JLINKARM_DLL_ERROR (ffffff9a)
I am trying to program my nRF9160 DK v0.9.0 with mfw v1.1.4 but I am getting an error "Modem DFU failed with error: Error: Error occured when program. Errorcode: CouldNotCallFunction (0x9) Lowlevel error: JLINKARM_DLL_ERROR (ffffff9a)". I am also sometimes having issues programming the application core. I have the VDD_IO set to 1.8V and programming switch to nRF91.
I am using the latest version of nrfjprog and JLink. This was also happening on JLink v6.88.
nrfjprog version: 10.12.1
JLinkARM.dll version: 7.20a
As you can see in the log below, it surprisingly detects the device as "NRF9160_xxAA_REV2" even though there is a Rev 1 (B0) on this DK. Perhaps that is the problem?
Log for modem update :
2021-05-07T23:19:33.426Z INFO Application data folder: C:\Users\Akash\AppData\Roaming\nrfconnect\pc-nrfconnect-programmer
2021-05-07T23:19:33.551Z DEBUG App pc-nrfconnect-programmer v1.4.8 official
2021-05-07T23:19:33.551Z DEBUG App path: C:\Users\Akash\.nrfconnect-apps\node_modules\pc-nrfconnect-programmer
2021-05-07T23:19:33.551Z DEBUG nRFConnect 3.6.1 is supported by the app (^3.6.0)
2021-05-07T23:19:33.551Z DEBUG nRFConnect path: C:\Users\Akash\AppData\Local\Programs\nrfconnect\resources\app.asar
2021-05-07T23:19:33.551Z DEBUG HomeDir: C:\Users\Akash
2021-05-07T23:19:33.552Z DEBUG TmpDir: C:\Users\Akash\AppData\Local\Temp
2021-05-07T23:19:33.577Z INFO Using nrfjprog library 10.12.1, pc-nrfjprog-js 1.7.6
2021-05-07T23:19:34.428Z VERBOSE Could not fetch serial number for serial port at COM3
2021-05-07T23:19:36.246Z INFO Using nrfjprog to communicate with target
2021-05-07T23:19:36.971Z INFO Using J-Link Software version 7.20
2021-05-07T23:19:37.463Z INFO Segger serial:  960056967
2021-05-07T23:19:37.463Z INFO Segger speed:  2000  kHz
2021-05-07T23:19:37.463Z INFO Segger version:  J-Link OB-K22-NordicSemi compiled Apr 29 2021 15:10:52
2021-05-07T23:19:37.464Z INFO Core probed: 960056967
2021-05-07T23:19:37.464Z INFO Core RAM: 256KiB
2021-05-07T23:19:37.464Z INFO Core ROM: 1024KiB in pages of 4KiB
2021-05-07T23:19:37.818Z INFO Model: NRF9160_xxAA_REV2.
2021-05-07T23:19:38.657Z INFO Core0: Reading device non-volatile memory. This may take a few seconds.
2021-05-07T23:19:39.302Z INFO Core0: UICR has been read. Click read button to read full non-volatile memory.
2021-05-07T23:19:50.081Z INFO Modem DFU starts to write...
2021-05-07T23:19:50.081Z INFO Writing C:\Users\Akash\Documents\Nordic\nRF9160\Modem_Firmware\Public\1.1.4\mfw_nrf9160_1.1.4.zip to device 960056967
2021-05-07T23:19:51.184Z INFO Checking for newer bootloader.
2021-05-07T23:19:51.188Z INFO Newer bootloader discovered, re-initializing.
2021-05-07T23:19:51.353Z INFO Programming file 0 of 2 files.
2021-05-07T23:19:51.367Z INFO Programming 1 of 1 segments.
2021-05-07T23:19:51.433Z INFO Programming finished.
2021-05-07T23:19:51.436Z INFO Programming file 1 of 2 files.
2021-05-07T23:19:52.495Z INFO Programming 1 of 32 segments.
2021-05-07T23:19:53.150Z INFO Programming 2 of 32 segments.
2021-05-07T23:19:54.563Z INFO Programming 3 of 32 segments.
2021-05-07T23:19:59.854Z ERROR Modem DFU failed with error: Error: Error occured when program. Errorcode: CouldNotCallFunction (0x9)
I am also getting an error (sometimes) when trying to update the application: 7041.log.log
Akash Patel
