AOA&AOD
I need examples of AOA and AOD of nrf52833, please tell me the download path. thank you
    Excuse me, AOA Tag TX. After the direction_finding_connectionless_ tx program is written on the NRF52833DK development board, the log print program runs normally. NRF Connect can't search for this device.
    thanks
  • Hi!
    First thanks for pointing out the bug but now I have another problem.
    I am running zephyr/samples/bluetooth/ direction_finding_connectionless_rx sample appplication with minor modifications. I had no problem building application. Then I updated my local zephyr project repository (to get rid of mentioned bug). Now my appliaction won't build beacuse of some Kconfig warning.
    Here is the complete console output from Eclipse IDE:
    west build -b nrf52833dk_nrf52833
    /usr/bin/cmake: /usr/local/lib/libcurl.so.4: no version information available (required by /usr/bin/cmake)
    Including boilerplate (Zephyr base (cached)): PROJECT_PATH/zephyr/cmake/app/boilerplate.cmake
    -- Application: PROJECT_PATH
    -- Zephyr version: 2.6.99 (PROJECT_PATH/zephyr), build: zephyr-v2.6.0-1198-g244f69d1df7f
    -- Found west (found suitable version "0.10.1", minimum required is "0.7.1")
    -- Board: nrf52833dk_nrf52833
    -- Cache files will be written to: HOME_PATH/.cache/zephyr
    -- Found dtc: /usr/bin/dtc (found suitable version "1.5.0", minimum required is "1.4.6")
    -- Found toolchain: gnuarmemb (GNU_ARM_EMBEDDED_TOOLCHAIN_PATH/gcc-arm-none-eabi-8-2019-q3-update-linux/gcc-arm-none-eabi-8-2019-q3-update)
    -- Found BOARD.dts: PROJECT_PATH/zephyr/boards/arm/nrf52833dk_nrf52833/nrf52833dk_nrf52833.dts
    -- Found devicetree overlay: PROJECT_PATH/boards/nrf52833dk_nrf52833.overlay
    -- Generated zephyr.dts: PROJECT_PATH/build/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: PROJECT_PATH/build/zephyr/include/generated/devicetree_unfixed.h
    -- Generated device_extern.h: PROJECT_PATH/build/zephyr/include/generated/device_extern.h
    Parsing PROJECT_PATH/zephyr/Kconfig
    Loaded configuration 'PROJECT_PATH/zephyr/boards/arm/nrf52833dk_nrf52833/nrf52833dk_nrf52833_defconfig'
    Merged configuration 'PROJECT_PATH/prj.conf'
    Merged configuration 'PROJECT_PATH/boards/nrf52833dk_nrf52833.conf'
    warning: <choice MEMFAULT_HTTP_PERIODIC_UPLOAD_CONTEXT> (defined at PROJECT_PATH/nrf/modules/memfault/Kconfig:160) defined with type unknown
    warning: <choice MEMFAULT_HTTP_PERIODIC_UPLOAD_CONTEXT> (defined at PROJECT_PATH/nrf/modules/memfault/Kconfig:160) defined without a prompt
    warning: the default selection MEMFAULT_HTTP_PERIODIC_UPLOAD_USE_DEDICATED_WORKQUEUE (undefined) of <choice MEMFAULT_HTTP_PERIODIC_UPLOAD_CONTEXT> (defined at PROJECT_PATH/nrf/modules/memfault/Kconfig:160) is not contained in the choice
    error: Aborting due to Kconfig warnings
    CMake Error at zephyr/cmake/kconfig.cmake:268 (message):
      command failed with return code: 1
      zephyr/cmake/app/boilerplate.cmake:572 (include)
      zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
      zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:40 (include_boilerplate)
      CMakeLists.txt:8 (find_package)
    FATAL ERROR: command exited with status 1: /usr/bin/cmake -DWEST_PYTHON=/usr/bin/python3 -B/build -S/PROJECT_PATH -GNinja
    "west build -b nrf52833dk_nrf52833" terminated with exit code 1. Build might be incomplete.
    18:41:52 Build Finished. 0 errors, 0 warnings. (took 2s.790ms)
    I have tried with fresh sample with no modifications and I got the same error.
    Do you have any clue what is going on?
  • I didn't update the latest library, just follow the steps to change the program.
