I need examples of AOA and AOD of nrf52833, please tell me the download path. thank you
Do you have a dome that converts IQ into an angle, or provides relevant information.Thank you
No we dont, i belive it's described in the white paper how this should be done..
Kaja
The value of chan_idx in the bt_df_per_adv_sync_iq_samples_report structure of the zephyr routine is not 0x00-0x27. How to convert the value to the corresponding frequency.For example, what is the frequency of 0x6c.Thank you!
Hello yangwen!
Thank you for being interested in direction finding.
I'd like to answer to your question about channel index in bt_df_per_adv_sync_iq_samples_report structure. Unfortunately there was a bug in the upstream code. The channel index was wrong.
I've created an issue to track it in Zephyr GitHub: https://github.com/zephyrproject-rtos/zephyr/issues/36022.
I've also created a bug-fix.
Here is a PR: https://github.com/zephyrproject-rtos/zephyr/pull/36023 that solves the problem.
You can wait for merge of the PR into upstream.
Piotr
I'm glad to hear from you. The problem has been solved. Thank you
