ubuntu@ip-172-31-25-55:~/aws$ npx tsc
cdk/resources/CellGeolocation.ts:7:25 - error TS2307: Cannot find module '@aws-cdk/aws-lambda' or its corresponding type declarations.
7 import * as Lambda from '@aws-cdk/aws-lambda'
cdk/resources/CellGeolocation.ts:17:22 - error TS2307: Cannot find module '@aws-cdk/aws-sqs' or its corresponding type declarations.
17 import * as SQS from '@aws-cdk/aws-sqs'
cdk/resources/CellGeolocationApi.ts:4:25 - error TS2307: Cannot find module '@aws-cdk/aws-lambda' or its corresponding type declarations.
4 import * as Lambda from '@aws-cdk/aws-lambda'
cdk/resources/CellGeolocationApi.ts:8:33 - error TS2307: Cannot find module '@aws-cdk/aws-logs' or its corresponding type declarations.
8 import * as CloudWatchLogs from '@aws-cdk/aws-logs'
cdk/resources/HistoricalData.ts:4:25 - error TS2307: Cannot find module '@aws-cdk/aws-lambda' or its corresponding type declarations.
cdk/resources/LambdaLogGroup.ts:2:25 - error TS2307: Cannot find module '@aws-cdk/aws-lambda' or its corresponding type declarations.
2 import * as Lambda from '@aws-cdk/aws-lambda'
cdk/resources/LambdaLogGroup.ts:3:33 - error TS2307: Cannot find module '@aws-cdk/aws-logs' or its corresponding type declarations.
3 import * as CloudWatchLogs from '@aws-cdk/aws-logs'
cdk/resources/LambdasWithLayer.ts:1:25 - error TS2307: Cannot find module '@aws-cdk/aws-lambda' or its corresponding type declarations.
1 import * as Lambda from '@aws-cdk/aws-lambda'
cdk/resources/NodeJS14Runtime.ts:1:25 - error TS2307: Cannot find module '@aws-cdk/aws-lambda' or its corresponding type declarations.
cdk/resources/ThingGroup.ts:2:25 - error TS2307: Cannot find module '@aws-cdk/aws-lambda' or its corresponding type declarations.
cdk/resources/ThingGroupLambda.ts:3:25 - error TS2307: Cannot find module '@aws-cdk/aws-lambda' or its corresponding type declarations.
3 import * as Lambda from '@aws-cdk/aws-lambda'
cdk/resources/lambdasOnS3.ts:1:25 - error TS2307: Cannot find module '@aws-cdk/aws-lambda' or its corresponding type declarations.
cdk/stacks/AssetTracker/stack.ts:3:25 - error TS2307: Cannot find module '@aws-cdk/aws-lambda' or its corresponding type declarations.
cdk/stacks/FirmwareCI.ts:2:25 - error TS2307: Cannot find module '@aws-cdk/aws-lambda' or its corresponding type declarations.
cdk/test-resources/HttpApiMockStack.ts:2:25 - error TS2307: Cannot find module '@aws-cdk/aws-lambda' or its corresponding type declarations.
cdk/test-resources/HttpApiMockStack.ts:5:29 - error TS2307: Cannot find module '@aws-cdk/aws-apigateway' or its corresponding type declarations.
5 import * as ApiGateway from '@aws-cdk/aws-apigateway'
Found 16 errors.
