Need a working example of using an SD card with FAT filesystem on the nRF9160.
There is a demo zephyr/samples/subsys/fa/fat_fs.
This purports to mount an SD card.
Is this for the unpopulated SD socket on the nRF9160 board?
The ticket https://devzone.nordicsemi.com/f/nordic-q-a/58558/reading-sd-card-on-nrf9160dk
talks about using an Adafruit SD breakout board over SPI.
These issues seem to be with earlier versions of the SDK.
It says..
I am using adafruit micro-sd breakout board and kingston micro sd card 8GB which is formatted to FAT32 Filesystem.
Connections are as follow:
SCK (Pin 11) -> CLK
MOSI (Pin 12) -> DI
MISO (Pin 13) -> DO
CS (Pin 10) -> CS
It also includes an image and it appears to match these connections.
However, the overlay file listed later in the same ticket has different pins.
There are two versions of the overlay file...
Attached is a working project using SPI3. The output is shown in the image.
&spi3 {
        status = "okay";
        sck-pin = <10>;
        mosi-pin = <11>;
        miso-pin = <12>;
        cs-gpios = <&gpio0 13 0>;
        sdhc0: sdhc@0 {
                compatible = "zephyr,mmc-spi-slot";
                reg = <0>;
                status = "okay";
                label = "SDHC0";
                spi-max-frequency = <24000000>;
But earlier in the same file it has:
 * Copyright (c) 2019 Tavish Naruka <tavishnaruka@gmail.com>
&spi3 {
        status = "okay";
        cs-gpios = <&gpio0 16 0>;
        sdhc0: sdhc@0 {
                reg = <0>;
                status = "okay";
                label = "SDHC0";
&spi3 {
        status = "okay";
        sck-pin = <19>;
        mosi-pin = <18>;
        miso-pin = <17>;
At the end there is a link to another ticket https://devzone.nordicsemi.com/f/nordic-q-a/59430/nrf9160-sd-card-access-via-spi/242347#242347
that says "The solution to this problem is to set the "Size of RAM buffers for SPIM peripherals" to some number. If the size is set to 0, the SPI transceive function will always return error."
However, my SDK (v1.5) has this set properly.
Has anyone at Nordic got this working?
  • Here is the output:
    *** Booting Zephyr OS build v2.4.99-ncs1  ***
    Error mounting disk.
    [00:00:00.004,180] <err> main: Storage init ERROR!
    [00:00:00.004,211] <err> fs: fs mount error (-5)
  • In the photo from the other ticket, the guy has the Adafruit powered on the 3v pin from what appears to be VDD on connector P1.
    I have the 5V connected to the 5V pin on connector P1.
    have you set the CONFIG_DISK_DRIVER_SDMMC=y config in the prj.conf? This enables the SD driver.
  • I am using the SDK 1.5 and Zephyr 2.4.99.
    What version does this require?
    It appears to be for 2.6-rc1.
    Here is my prj.conf:
    # Original from fat_fs
    #CONFIG_DISK_ACCESS=y
    #CONFIG_LOG=y
    #CONFIG_FILE_SYSTEM=y
    #CONFIG_FAT_FILESYSTEM_ELM=y
    #CONFIG_PRINTK=y
    #CONFIG_MAIN_STACK_SIZE=2048
    CONFIG_SPI=y
    CONFIG_SPI_3=y
    CONFIG_DISK_ACCESS_SDHC=y
    CONFIG_DISK_ACCESS_SPI_SDHC=y
    CONFIG_LOG=y
    CONFIG_NRFX_SPIM=y
    CONFIG_SPI_NRFX_RAM_BUFFER_SIZE=64
    CONFIG_GPIO=y
    When I add ... the build fails as follows:
    Loaded configuration '/home/r/ncs/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160ns_defconfig'
    Merged configuration '/home/r/ncs/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160ns_0_7_0.conf'
    Merged configuration '/home/r/ncs/zephyr/samples/subsys/fs/fat_fs/prj.conf'
    /home/r/ncs/zephyr/samples/subsys/fs/fat_fs/prj.conf:19: warning: attempt to assign the value 'y' to the undefined symbol DISK_DRIVER_SDMMC
    error: Aborting due to Kconfig warnings
    With my configuration when I step into the initialization I get to sdhc_spi_detect in zephyr/subsys/disk/disk_access_spi_sdhc.c mean I have the right driver enabled?
  • It is not available on 1.5, but you can try master. It should work there.
1 2 3
