How can i write external qspi flash over BLE DFU?
Hello
i'm use nrf52840 and I want write external qspi flash over BLE DFU but cannot be use
how can i solve this problem?
DFU log
<info> app: Inside main
<debug> app: In nrf_bootloader_init
<debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()...
<debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
<debug> nrf_dfu_settings: Using settings page.
<debug> nrf_dfu_settings: Copying forbidden parts from backup page.
<debug> nrf_dfu_settings: Destination settings are identical to source, write not needed. Skipping.
<info> nrf_dfu_settings: Backing up settings page to address 0xFE000.
<debug> app: Enter nrf_bootloader_fw_activate
<info> app: No firmware to activate.
<info> app: Boot validation failed. No valid app to boot.
<debug> app: DFU mode because app is not valid.
<info> nrf_bootloader_wdt: WDT is not enabled
<debug> app: in weak nrf_dfu_init_user
<debug> app: timer_stop (0x200059A0)
<debug> app: timer_activate (0x200059A0)
<info> app: Entering DFU mode.
<debug> app: Initializing transports (found: 1)
<debug> nrf_dfu_ble: Initializing BLE DFU transport
<debug> nrf_dfu_ble: Setting up vector table: 0x000EE000
<debug> nrf_dfu_ble: Enabling SoftDevice.
<debug> app: nrf_fstorage_sdh_req_handler
<debug> app: nrf_fstorage_sdh_state_handler state 0
<debug> app: nrf_fstorage_sdh_state_handler state 1
<debug> nrf_dfu_ble: Configuring BLE stack.
<debug> nrf_dfu_ble: Enabling the BLE stack.
<debug> nrf_dfu_ble: No advertising name found
<debug> nrf_dfu_ble: Using default advertising name
<debug> nrf_dfu_ble: Advertising...
<debug> nrf_dfu_ble: BLE DFU transport initialized.
<debug> nrf_dfu_flash: Initializing nrf_fstorage_sd backend.
<debug> app: Enter main loop
<debug> nrf_dfu_ble: Connected
<debug> nrf_dfu_ble: Received BLE_GAP_EVT_CONN_PARAM_UPDATE
<debug> nrf_dfu_ble: max_conn_interval: 12
<debug> nrf_dfu_ble: min_conn_interval: 12
<debug> nrf_dfu_ble: slave_latency: 0
<debug> nrf_dfu_ble: conn_sup_timeout: 600
<debug> nrf_dfu_ble: max_conn_interval: 6
<debug> nrf_dfu_ble: min_conn_interval: 6
<debug> nrf_dfu_ble: conn_sup_timeout: 500
<debug> nrf_dfu_ble: Received BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST (request: 517, reply: 247).
<debug> nrf_dfu_ble: Received BLE_GAP_EVT_DATA_LENGTH_UPDATE_REQUEST.
<debug> nrf_dfu_ble: Received BLE_GAP_EVT_DATA_LENGTH_UPDATE (251, max_rx_time 2120).
<debug> nrf_dfu_req_handler: nrf_dfu_req_handler_req_process()
<debug> nrf_dfu_req_handler: nrf_dfu_obj_op()
<debug> nrf_dfu_req_handler: CMD req
<debug> nrf_dfu_req_handler: nrf_dfu_command_req() REQ : 6
<debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_SELECT (command)
<debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
<debug> nrf_dfu_ble: Set receipt notif
<debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_RECEIPT_NOTIF_SET
<debug> app: Shutting down transports (found: 1)
<debug> nrf_dfu_req_handler: nrf_dfu_command_req() REQ : 1
<debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (command)
<debug> nrf_dfu_ble: Buffer 0x200076FC acquired, len 141 (244)
<debug> nrf_dfu_req_handler: nrf_dfu_command_req() REQ : 8
<debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (command)
<debug> nrf_dfu_ble: Freeing buffer 0x200076FC
<debug> nrf_dfu_req_handler: nrf_dfu_command_req() REQ : 3
<debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (command)
<debug> nrf_dfu_req_handler: nrf_dfu_command_req() REQ : 4
<debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (command)
<debug> nrf_dfu_validation: PB: Init packet data len: 64
<info> nrf_dfu_validation: Signature required. Checking signature.
<info> nrf_dfu_validation: Calculating hash (len: 64)
<info> nrf_dfu_validation: Verify signature
<info> nrf_dfu_validation: Image verified
<debug> app: Enter nrf_dfu_cache_prepare()
<debug> app: required_size: 0x2D598.
<debug> app: single_bank: false.
<debug> app: keep_app: false.
<debug> app: keep_softdevice: true.
<debug> app: SD_PRESENT: true.
<debug> app: Bank contents:
<debug> app: Bank 0 code: 0x00: Size: 0x0
<debug> app: Bank 1 code: 0x00: Size: 0x0
<debug> app: pass: 0.
<debug> app: cache_address: 0x27000.
<debug> app: cache_too_small: false.
<debug> app: keep_firmware: false.
<debug> app: delete_more: false.
<debug> nrf_dfu_validation: Write address set to 0x00027000
<debug> nrf_dfu_settings: Writing settings...
<debug> nrf_dfu_settings: Erasing old settings at: 0x000FF000
<debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x000FF000, len=1 pages), queue usage: 0
<debug> app: sd erase
<debug> app: queue_start() queue_running : 0, paused : 0
<debug> app: SD Erase page address : 0xFF000
<debug> app: Que Excute code : 1, rc : 1
<debug> app: Queue Excute sd_enabled : 1
<debug> app: queue process error  0x1
<debug> nrf_dfu_flash: dfu_fstorage_evt_handler()
<debug> nrf_dfu_flash: Flash erase failed (0x3): addr=0x000FF000, len=0x1 bytes, pending 0
<debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000FF000, src=0x20008798, len=896 bytes), queue usage: 1
<debug> app: sd Write
<debug> app: Que Excute code : 0, rc : 0
<debug> nrf_dfu_settings: Erasing old settings at: 0x000FE000
<debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x000FE000, len=1 pages), queue usage: 2
<debug> app: queue_start() queue_running : 1, paused : 0
<debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000FE000, src=0x20008B18, len=896 bytes), queue usage: 3
<debug> nrf_dfu_req_handler: Writing valid init command to flash.
<debug> nrf_dfu_req_handler: DFU req
<debug> nrf_dfu_req_handler: Req on_data_obj_select_request
<debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_SELECT (data)
<debug> nrf_dfu_req_handler: crc = 0x0, offset = 0x0, max_size = 0x1000
<debug> nrf_dfu_req_handler: Req on_data_obj_create_request
<debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (data)
<debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00027000, len=1 pages), queue usage: 4
<debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00000000, CRC: 0x00000000
<debug> nrf_dfu_ble: Buffer 0x200076FC acquired, len 244 (244)
<debug> nrf_dfu_req_handler: Req on_data_obj_write_request
<debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (data)
<debug> nrf_dfu_req_handler: Start address : 0x27000, address offset 0x0
<debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027000, src=0x200076FC, len=244 bytes), queue usage: 5
<debug> nrf_dfu_ble: Buffer 0x200077F0 acquired, len 244 (244)
<debug> nrf_dfu_req_handler: Start address : 0x27000, address offset 0xF4
<debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000270F4, src=0x200077F0, len=244 bytes), queue usage: 6
<debug> nrf_dfu_ble: Buffer 0x200078E4 acquired, len 244 (244)
<debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000271E8, src=0x200078E4, len=244 bytes), queue usage: 7
<debug> nrf_dfu_ble: Buffer 0x200079D8 acquired, len 244 (244)
<debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000272DC, src=0x200079D8, len=244 bytes), queue usage: 8
<debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000273D0, src=0x20007ACC, len=244 bytes), queue usage: 9
<debug> nrf_dfu_ble: Buffer 0x20007DA8 acquired, len 244 (244)
<debug> nrf_dfu_ble: Buffer 0x20007E9C acquired, len 244 (244)
<debug> nrf_dfu_ble: Buffer 0x20007F90 acquired, len 244 (244)
Logs dropped (1)
<debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027988, src=0x20008084, len=244 bytes), queue usage: 15
Logs dropped (1)
Logs dropped (2)
Logs dropped (2)
<debug> nrf_dfu_ble: Buffer 0x20008178 acquired, len 244 (244)
Logs dropped (2)
<debug> nrf_dfu_req_handler: Start address : 0x27000, address offset 0xA7C
Logs dropped (1)
<debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027A7C, src=0x20008178, len=244 bytes), queue usage: 16
<debug> nrf_dfu_ble: Buffer 0x2000826C acquired, len 244 (244)
Logs dropped (2)
<debug> nrf_dfu_req_handler: Start address : 0x27000, address offset 0xB70
Logs dropped (1)
<debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027B70, src=0x2000826C, len=244 bytes), queue usage: 17
Logs dropped (1)
Logs dropped (2)
<warning> nrf_dfu_flash: nrf_fstorage_write() failed with error 0x4.
Logs dropped (1)
Logs dropped (3)
Logs dropped (1)
Logs dropped (2)
<debug> nrf_dfu_req_handler: Write flash error
Logs dropped (1)
<debug> nrf_dfu_ble: Freeing buffer 0x2000826C
Logs dropped (2)
Logs dropped (3)
Logs dropped (1)
Logs dropped (1)
Logs dropped (2)
Logs dropped (1)
Logs dropped (1)
Logs dropped (2)
Logs dropped (2)
Logs dropped (1)
Logs dropped (1)
Logs dropped (1)
Logs dropped (1)
<debug> nrf_dfu_ble: Buffer 0x2000826C acquired, len 192 (244)
Logs dropped (1)
Logs dropped (1)
Logs dropped (1)
Logs dropped (2)
Logs dropped (1)
<debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00027B70, src=0x2000826C, len=192 bytes), queue usage: 17
Logs dropped (5)
Logs dropped (3)
Logs dropped (1)
<debug> nrf_dfu_req_handler: Req on_data_obj_crc_request
Logs dropped (1)
<debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (data)
Logs dropped (2)
<debug> nrf_dfu_req_handler: Offset:2928, CRC:0xCCAD3863
Logs dropped (2)
Logs dropped (3)
Logs dropped (3)
Logs dropped (2)
Logs dropped (1)
<debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00027000, len=1 pages), queue usage: 17
Logs dropped (2)
Logs dropped (2)
<warning> nrf_dfu_flash: nrf_fstorage_erase() failed with error 0x4.
Logs dropped (2)
<error> nrf_dfu_req_handler: Erase operation failed
Logs dropped (1)
<debug> nrf_dfu_req_handler: Request handling complete. Result: 0x5
Logs dropped (1)
<warning> nrf_dfu_ble: DFU request 1 failed with error: 0x5
modified  nrf_fstorage_sd.c
static uint32_t write_execute(nrf_fstorage_sd_op_t const * p_op)
    //uint32_t chunk_len;
    //chunk_len = MIN(p_op->write.len - p_op->write.offset, NRF_FSTORAGE_SD_MAX_WRITE_SIZE);
    //chunk_len = MAX(1, chunk_len / m_flash_info.program_unit);
    ///* Cast to p_src to uint32_t to perform arithmetic. */
    //uint32_t       * p_dest = (uint32_t*)(p_op->write.dest + p_op->write.offset);
    //uint32_t const * p_src  = (uint32_t*)((uint32_t)p_op->write.p_src + p_op->write.offset);
    //return sd_flash_write(p_dest, p_src, chunk_len);
    uint32_t err_code;
    uint32_t chunk_len;
    uint32_t         p_dest = (p_op->write.dest + p_op->write.offset);
    err_code = nrfx_qspi_write(p_src, chunk_len, p_dest);
    return err_code;
static uint32_t erase_execute(nrf_fstorage_sd_op_t const * p_op)
    //NRF_LOG_DEBUG("Erase page number %d, progress %d", p_op->erase.page, p_op->erase.progress);
    //return sd_flash_page_erase(p_op->erase.page + p_op->erase.progress);
    uint32_t err_code;
    uint32_t erase_start_addr = (p_op->erase.page + p_op->erase.progress) * 4096;
    nrfx_qspi_erase(NRF_QSPI_ERASE_LEN_4KB, erase_start_addr);
    NRF_LOG_DEBUG("SD Erase page address : 0x%x", erase_start_addr);
    return err_code;
static ret_code_t read(nrf_fstorage_t const * p_fs, uint32_t src, void * p_dest, uint32_t len)
    //memcpy(p_dest, (uint32_t*)src, len);
    //NRF_LOG_DEBUG("sd Read");
    //return NRF_SUCCESS;
    ret_code_t err_code;
    err_code = nrfx_qspi_read(p_dest, len, src);
    return err_code;
    I see the log and your modified nrf_fstorage_sd.c but I am not sure how you use this and how you intend it to work, nor how it fails. Can you elaborate by providing more overview and also details about this?
  • hello Einar, I'm want to write external flash instead of internal flash using BLE DFU.
    when the download is complete and I will copy it to internal flash memory. but it stop while receiving data over BLE.
    I think that 'nrf_fstorage_sys_evt_handler()' was not called because a problem occurred after using 'erase_execute', 'write_execute'
    Is there a way to call the 'nrf_fstorage_sys_evt_handler()'?
    attach modified nrf_fstorage_sd.c
     * Copyright (c) 2016 - 2020, Nordic Semiconductor ASA
     * All rights reserved.
    #include "sdk_common.h"
    #if NRF_MODULE_ENABLED(NRF_FSTORAGE)
    #include "nrf_fstorage_sd.h"
    #include <stdint.h>
    #include <string.h>
    #include <stdbool.h>
    #include "nordic_common.h"
    #include "nrf_soc.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_atomic.h"
    #include "nrf_atfifo.h"
    #include "nrf_log.h"
    #include "nrfx_qspi.h"
    #if (NRF_FSTORAGE_SD_MAX_WRITE_SIZE % 4)
    #error NRF_FSTORAGE_SD_MAX_WRITE_SIZE must be a multiple of the word size.
    /**@brief   fstorage operation codes. */
    typedef enum
        NRF_FSTORAGE_OP_WRITE,  //!< Write bytes to flash.
        NRF_FSTORAGE_OP_ERASE   //!< Erase flash pages.
    } nrf_fstorage_sd_opcode_t;
    ANON_UNIONS_ENABLE;
    /**@brief   fstorage operation queue element. */
    typedef struct
        nrf_fstorage_t           const * p_fs;     //!< The fstorage instance that requested the operation.
        nrf_fstorage_sd_opcode_t         op_code;  //!< Requested operation.
        void                           * p_param;  //!< User-defined parameter passed to the event handler.
        union
            struct
                void     const * p_src;     //!< Data to be written to flash.
                uint32_t         dest;      //!< Destination of the data in flash.
                uint32_t         len;       //!< Length of the data to be written (in bytes).
                uint32_t         offset;    //!< Write offset.
            } write;
            struct
                uint32_t page;              //!< Physical page number.
                uint32_t progress;          //!< Number of pages erased.
                uint32_t pages_to_erase;    //!< Total number of pages to erase.
            } erase;
    } nrf_fstorage_sd_op_t;
    ANON_UNIONS_DISABLE;
    typedef enum
        NRF_FSTORAGE_STATE_IDLE,            //!< No operations requested to the SoftDevice.
        NRF_FSTORAGE_STATE_OP_PENDING,      //!< A non-fstorage operation is pending.
        NRF_FSTORAGE_STATE_OP_EXECUTING,    //!< An fstorage operation is executing.
    } nrf_fstorage_sd_state_t;
    /**@brief   Internal state. */
    typedef struct
        nrf_atomic_flag_t       initialized;    //!< fstorage is initalized.
        nrf_atomic_flag_t       queue_running;  //!< The queue is running.
                                                /** Prevent API calls from entering queue_process(). */
        nrf_fstorage_sd_state_t state;          //!< Internal fstorage state.
        uint32_t                retries;        //!< Number of times an operation has been retried on timeout.
        bool                    sd_enabled;     //!< The SoftDevice is enabled.
        bool                    paused;         //!< A SoftDevice state change is impending.
                                                /** Do not load a new operation when the last one completes. */
    } nrf_fstorage_sd_work_t;
    void nrf_fstorage_sys_evt_handler(uint32_t, void *);
    bool nrf_fstorage_sdh_req_handler(nrf_sdh_req_evt_t, void *);
    void nrf_fstorage_sdh_state_handler(nrf_sdh_state_evt_t, void *);
    /* Flash device information. */
    static nrf_fstorage_info_t m_flash_info =
    #if   defined(NRF51)
        .erase_unit   = 1024,
    #elif defined(NRF52_SERIES)
        .erase_unit   = 4096,
        .program_unit = 4,
        .rmap         = true,
        .wmap         = false,
    /* Queue of fstorage operations. */
    NRF_ATFIFO_DEF(m_fifo, nrf_fstorage_sd_op_t, NRF_FSTORAGE_SD_QUEUE_SIZE);
    /* Define a nrf_sdh_soc event observer to receive SoftDevice system events. */
    NRF_SDH_SOC_OBSERVER(m_sys_obs, 0, nrf_fstorage_sys_evt_handler, NULL);
    /* nrf_sdh request observer. */
    NRF_SDH_REQUEST_OBSERVER(m_req_obs, 0) =
        .handler = nrf_fstorage_sdh_req_handler,
    /* nrf_sdh state observer. */
    NRF_SDH_STATE_OBSERVER(m_state_obs, 0) =
        .handler = nrf_fstorage_sdh_state_handler,
    static nrf_fstorage_sd_work_t   m_flags;        /* Internal status. */
    static nrf_fstorage_sd_op_t   * m_p_cur_op;     /* The current operation being executed. */
    static nrf_atfifo_item_get_t    m_iget_ctx;     /* Context for nrf_atfifo_item_get() and nrf_atfifo_item_free(). */
    /* Send events to the application. */
    static void event_send(nrf_fstorage_sd_op_t const * p_op, ret_code_t result)
        if (p_op->p_fs->evt_handler == NULL)
            /* Nothing to do. */
            return;
        nrf_fstorage_evt_t evt =
            .result  = result,
            .p_param = p_op->p_param,
        switch (p_op->op_code)
            case NRF_FSTORAGE_OP_WRITE:
                evt.id    = NRF_FSTORAGE_EVT_WRITE_RESULT;
                evt.addr  = p_op->write.dest;
                evt.p_src = p_op->write.p_src;
                evt.len   = p_op->write.len;
            case NRF_FSTORAGE_OP_ERASE:
                evt.id   = NRF_FSTORAGE_EVT_ERASE_RESULT;
                evt.addr = (p_op->erase.page * m_flash_info.erase_unit);
                evt.len  = p_op->erase.pages_to_erase;
                /* Should not happen. */
        p_op->p_fs->evt_handler(&evt);
    /* Write to flash. */
        uint32_t err_code;
        uint32_t chunk_len;
        sd_flash_write(NULL, NULL, chunk_len);
        return err_code;
    /* Erase flash page(s). */
        uint32_t err_code;
        return err_code;
    /* Free the current queue element. */
    static void queue_free(void)
        (void) nrf_atfifo_item_free(m_fifo, &m_iget_ctx);
    /* Load a new operation from the queue. */
    static bool queue_load_next(void)
        m_p_cur_op = nrf_atfifo_item_get(m_fifo, &m_iget_ctx);
        return (m_p_cur_op != NULL);
    /* Execute an operation in the queue. */
    static void queue_process(void)
        uint32_t rc;
        if (m_flags.state == NRF_FSTORAGE_STATE_IDLE)
            if (!queue_load_next())
                /* No more operations, nothing to do. */
                m_flags.queue_running = false;
                return;
        m_flags.state = NRF_FSTORAGE_STATE_OP_EXECUTING;
        switch (m_p_cur_op->op_code)
                rc = write_execute(m_p_cur_op);
                rc = erase_execute(m_p_cur_op);
                rc = NRF_ERROR_INTERNAL;
        NRF_LOG_DEBUG("Que Excute code : %d, rc : %d", m_p_cur_op->op_code,rc);
        NRF_LOG_DEBUG("Queue Excute sd_enabled : %d", m_flags.sd_enabled);
        if(rc != 0)
          NRF_LOG_DEBUG("queue process error  0x%x", rc);
        switch (rc)
            case NRF_SUCCESS:
                /* The operation was accepted by the SoftDevice.
                 * If the SoftDevice is enabled, wait for a system event. Otherwise,
                 * the SoftDevice call is synchronous and will not send an event so we simulate it. */
                if (!m_flags.sd_enabled)
                    nrf_fstorage_sys_evt_handler(NRF_EVT_FLASH_OPERATION_SUCCESS, NULL);
            } break;
            case NRF_ERROR_BUSY:
                /* The SoftDevice is executing a flash operation that was not requested by fstorage.
                 * Stop processing the queue until a system event is received. */
                m_flags.state = NRF_FSTORAGE_STATE_OP_PENDING;
            } break;
                /* An error has occurred. We cannot proceed further with this operation. */
                event_send(m_p_cur_op, NRF_ERROR_INTERNAL);
                /* Reset the internal state so we can accept other operations. */
                m_flags.state         = NRF_FSTORAGE_STATE_IDLE;
                queue_free();
            } break;
    /* Start processing the queue if it is not running and fstorage is not paused. */
    static void queue_start(void)
        NRF_LOG_DEBUG("queue_start() queue_running : %d, paused : %d", m_flags.queue_running, m_flags.paused);
        if (   (!nrf_atomic_flag_set_fetch(&m_flags.queue_running))
            && (!m_flags.paused))
            queue_process();
    /* Flash operation success callback. Keeps track of the progress of an operation. */
    static bool on_operation_success(nrf_fstorage_sd_op_t * const p_op)
        /* Reset the retry counter on success. */
        m_flags.retries = 0;
                /* Update the offset only if the operation is successful
                 * so that it can be retried in case it times out. */
                uint32_t const chunk_len = MIN(p_op->write.len - p_op->write.offset,
                p_op->write.offset += chunk_len;
                if (p_op->write.offset == p_op->write.len)
                    return true;
            } break;
                p_op->erase.progress++;
                if (p_op->erase.progress == p_op->erase.pages_to_erase)
                    return true;
            } break;
        return false;
    /* Flash operation failure callback. */
    static bool on_operation_failure(nrf_fstorage_sd_op_t const * p_op)
        UNUSED_PARAMETER(p_op);
        m_flags.retries++;
        if (m_flags.retries > NRF_FSTORAGE_SD_MAX_RETRIES)
            /* Maximum amount of retries reached. Give up. */
            return true;
        return false;
    static ret_code_t init(nrf_fstorage_t * p_fs, void * p_param)
        UNUSED_PARAMETER(p_param);
        p_fs->p_flash_info = &m_flash_info;
        if (!nrf_atomic_flag_set_fetch(&m_flags.initialized))
    #if NRF_SDH_ENABLED
            m_flags.sd_enabled = nrf_sdh_is_enabled();
            (void) NRF_ATFIFO_INIT(m_fifo);
        return NRF_SUCCESS;
    static ret_code_t uninit(nrf_fstorage_t * p_fs, void * p_param)
        UNUSED_PARAMETER(p_fs);
        /* The state is re-initialized upon init().
         * The common uninitialization code is run by the caller. */
        memset(&m_flags, 0x00, sizeof(m_flags));
        (void) nrf_atfifo_clear(m_fifo);
        return NRF_SUCCESS;
    static ret_code_t write(nrf_fstorage_t const * p_fs,
                            uint32_t               dest,
                            void           const * p_src,
                            uint32_t               len,
                            void                 * p_param)
        nrf_fstorage_sd_op_t  * p_op;
        nrf_atfifo_item_put_t   iput_ctx;
        NRF_LOG_DEBUG("sd Write");
        /* Get a free queue element. */
        p_op = nrf_atfifo_item_alloc(m_fifo, &iput_ctx);
        if (p_op == NULL)
            return NRF_ERROR_NO_MEM;
        /* Initialize the operation. */
        memset(p_op, 0x00, sizeof(nrf_fstorage_sd_op_t));
        p_op->op_code     = NRF_FSTORAGE_OP_WRITE;
        p_op->p_fs        = p_fs;
        p_op->p_param     = p_param;
        p_op->write.dest  = dest;
        p_op->write.p_src = p_src;
        p_op->write.len   = len;
        /* Put the operation on the queue. */
        (void) nrf_atfifo_item_put(m_fifo, &iput_ctx);
        queue_start();
        return NRF_SUCCESS;
        return err_code;
    static ret_code_t erase(nrf_fstorage_t const * p_fs,
                            uint32_t               page_addr,
                            uint32_t               len,
                            void                 * p_param)
        NRF_LOG_DEBUG("sd erase");
        if (p_op == NULL)
        p_op->op_code              = NRF_FSTORAGE_OP_ERASE;
        p_op->p_fs                 = p_fs;
        p_op->erase.page           = (page_addr / m_flash_info.erase_unit);
        p_op->erase.pages_to_erase = len;
        queue_start();
        return NRF_SUCCESS;
    static uint8_t const * rmap(nrf_fstorage_t const * p_fs, uint32_t addr)
        return (uint8_t*)addr;
    static uint8_t * wmap(nrf_fstorage_t const * p_fs, uint32_t addr)
        UNUSED_PARAMETER(addr);
        /* Not supported. */
        return NULL;
    static bool is_busy(nrf_fstorage_t const * p_fs)
        return (m_flags.state != NRF_FSTORAGE_STATE_IDLE);
    void nrf_fstorage_sys_evt_handler(uint32_t sys_evt, void * p_context)
        UNUSED_PARAMETER(p_context);
        if (   (sys_evt != NRF_EVT_FLASH_OPERATION_SUCCESS)
            && (sys_evt != NRF_EVT_FLASH_OPERATION_ERROR))
            /* Ignore any non-flash events. */
            return;
        NRF_LOG_DEBUG("nrf_fstorage_sys_evt_handler() flag state %d, paused %d, sys_evt %d ",m_flags.state, m_flags.paused, sys_evt);
        switch (m_flags.state)
            case NRF_FSTORAGE_STATE_IDLE:
                /* Ignore flash events if no flash operation was requested. */
                return;
            case NRF_FSTORAGE_STATE_OP_PENDING:
                /* The SoftDevice has completed a flash operation that was not requested by fstorage.
                 * It should be possible to request an operation now.
                 * Process the queue at the end of this function. */
            case NRF_FSTORAGE_STATE_OP_EXECUTING:
                /* Handle the result of a flash operation initiated by this module. */
                bool operation_finished = false;
                switch (sys_evt)
                    case NRF_EVT_FLASH_OPERATION_SUCCESS:
                        operation_finished = on_operation_success(m_p_cur_op);
                    case NRF_EVT_FLASH_OPERATION_ERROR:
                        operation_finished = on_operation_failure(m_p_cur_op);
                if (operation_finished)
                    /* The operation has finished. Change state to NRF_FSTORAGE_STATE_IDLE
                     * so that queue_process() will fetch a new operation from the queue. */
                    event_send(m_p_cur_op, (sys_evt == NRF_EVT_FLASH_OPERATION_SUCCESS) ?
                                            NRF_SUCCESS : NRF_ERROR_TIMEOUT);
                    NRF_LOG_DEBUG("operation_finished  m_flags.state %d",  m_flags.state);
                    /* Free the queue element after sending out the event to prevent API calls made
                     * in the event context to queue elements indefinitely, without this function
                     * ever returning in case the SoftDevice calls are synchronous. */
                    queue_free();
            } break;
        if (!m_flags.paused)
            queue_process();
            /* A flash operation has completed. Let the SoftDevice change state. */
            (void) nrf_sdh_request_continue();
    bool nrf_fstorage_sdh_req_handler(nrf_sdh_req_evt_t req, void * p_context)
        UNUSED_PARAMETER(req);
        m_flags.paused = true;
        NRF_LOG_DEBUG("nrf_fstorage_sdh_req_handler");
        /* If there are any operations ongoing, pause the SoftDevice state change. */
        return (m_flags.state == NRF_FSTORAGE_STATE_IDLE);
    void nrf_fstorage_sdh_state_handler(nrf_sdh_state_evt_t state, void * p_context)
        NRF_LOG_DEBUG("nrf_fstorage_sdh_state_handler state %d", state);
        if (    (state == NRF_SDH_EVT_STATE_ENABLED)
            ||  (state == NRF_SDH_EVT_STATE_DISABLED))
            m_flags.paused     = false;
            m_flags.sd_enabled = (state == NRF_SDH_EVT_STATE_ENABLED);
            /* Execute any operations still in the queue. */
            queue_process();
    /* Exported API implementation. */
    nrf_fstorage_api_t nrf_fstorage_sd =
        .init    = init,
        .uninit  = uninit,
        .read    = read,
        .write   = write,
        .erase   = erase,
        .rmap    = rmap,
        .wmap    = wmap,
        .is_busy = is_busy
    #endif // NRF_FSTORAGE_ENABLED
    nrf_fstorage_sys_evt_handler() is registered as an observer for SoC event from the SoftDevice, so whenever there is a new SoC event, nrf_fstorage_sys_evt_handler() will be called. When writing to the internal flash using the SoftDevice API you will get a SoC event whenever a operation has completed. When writing to external flash this does not happen as that does not generate a SoftDevice SoC event. In stead, you would probably want to use QSPI driver events to know that a write has completed (NRFX_QSPI_EVENT_DONE).
