;
		label = "MX25R64";
		jedec-id = [c2 28 17];
		sfdp-bfp = [
			e5 20 f1 ff  ff ff ff 03  44 eb 08 6b  08 3b 04 bb
			ee ff ff ff  ff ff 00 ff  ff ff 00 ff  0c 20 0f 52
			10 d8 00 ff  23 72 f5 00  82 ed 04 cc  44 83 68 44
			30 b0 30 b0  f7 c4 d5 5c  00 be 29 ff  f0 d0 ff ff
		size = <67108864>;
		has-dpd;
		t-enter-dpd = <10000>;
		t-exit-dpd = <35000>;
I am using the main.c from the ncs/zephyr/samples/drivers/spi_flash example code.
JEDEC QSPI-NOR SPI flash testing
SPI flash driver MX25R64 was not found!
If I debug it and step into "device_get_binding()" and go down to '*z_impl_device_get_binding()" it will find the device with the following details.
dev->name = "MX25R64"
dev->config = 0x15884 <flash_id>
dev->api = 0x158d4 <qspi_nor_api>
dev->data = 0x200000e4 <qspi_nor_memory_data>
However, "sys_bitfield_test_bit()", in "z_device_ready()", indicates that the device failed initialization.
I am running this code on a custom board that is known good. I have existing code using the nRF_SDK v15.3.0 that successfully uses the MX25R64 with SPI.
What am I missing to get the MX25R64 to work with dual QSPI in Zephyr?
  • The following device tree should work for the nRF52840DK
     * Copyright (c) 2017 Linaro Limited
    /dts-v1/;
    #include <nordic/nrf52840_qiaa.dtsi>
    	model = "Nordic nRF52840 DK NRF52840";
    	compatible = "nordic,nrf52840-dk-nrf52840";
    	chosen {
    		zephyr,console = &uart0;
    		zephyr,shell-uart = &uart0;
    		zephyr,uart-mcumgr = &uart0;
    		zephyr,bt-mon-uart = &uart0;
    		zephyr,bt-c2h-uart = &uart0;
    		zephyr,sram = &sram0;
    		zephyr,flash = &flash0;
    		zephyr,code-partition = &slot0_partition;
    	leds {
    		compatible = "gpio-leds";
    		led0: led_0 {
    			gpios = <&gpio0 13 GPIO_ACTIVE_LOW>;
    			label = "Green LED 0";
    		led1: led_1 {
    			gpios = <&gpio0 14 GPIO_ACTIVE_LOW>;
    			label = "Green LED 1";
    		led2: led_2 {
    			gpios = <&gpio0 15 GPIO_ACTIVE_LOW>;
    			label = "Green LED 2";
    		led3: led_3 {
    			gpios = <&gpio0 16 GPIO_ACTIVE_LOW>;
    			label = "Green LED 3";
    	pwmleds {
    		compatible = "pwm-leds";
    		pwm_led0: pwm_led_0 {
    			pwms = <&pwm0 13>;
    	buttons {
    		compatible = "gpio-keys";
    		button0: button_0 {
    			gpios = <&gpio0 11 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
    			label = "Push button switch 0";
    		button1: button_1 {
    			gpios = <&gpio0 12 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
    			label = "Push button switch 1";
    		button2: button_2 {
    			gpios = <&gpio0 24 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
    			label = "Push button switch 2";
    		button3: button_3 {
    			gpios = <&gpio0 25 (GPIO_PULL_UP | GPIO_ACTIVE_LOW)>;
    			label = "Push button switch 3";
    	arduino_header: connector {
    		compatible = "arduino-header-r3";
    		#gpio-cells = <2>;
    		gpio-map-mask = <0xffffffff 0xffffffc0>;
    		gpio-map-pass-thru = <0 0x3f>;
    		gpio-map = <0 0 &gpio0 3 0>,	/* A0 */
    			   <1 0 &gpio0 4 0>,	/* A1 */
    			   <2 0 &gpio0 28 0>,	/* A2 */
    			   <3 0 &gpio0 29 0>,	/* A3 */
    			   <4 0 &gpio0 30 0>,	/* A4 */
    			   <5 0 &gpio0 31 0>,	/* A5 */
    			   <6 0 &gpio1 1 0>,	/* D0 */
    			   <7 0 &gpio1 2 0>,	/* D1 */
    			   <8 0 &gpio1 3 0>,	/* D2 */
    			   <9 0 &gpio1 4 0>,	/* D3 */
    			   <10 0 &gpio1 5 0>,	/* D4 */
    			   <11 0 &gpio1 6 0>,	/* D5 */
    			   <12 0 &gpio1 7 0>,	/* D6 */
    			   <13 0 &gpio1 8 0>,	/* D7 */
    			   <14 0 &gpio1 10 0>,	/* D8 */
    			   <15 0 &gpio1 11 0>,	/* D9 */
    			   <16 0 &gpio1 12 0>,	/* D10 */
    			   <17 0 &gpio1 13 0>,	/* D11 */
    			   <18 0 &gpio1 14 0>,	/* D12 */
    			   <19 0 &gpio1 15 0>,	/* D13 */
    			   <20 0 &gpio0 26 0>,	/* D14 */
    			   <21 0 &gpio0 27 0>;	/* D15 */
    	arduino_adc: analog-connector {
    		compatible = "arduino,uno-adc";
    		#io-channel-cells = <1>;
    		io-channel-map = <0 &adc 1>,	/* A0 = P0.3 = AIN1 */
    				 <1 &adc 2>,	/* A1 = P0.4 = AIN2 */
    				 <2 &adc 4>,	/* A2 = P0.28 = AIN4 */
    				 <3 &adc 5>,	/* A3 = P0.29 = AIN5 */
    				 <4 &adc 6>,	/* A4 = P0.30 = AIN6 */
    				 <5 &adc 7>;	/* A5 = P0.31 = AIN7 */
    	/* These aliases are provided for compatibility with samples */
    	aliases {
    		led0 = &led0;
    		led1 = &led1;
    		led2 = &led2;
    		led3 = &led3;
    		pwm-led0 = &pwm_led0;
    		sw0 = &button0;
    		sw1 = &button1;
    		sw2 = &button2;
    		sw3 = &button3;
    &adc {
    	status = "okay";
    &gpiote {
    	status = "okay";
    &gpio0 {
    	status = "okay";
    &gpio1 {
    	status = "okay";
    &uart0 {
    	status = "okay";
    	current-speed = <115200>;
    	tx-pin = <6>;
    	rx-pin = <8>;
    	rts-pin = <5>;
    	cts-pin = <7>;
    arduino_serial: &uart1 {
    	status = "okay";
    	rx-pin = <33>;
    	tx-pin = <34>;
    arduino_i2c: &i2c0 {
    	compatible = "nordic,nrf-twi";
    	status = "okay";
    	sda-pin = <26>;
    	scl-pin = <27>;
    &i2c1 {
    	/* Cannot be used together with spi1. */
    	/* status = "okay"; */
    	sda-pin = <30>;
    	scl-pin = <31>;
    &pwm0 {
    	status = "okay";
    	ch0-pin = <13>;
    	ch0-inverted;
    &spi0 {
    	/* Cannot be used together with i2c0. */
    	sck-pin = <27>;
    	mosi-pin = <26>;
    	miso-pin = <29>;
    &spi1 {
    	status = "okay";
    	sck-pin = <31>;
    	mosi-pin = <30>;
    	miso-pin = <40>;
    // &spi2 {
    // 	compatible = "nordic,nrf-spi";
    // 	status = "disabled";
    // 	sck-pin = <19>;
    // 	mosi-pin = <20>;
    // 	miso-pin = <21>;
    &qspi {
    	status = "okay";
    	sck-pin = <19>;
    	io-pins = <20>, <21>;
    	csn-pins = <17>;
    		reg = <0>;
    		writeoc = "pp";
    		label = "MX25R64";
    		sfdp-bfp = [
    		size = <67108864>;
    		has-dpd;
    arduino_spi: &spi3 {
    	status = "okay";
    	sck-pin = <47>;
    	miso-pin = <46>;
    	mosi-pin = <45>;
    	cs-gpios = <&arduino_header 16 GPIO_ACTIVE_LOW>; /* D10 */
    &flash0 {
    	partitions {
    		#address-cells = <1>;
    		#size-cells = <1>;
    		boot_partition: partition@0 {
    			label = "mcuboot";
    			reg = <0x000000000 0x0000C000>;
    		slot0_partition: partition@c000 {
    			label = "image-0";
    			reg = <0x0000C000 0x00067000>;
    		slot1_partition: partition@73000 {
    			label = "image-1";
    			reg = <0x00073000 0x00067000>;
    		scratch_partition: partition@da000 {
    			label = "image-scratch";
    			reg = <0x000da000 0x0001e000>;
    		 * The flash starting at 0x000f8000 and ending at
    		 * 0x000fffff is reserved for use by the application.
    		 * Storage partition will be used by FCB/LittleFS/NVS
    		 * if enabled.
    		storage_partition: partition@f8000 {
    			label = "storage";
    			reg = <0x000f8000 0x00008000>;
    &usbd {
    	compatible = "nordic,nrf-usbd";
    	status = "okay";
