Trying to execute the following command. It isn't showing anything
ubuntu@ip-172-31-25-55:~/aws$ npx cdk -a 'node dist/cdk/cloudformation-sourcecode.js' deploy
Hei,
this could be because the AWS credentials are missing, could you double check that you are authenticated, e.g. by running
aws sts get-caller-identity
If you are I need a little bit more information about your environment:
~Markus
Hey Markus
Please find the following info
Operating system ===> 5.4.0-1047-aws
aws --version ===> aws-cli/1.18.69 Python/3.6.9 Linux/5.4.0-1047-aws botocore/1.16.19
node ===> v12.22.1
Thanks
Hei, please immediately revoke the AWS credentials that you just posted. Never share them!
Once you have created new credentials follow the instruction on how to authenticate against AWS.
Hey, I did.
Okay, I got it. Could you please let me know what value needs to be given for the default output format
