NRF5340 power consumption issue when QSPI is disabled.
Hi
        I am having some issues with running QSPI on the nRF5340DK board.
After I disabled the QSPI, I found the board still having a high current consumption of 700 uA.
Although I tried trying edit source code follow the nrf52840_errata [122] docs which had a similar problem. But I still can't fix the problem.
static int qspi_nor_read(const struct device *dev, off_t addr, void *dest,
			 size_t size)
	if (!dest) {
		return -EINVAL;
	/* read size must be non-zero */
	if (!size) {
		return 0;
	const struct qspi_nor_config *params = dev->config;
	/* affected region should be within device */
	if (addr < 0 ||
	    (addr + size) > params->size) {
		LOG_ERR("read error: address or size "
			"exceeds expected values."
			"Addr: 0x%lx size %zu", (long)addr, size);
		return -EINVAL;
	int rc = ANOMALY_122_INIT(dev);
	if (rc != 0) {
		goto out;
	qspi_lock(dev);
	nrfx_err_t res = read_non_aligned(dev, addr, dest, size);
	qspi_unlock(dev);
	rc = qspi_get_zephyr_ret_code(res);
out:
	ANOMALY_122_UNINIT(dev);
	return rc;
static void anomaly_122_uninit(const struct device *dev)
	struct qspi_nor_data *dev_data = get_dev_data(dev);
	bool last = true;
	qspi_lock(dev);
#ifdef CONFIG_MULTITHREADING
	/* The last thread to finish using the driver uninit the QSPI */
	(void) k_sem_take(&dev_data->count, K_NO_WAIT);
	last = (k_sem_count_get(&dev_data->count) == 0);
	if (last) {
		while (nrfx_qspi_mem_busy_check() != NRFX_SUCCESS) {
			k_msleep(50);
		nrf_gpio_cfg_output(QSPI_PROP_AT(csn_pins, 0));
		nrf_gpio_pin_set(QSPI_PROP_AT(csn_pins, 0));
		//*(volatile uint32_t *)0x40029010ul = 1ul;
		//*(volatile uint32_t *)0x40029054ul = 1ul;
		nrfx_qspi_uninit();
		qspi_initialized = false;
	qspi_unlock(dev);
	LOG_INF("anomaly_122_uninit");
nrf_qspi_nor.rar
  • Hi Wasan,
    Seems to me that you are using a nrf52840 DK(PCA10056), and not a nrf53 DK. You said that you did not encounter the same issue on the nrf52840.
    If you are using a older DK for the 53 series then you might have a PDK. There are some issues that could cause these type of behavior.
    But I recommend that you try to disable UART that are not in use in the .overlay file also.
    Jonathan
  • OhI'm so sorry for the mistake about my image.
    This's my nRF5340DK Board
    pca10095
    0.11.0
    2020.45
    960173359
    I will try to disable UART for test agian.
    Wasan
  • Hi Jonathan
         I tested the device disabled uart in overlay file.But I found the same problem.
    SDK Vesion
    nRF Connect SDK 1.7.1
    Regards
    Wasan
    At what frequency is the scalable QSPI input clock (PCLK192M) running at? This can be configured in register HFCLK192MCTRL. When running at the full 192MHz speed the device uses more current (with a sleep current of ~700uA).
    To lower the sleep current consumption you would need to configure the QSPI to a lower frequency during sleep. Scaling this down to 96MHz (divide by two) should give much better numbers. Depending on the use-case reducing, the frequency just around CPU sleep should be a viable option. This is described closer under Voltage and Frequency Scaling in the PS.
    Jørgen
