Trying to execute the following command. It isn't showing anything
ubuntu@ip-172-31-25-55:~/aws$ npx cdk -a 'node dist/cdk/cloudformation-sourcecode.js' deploy
I got the Userid, Account, Arn by executing the aws sts get-caller-identity. Can you please let me know what I need to do next with the steps
I did it. Everything looks good. I checked it now
Markus,
Could you please let me know, What I need to do next?
Just to make sure:
When you run
`npx cdk -a 'node dist/cdk/cloudformation-sourcecode.js' deploy`
no output can be observed.
Does the command eventually time out (with which error message)?
Or after how long do you terminate it manually?
I did. When I'm running the following command. I'm getting the following error.
ubuntu@ip-172-31-25-55:~/aws$ npx cdk bootstrap
internal/modules/cjs/loader.js:818
throw err;
Error: Cannot find module '@aws-cdk/aws-autoscaling-common'
Require stack:
- /home/ubuntu/aws/node_modules/@aws-cdk/aws-applicationautoscaling/lib/step-scaling-policy.js
- /home/ubuntu/aws/node_modules/@aws-cdk/aws-applicationautoscaling/lib/scalable-target.js
- /home/ubuntu/aws/node_modules/@aws-cdk/aws-applicationautoscaling/lib/base-scalable-attribute.js
- /home/ubuntu/aws/node_modules/@aws-cdk/aws-applicationautoscaling/lib/index.js
- /home/ubuntu/aws/node_modules/@aws-cdk/aws-lambda/lib/alias.js
- /home/ubuntu/aws/node_modules/@aws-cdk/aws-lambda/lib/index.js
- /home/ubuntu/aws/node_modules/@aws-cdk/custom-resources/lib/aws-custom-resource/aws-custom-resource.js
- /home/ubuntu/aws/node_modules/@aws-cdk/custom-resources/lib/aws-custom-resource/index.js
- /home/ubuntu/aws/node_modules/@aws-cdk/custom-resources/lib/index.js
- /home/ubuntu/aws/node_modules/@aws-cdk/aws-cognito/lib/user-pool-domain.js
- /home/ubuntu/aws/node_modules/@aws-cdk/aws-cognito/lib/user-pool.js
- /home/ubuntu/aws/node_modules/@aws-cdk/aws-cognito/lib/index.js
- /home/ubuntu/aws/dist/cdk/stacks/AssetTracker/stack.js
- /home/ubuntu/aws/dist/cdk/apps/AssetTracker.js
- /home/ubuntu/aws/dist/cdk/cloudformation.js
at Function.Module._resolveFilename (internal/modules/cjs/loader.js:815:15)
at Function.Module._load (internal/modules/cjs/loader.js:667:27)
at Module.require (internal/modules/cjs/loader.js:887:19)
at require (internal/modules/cjs/helpers.js:74:18)
at Object.<anonymous> (/home/ubuntu/aws/node_modules/@aws-cdk/aws-applicationautoscaling/lib/step-scaling-policy.js:6:34)
at Module._compile (internal/modules/cjs/loader.js:999:30)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
at Module.load (internal/modules/cjs/loader.js:863:32)
at Function.Module._load (internal/modules/cjs/loader.js:708:14)
at Module.require (internal/modules/cjs/loader.js:887:19) {
code: 'MODULE_NOT_FOUND',
requireStack: [
'/home/ubuntu/aws/node_modules/@aws-cdk/aws-applicationautoscaling/lib/step-scaling-policy.js',
'/home/ubuntu/aws/node_modules/@aws-cdk/aws-applicationautoscaling/lib/scalable-target.js',
'/home/ubuntu/aws/node_modules/@aws-cdk/aws-applicationautoscaling/lib/base-scalable-attribute.js',
'/home/ubuntu/aws/node_modules/@aws-cdk/aws-applicationautoscaling/lib/index.js',
'/home/ubuntu/aws/node_modules/@aws-cdk/aws-lambda/lib/alias.js',
'/home/ubuntu/aws/node_modules/@aws-cdk/aws-lambda/lib/index.js',
'/home/ubuntu/aws/node_modules/@aws-cdk/custom-resources/lib/aws-custom-resource/aws-custom-resource.js',
'/home/ubuntu/aws/node_modules/@aws-cdk/custom-resources/lib/aws-custom-resource/index.js',
'/home/ubuntu/aws/node_modules/@aws-cdk/custom-resources/lib/index.js',
'/home/ubuntu/aws/node_modules/@aws-cdk/aws-cognito/lib/user-pool-domain.js',
'/home/ubuntu/aws/node_modules/@aws-cdk/aws-cognito/lib/user-pool.js',
'/home/ubuntu/aws/node_modules/@aws-cdk/aws-cognito/lib/index.js',
'/home/ubuntu/aws/dist/cdk/stacks/AssetTracker/stack.js',
'/home/ubuntu/aws/dist/cdk/apps/AssetTracker.js',
'/home/ubuntu/aws/dist/cdk/cloudformation.js'
Subprocess exited with error 1
